Jeg har hatt det her problemet en stund, men jeg synes det har blitt oftere i det siste så nå må jeg prøve å løse det.
Jeg har da en iPad 2019 som står alltid på med HsTouch, men den lukker seg med ujevne mellomrom.
Det er ikke noe logikk i loggen om det er noe som gjør dette.
mar-27 08.26.50   Speaker Speaker host added, Name: HomeSeerServer Instance: iPad IP address: 10.0.0.211
mar-27 08.26.50   HSTouch Server Connecting speaker client to HomeSeer IP 10.0.0.40
mar-27 08.26.50   HSTouch Server Client iPad (10.0.0.211/49169) named iPad has CONNECTED.
mar-27 08.26.50   Z-Wave Device: 2 etg Jakob TV Wallplug - Watt Set to 0,5 (W)
mar-27 08.26.49   HSTouch Server Client iPad named iPad has DISCONNECTED.
mar-27 08.26.49   HSTouch Server Opening connection from:10.0.0.211/49169
mar-27 08.26.49   ASR Speaker Client speech recognition stopped
mar-27 08.26.49   Speaker Speaker host disconnected, Name: HOMESEERSERVER IP address: 10.0.0.211
mar-27 08.26.49   HSTouch Server Client iPad:iPad (10.0.0.211/49168) has raised LineDisconnected or was forced closed.
mar-27 08.26.49   HSTouch Server Warning Client dropped connection 10.0.0.211/49168
mar-27 08.26.49   Speaker Speaker host added, Name: HomeSeerServer Instance: iPad IP address: 10.0.0.211
mar-27 08.26.49   HSTouch Server Connecting speaker client to HomeSeer IP 10.0.0.40
mar-27 08.26.49   HSTouch Server Client iPad (10.0.0.211/49168) named iPad has CONNECTED.
mar-27 08.03.25   HSTouch Server Opening connection from:10.0.0.211/49168
mar-27 08.03.25   HSTouch Server Client iPad named iPad has DISCONNECTED.
mar-27 08.03.24   ASR Speaker Client speech recognition stopped
mar-27 08.03.24   Speaker Speaker host disconnected, Name: HOMESEERSERVER IP address: 10.0.0.211
mar-27 08.03.24   HSTouch Server Client iPad:iPad (10.0.0.211/49167) has raised LineDisconnected or was forced closed.
mar-27 08.03.24   HSTouch Server Warning Client dropped connection 10.0.0.211/49167
mar-27 08.03.23   Speaker Speaker host added, Name: HomeSeerServer Instance: iPad IP address: 10.0.0.211
mar-27 08.03.23   ASR Speaker Client speech recognition stopped
mar-27 08.03.23   HSTouch Server Connecting speaker client to HomeSeer IP 10.0.0.40
mar-27 08.03.23   HSTouch Server Client iPad (10.0.0.211/49167) named iPad has CONNECTED.
mar-27 08.03.21   Z-Wave Device: 2 etg Stue Varmepumpe - HDS - Ampere Set to 3,187 (3,187 Amperes)
mar-27 08.03.20   Z-Wave Device: 2 etg Jakob TV Wallplug - Watt Set to 0,6 (W)
mar-27 08.03.17   Speaker Speaker host added, Name: HomeSeerServer Instance: iPad IP address: 10.0.0.211
mar-27 08.03.17   HSTouch Server Connecting speaker client to HomeSeer IP 10.0.0.40
mar-27 08.03.17   HSTouch Server Client iPad (10.0.0.211/49167) named iPad has CONNECTED.
mar-27 08.03.16   HSTouch Server Opening connection from:10.0.0.211/49167
Noen som har det samme eller har noen ideer her?
Loggen rapporterer bare at forbindelsen plutselig er mistet, sannsynligvis når appen lukker seg på iPaden, men det kan se ut som om du har noe tilkoblingsproblemer.
Bruker du speech? Kan du prøve å deaktivere det for å se om det hjelper på stabiliteten?
Det er nok når appen lukker seg ja.
Nei, jeg bruker ikke speech, men jeg trodde at jeg hadde deaktivert det som kan deaktiveres.
For moro skyld, hvor deaktiverer jeg det?
Hvis du ikke bruker det, har du nok ikke satt det opp. Men det ligger under Tools -> Setup -> Network, se under HStouch settings. Fjern evt. brukernavn og passord der.
Alright, da er det ikke det. Det måtte være det eneste som kan få HS til å gjøre noe med iPad'en, så da tipper jeg det er iPad som gjør noe den ikke burde.
