Domoticz 3.5837, UZB1 1.4-2222-g83919e3-dirty
Har kjørt denne enheten lenge, fungert supert, men plutselig en dag sluttet den å virke, ingenting skjer.
Dvs, det må være forbindelse ettersom den stadig får info om temperatur. og dersom jeg setter "Heating Temp" eller "Cooling Temp" så responderer den på det.
Men jeg pleier alltid å bruke termostat mode til å sette på og av, det har fungert, men ikke nå lenger? virker ikke som enheten får signalet, for mobilkameraet oppfatter ingen IR-lys i det jeg trykker. Prøvd aktivere polling ute effekt.
Prøvd ekskludere og inkludere, viser forøvrig til logg under: (node31 før ekskludering, node32 etter ny inkludering)
2017-01-06 22:28:19.400 OpenZWave: Node Exclude command initiated...
2017-01-06 22:28:27.226 OpenZWave: Node Removed. HomeID: 4092244624, NodeID: 31 (0x1f)
2017-01-06 22:29:33.594 New sensors allowed for 5 minutes...
2017-01-06 22:29:33.594 OpenZWave: Node Include command initiated...
2017-01-06 22:30:00.106 OpenZWave: New Node added. HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 22:34:09.952 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 22:34:32.491 User: flemmingss initiated a Thermostat Mode command
2017-01-06 22:34:42.532 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 22:36:24.292 User: flemmingss initiated a Thermostat Mode command
2017-01-06 22:36:29.968 User: flemmingss initiated a Thermostat Mode command
2017-01-06 22:36:34.318 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 22:36:44.344 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 22:42:44.356 User: flemmingss initiated a Thermostat Mode command
2017-01-06 22:42:48.389 User: flemmingss initiated a Thermostat Mode command
2017-01-06 22:42:54.382 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 22:42:59.260 User: flemmingss initiated a Thermostat Mode command
2017-01-06 22:43:04.409 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 22:43:14.435 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 22:43:43.816 User: flemmingss initiated a Thermostat Mode command
2017-01-06 22:43:53.841 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 22:50:37.221 User: flemmingss initiated a Thermostat Mode command
2017-01-06 22:50:47.247 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 22:55:45.101 User: flemmingss initiated a Thermostat Fan Mode command
2017-01-06 22:55:49.583 User: flemmingss initiated a Thermostat Mode command
2017-01-06 22:55:54.174 User: flemmingss initiated a Thermostat Mode command
2017-01-06 22:55:55.127 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 22:55:57.627 User: flemmingss initiated a Thermostat Mode command
2017-01-06 22:56:05.153 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 22:56:15.178 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 22:56:25.204 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 23:10:17.300 User: flemmingss initiated a Thermostat Mode command
2017-01-06 23:10:23.467 User: flemmingss initiated a Thermostat Mode command
2017-01-06 23:10:27.327 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 23:10:37.353 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
2017-01-06 23:19:54.402 User: flemmingss initiated a Thermostat Mode command
2017-01-06 23:20:04.428 OpenZWave: Received timeout notification from HomeID: 4092244624, NodeID: 32 (0x20)
Log output
s,
2017-01-06 23:28:38.834 Always, End of queued log message dump
2017-01-06 23:34:48.730 Error, Node032, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-01-06 23:34:48.730 Always,
2017-01-06 23:34:48.730 Always, Dumping queued log messages
2017-01-06 23:34:48.730 Always, End of queued log message dump
Forslag?
