New solar panel!
We have some good news to share with you.
As you all probably know there is a solar panel included in the package. Our initial thought was that the user automates the device based on solar conditions which means that the motor will only run when the sun is bright enough. So there will be a balance between energy consumption and energy gains and the unit will be self sufficient. That was perfect in theory...
In real life the user wants to use the device even when the sun is not strong enough to charge the batteries e.g. for privacy and going to bed at night.
Because of the feedback we have received from our 10.000 + users we have been developing a new solar panel that is powerful enough to charge the batteries in a sufficient way. Ta-da! It´s now released and available at https://www.teptron.com/product/solar-panel .
If you are interested in adding the larger solar panel to your MOVEZ kit we are going to give you an exclusive backer discount of 20%! Use the bonus code MOVEZVIP20 when you place the order and the larger solar panel will be shipped along with your Indiegogo order.*
When it comes to MOVEZ we are still working on the software and waiting for the certifications. That said we are moving forward and we want the product to be market ready as fast as possible, just like you. So we are all in this together with the same goal in mind.
*The solar panel offer is for MOVEZ backers only. If used by a non MOVEZ backer we will cancel the order.
[\quote]
Ja @Salvesen. Går du gjennom samtlige ordrer nå og forhører deg om hvem som vil ha større solcellepanel og hvor mangen da? Hehe neida ?
edit: limte inn posten til sitelux siden min post gjorde at det ble ny side
Endret av Hr Kotelett
2 minutter siden, Hr Kotelett skrev:
Ja @Salvesen. Går du gjennom samtlige ordrer nå og forhører deg om hvem som vil ha større solcellepanel og hvor mangen da? Hehe neida 1f602.png
hehe ikke for å være lat eller noe, men tror det er lettest om de som vill ha tar kontakt ??
18x5,2 cm står det på den nye, større varianten, men finner ikke noe om hvor stor den gamle er. Hvis den nye gjør at vi i Norge kan slippe tilkoblet strøm/lade batterier hver måned er det jo helt ikke uinteressant.
Min plan er å ha dem kontinuerlig koblet til strømlader. Kabler og lader er på plass for leeeeenge siden :P
Så ingen nye solcellepaneler på meg. Kommer nok ikke til å bruke de som følger med heller.
1 time siden, bio skrev:
Fortsatt mulig å slenge seg på her?
4stk
Mvh Robert
Edit: ikke solcellepaneler:)
Nei disse er bestilt for lengst, dessverre :)
Nei disse er bestilt for lengst, dessverre [emoji4]
Var det jeg trodde etter å ha skumlest postene.
Takk for svar, så får noen heller si ifra om de vil selge noen:)
På 17.10.2017 den 20.45, Salvesen skrev:
hehe ikke for å være lat eller noe, men tror det er lettest om de som vill ha tar kontakt 1f602.png1f602.png
Hehe, for å være helt ærlig så hadde jeg vært så lat at det hadde folk fått bestilt selv, er det ikke nok styr å holde rede på selve Movez'ene? :D
Hehe jo absolutt :P
Har dere mottatt disse ?
Hvordan er erfaringene deres ?
Fikk oppdatering i helgen. Vi kan forvente dem i første kvartal....
Dear MOVEZ community
We hope that you are all well.
The cold has come to Sweden and the hysteric shopping for christmas presents has begun :)
For all of you that has friends that does not have a home automation hub at home you are always welcome to mention our Bluetooth version MOVE ;)
We have a question!
We would like to know if there are any interest from you to be able to pull sensor data from MOVEZ. Each MOVEZ could be able to report temperature and a sun value (sun value will be based upon the solar panel).
Please answer “YES” or “NO” in the comments below or send your answer to [email protected] and we will go through the answers and see if there is enough interest to make that a reality.
Status information
We can happily inform that we are taking steps forward with the development of MOVEZ. Like we have mentioned earlier we have had some issues with code and components which have caused delays. But the list of things needed to be corrected is getting smaller every day. One of the biggest challenges that we did not anticipate this time around is how many different certification regulations we need to conform to. There are a lot more documents to go through this time compare to what we needed go through with the first bluetooth MOVE.
We totally understand that you all want MOVEZ now! :blush: and we are pushing forward as fast as we can but unfortunately due to code and component problems we have not been able to get further in the certification process. That said and to give an estimate based upon the current situation we believe that we will be able to ship the first quarter of 2018.
If you have any questions please send them to [email protected]
Take care!
MOVEZ Team
[\quote]
Sent fra min SM-G930F via Tapatalk
Jeez...
Javel, sånn er det. Typisk crowdfunding. Det tar alltid lenger tid enn du tror. Eight Sleep var 1,5 år over første leveringsdato, totalt over 2 år.
Jeez...
Jepp, kjipe greier. Men greit at de gir oss en viss tidsindikasjon iallefall. Sier som jeg sa en gang tidligere, glad om jeg får de til sommeren :P
Det jeg har problemer med når sånt skjer, er at de ikke kan informere litt før. Dette er ikke en overraskelse for dem, de har sett dette komme lenge.
Helt enig, kommunikasjonen har vært horribel. Og ting som at de oppdaget i ettertid at de trengte flere sertifiseringer når de gikk for zwave kjøper jeg ikke. Så dumme kan de umulig være.
Første post i denne tråden er fra 4 januar. Der fikk vi vite at: For å forsikre meg at alle er kjent med kampanjen er produktet ikke klart enda, estimert levering er i Mars
Med andre ord, i løpet av et lite år har de blitt et helt år forsinket. Vi er altså nå fjernere fra leveringsdatoen enn det vi var for ca et år siden. Slå den. ☹️
1 time siden, DeVille skrev:
Null problem, dette er jo raskt.
Ref. alle andre kickstarter- eller indiegogo-kampanjer jeg har vært med på som er blitt populære.
Ikke imponert.
Dem burde fokusere på å få ferdig produktet fremfor å skrive mailer om været i sverige  og implementere sensorer vi iķke trenger.
  • 4 uker senere...
"We are still working on a few software related things but are still on track to release the product in the first quarter of 2018. We really hope no more unforeseen things will occur ..."
Ja, ja. ?
På 12/5/2017 den 23.34, Evelen skrev:
Ikke imponert.
enig, den siste oppdateringen var passe tåpelig. Men heldigvis ikke noe flere utsettelser om en skal se litt positivt på det.
Da kom det en ny oppdatering. Release date ser ut til å bli flyttet igjen og er nå 1. juni...
Monthly update
First of all we are sorry for the delayed update.
We have some good news regarding the standby power consumption of the system. Because the MOVEZ will spend most of their time in standby this is by far the most important part of the code to make the devices useful for everyone. That is why we have been working really hard trying to get the overall standby power consumption as low as possible and now we think we have reached an acceptable level. In our tests we have reached a standby time of about 6 weeks and if the solar panels get enough sunlight and the MOVEZ is used to protect from sun light the equation with the small solar panel works. If the MOVEZ is used to create privacy and no consideration is made to if it is sunny or not outside the bigger solar panel will be needed, in some cases where the window does not get direct sunlight at all a USB power adapter may even be needed. But luckily MOVEZ have all this option and we believe it will be possible to find ways to power it that suits all you great backers.
We have started the work of talking to the HUB providers that we have received requests to integrate with from all you backers. We are doing this to get the product integrated as good as possible so that you can get a really nice experience when you receive the product. It is still to early to say exactly how many we will be able to tightly integrate with, but we will do our best to cover all in the list we have.
The progress of production start has unfortunately been pushed forward a bit again due to certification issues that we are having. The release date will be pushed forward until the 1st of June. We are truly sorry for this and are working really hard to get the remaining pieces in place in order to start sending you all MOVEZ. We understand that this process can be a bit frustrating, but we can assure you that we are doing all we can to push forward, and we appreciate all great feedback we get. We believe that ultimately all pointers we get regarding the product development is great because it is making the product better.
With that said we like to know which HUB you all think is the most popular to integrate with?
Please post a comment regarding the system you like us to focus at.
That is all for now and take care!
  • Sad 1
Pokker, de sa ikke hvilket år ? men skulle tro de hadde råd til litt parallell jobbing, at noen tar sertifikat biten, mens noen tar hub integrasjon. Id lock 150 versjonen tok vel ikke så lang tid å få sertifisert heller?
Fordelen er at jeg kan utsette kjøpet av solfilmrullegardin enda litt til.
Ja virker som de roter mye, håper produktet virker når det endelig er på plass iallefall.
