20 minutter siden, ZoRaC skrev:
Jeg oppdaterte til BETA-versjonen av Z-wave-plugin, ser ut til å fungere igjen nå. :)
Tydeligvis ikke, feilene er borte fra loggen og én gang har magnetsensoren oppdatert i dag, men nå skjer det ikke noe igjen... :(
Ingen feil å se heller.
Jan-05 19:28:10   Z-Wave UZB1: ......................................................................
Jan-05 19:28:10   Z-Wave UZB1: .............................. FINISHED ..............................
Jan-05 19:28:10   Z-Wave UZB1 is the SIS for the network.
Jan-05 19:28:10   Z-Wave UZB1 There is a SUC/SIS in the network.
Jan-05 19:28:10   Z-Wave UZB1 Controller is static lib.
Jan-05 19:28:10   Z-Wave UZB1 Controller chip type is ZW050x.
Jan-05 19:28:10   Z-Wave Starting Z-Wave Polling for Network E6AF0F6C...
Jan-05 19:28:10   Z-Wave The interface's security support has been set.
Jan-05 19:28:10   Z-Wave UZB1: Z-Wave PC Controller is Type: Static Controller
Jan-05 19:28:10   Z-Wave UZB1: Z-Wave PC Controller Library Version: Z-Wave 4.05 (ZDK 6.51.6)
Jan-05 19:28:10   Z-Wave UZB1: Found 4 Z-Wave nodes in interface node ID 1 (UZB1)
Jan-05 19:28:10   Z-Wave UZB1: Z-Wave interface node ID: 1, Home ID: E6AF0F6C
Jan-05 19:28:10   Z-Wave UZB1: Z-Wave Serial API version: 5
Jan-05 19:28:10   Z-Wave UZB1: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
Jan-05 19:28:10   Z-Wave UZB1: Controller firmware version: 5.6
Jan-05 19:28:10   Z-Wave UZB1: Controller Manufacturer: PowerLynx, ID=0x1, Type=0x4
Jan-05 19:28:09   Z-Wave UZB1: Getting node information from controller...
Jan-05 19:28:09   Z-Wave UZB1: ----------------------------------------------------------------------
Jan-05 19:28:09   Z-Wave Initializing Z-Wave interface UZB1 (Z-Wave.me UZB) on /dev/ttyACM0
Jan-05 19:28:09   Z-Wave UZB1: ======================================================================
Endret av ZoRaC
Trekk ut UZB1'en fra maskinen og sett den inn igjen.
Det hjalp ikke, men jeg flyttet den fra en USB3 til en USB2-port, da ser det (foreløpig) bedre ut! :)
Det har jo kommet USB3-støtte i ESXi 6.5, så mulig den ikke helt likte det.
Ah.. ESXi og USB-forwarding har jeg ikke bare gode erfaringer med. Bruker heller USB-over-nettverk-løsninger. :)
Fortsatt ustabilt her...
Hvilken USB-over-nettverk bruker du? Jeg har et par RPi liggende - kan jeg bruke en av dem til å dele UZB1 over nett med?
Jeg tror det, men jeg kan ikke fortelle deg hvordan.
Jeg har tenkt å gjøre det med RFXtrx'er, men venter på at @iblis skal skrive en guide for det. Med RFXtrx kan du sette inn addressen til Pi'en rett i plugin'en.
Jeg bruker noen Belkin USB-over-Network bokser.
Tror jeg testet en aeotec z-stick på en slik Belkin-boks, og det gikk IKKE bra...:)
Ellers finnes det diverse guider for å sette opp en RPi til det formålet du nevner, jeg har gjort det og bruker en slik på hytta. Se f.eks. her:
Tøys og tull! Jeg har brukt det i mange år, både med Z-stick og med UZB1!
Fungerte helt fint. :)
Der var linken til RFXtrx. Takk! :)
Kræsja noe alvorlig på min HS PC når jeg prøvde, men det kan selvfølgelig være lokale forhold. :)
Det ser ut til å fungere! :)
RPi med Minibian og ser2net. UZB1 tilkoblet denne.
Z-wave controller satt opp som "Ethernet Interface".
PS:
Er det mulig å splitte denne tråden? Ble lite snakk om lys på bad etterhvert... :P
Seriøst?! Wow! Det var jo genialt, og veldig kjekt å vite! :D
Noen må skrive en step-by-step guide for meg (og andre!). ;)
Done!
Fulgte stort sett guiden som @mk1 black limited lenket til, med noen små tilpasninger. Jeg kan se om jeg får tid til å skrive litt mer detaljert rundt det en dag (når jeg har fått kjørt det stabilt en stund). :)
Herlig! :)
Legg det på et nivå under HomeSeer-skolen, så forstår jeg det nok. ;)
