30.11.2016 18:21:36 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
Denne kommer "hver gang" jeg starter HS3, Z-Wave er tilkoblet med kabel, IP er lagt inn i router.
Etter x-feilmeldinger kommer HS3 opp, irriterende problem.
Andre med samme feil?
  • 4 uker senere...
Den 2.12.2016 klokken 21.06, Moskus skrev:
Har du flere interfacer?
Hvilket interface?
Sorry for sent svar.
Det er z-wave, Homeseer Z-Net. Jeg har kun 1.
Hvis du går til Plugins -> Z-wave -> Controller Information, og utvider den øverste menyen (Z-wave Networks And Options), ser du mer enn ett nettverk der?
Tja, si det...
Den som ble lagt inn når jeg kjøpte den i sommer.
Må undersøke hvordan jeg finner utav det, og om det er nyere versjon der ute.
Er fortsatt "pasient", dermed begrenset hva jeg tør gjøre remote.
Takk.
EDIT:
Version 1.0.20 Update Available
Oppgraderer og rapporterer tilbake.
EDIT 2:
Z-NET V2 Configuration - Version 1.0.23
Endret av Erling
Starting up....
27.12.2016 17:12:01 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:04 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:07 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:10 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:13 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:16 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:19 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:22 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:25 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:28 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:31 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:34 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:37 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:40 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:43 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
27.12.2016 17:12:46 ~!~Z-Wave Error~!~EE: The EE interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).Startup Complete, 16 errors detected, check the log for more information.
Nix, ny firmware hjalp ikke.
Ved start av HS3 kommer denne loggen opp:
Oransje/gult lys på Z-Wave, etter 5 timer ble det grønt.
Noen ideer Moskus? Kan godt vente med å gjøre noe - det har kanskje ingen betydning utover irritasjonen.
Den virker med en gang? Ingen forsinkelser eller andre problemer?
Tja, andre problemer...
Jeg brakk ankelen 9. oktober og har siden vært pasient med belastningsforbud av foten, men om 2 uker skal jeg endelig hjem og får teste forsinkelse og annet da.
