Bruker i dag noen enkle men "stygge" templates, og noen gir meg nå feilmelding. Det er nok template syntax som er i endring og som da ikke lenger vil støttes i neste versjon. I tillegg kan nok template skrives på en mer ryddig måte? Noen som har anbefalinger?
Feilmelding:
Template warning: 'float' got invalid input '<template TemplateState
(<state sensor.kwh_kjellerbad_today=1.5; unit_of_measurement=kWh, friendly_name=Kwh Kjellerbad Today @ 2021-12-14T01:44:14.262309+01:00>)>'
when rendering template
'{%- if not (is_state("sensor.kwh_bad_1etg_today","unknown") or is_state("sensor.kwh_bad_2etg_today","unknown") or
is_state("sensor.kwh_kg_today","unknown") or is_state("sensor.kwh_ks_today","unknown") or is_state("sensor.kwh_n_today","unknown") or
is_state("sensor.kwh_stue_today","unknown") or is_state("sensor.kwh_a_today","unknown") or is_state("sensor.kwh_drivhus_today","unknown") or
is_state("sensor.kwh_s_today","unknown") or is_state("sensor.kwh_masterbedroom_today","unknown") or is_state("sensor.kwh_t_today","unknown") or
is_state("sensor.kwh_kjellerbad_today","unknown") or is_state("sensor.kwh_vr_today","unknown") )-%} {{ ((states.sensor.kwh_bad_1etg_today.state | float) +
(states.sensor.kwh_bad_2etg_today.state | float) + (states.sensor.kwh_kg_today.state | float) + (states.sensor.kwh_ks_today.state | float) +
(states.sensor.kwh_n_today.state | float) + (states.sensor.kwh_stue_today.state | float) + (states.sensor.kwh_a_today.state | float) +
(states.sensor.kwh_drivhus_today.state | float) + (states.sensor.kwh_s_today.state | float) + (states.sensor.kwh_masterbedroom_today.state | float) +
(states.sensor.kwh_t_today.state | float) + (states.sensor.kwh_kjellerbad_today | float) + (states.sensor.kwh_vr_today.state | float)) |default(0)|round }}
{%- endif -%}'
but no default was specified. Currently 'float' will return '0', however this template will fail to render in Home Assistant core 2022.1
Template Sensor:
      total_kwh_heating_today:
        value_template: '{%- if not (is_state("sensor.kwh_bad_1etg_today","unknown")
or is_state("sensor.kwh_kg_today","unknown")
or is_state("sensor.kwh_stue_today","unknown")
or is_state("sensor.kwh_s_today","unknown")
or is_state("sensor.kwh_kjellerbad_today","unknown")
{%- endif -%}'
        friendly_name: "Kwh Oppvarming i dag"
        unit_of_measurement: 'Kwh'
Denne, states.sensor.kwh_bad_2etg_today.state, måten å referere til en sensor på er noe du bør endre. Bruk states("sensor.kwh_bad_2etg_today") istedenfor.
Avoid using states.sensor.temperature.state, instead use states('sensor.temperature'). It is strongly advised to use the states(), is_state(), state_attr() and is_state_attr() as much as possible, to avoid errors and error message when the entity isn’t ready yet (e.g., during Home Assistant startup).
Templating - Home Assistant (home-assistant.io)
Alle |float bør endres til |float(0)
(eller bruk en mer fornuftig standardverdi enn null hvis mulig)
kjetilsn skrev (1 minutt siden):
da slipper jeg tydeligvis å bruke første delen av templaten som "sjekker" om state er "unknown"
Det slipper du, ja 👍
