Viser innholdet med mest poeng fra 11. juni 2016 i alle områder
  1. Da var firmware versjon 42 lansert til RFLink Gateway R42: - New Device: Mi-Light/LimitlessLED/Applamp/Easybulb 2 way bridge functionality (2.4 Ghz, NRF24L01 with Milight wiring required) - New Device: Hama SD-UN5-RF switch set - New Device: Acurite Tower sensors - New Device: Pollin PFR-130 Temperature & Rain meter - New Device: Gaposa Blind/Shutter control (a.o. model QCT3S) - New Device: Byron BY35 / BY301 - Added: Command "echo" function to auto create devices without the need of remote controls - Added: Command "rtsrecclean 9" function to clean a single rolling code table entry - Added: Command to invert the ON/OFF handling of the Tristate protocol - Fixed: improved Atlantic MD-210R detection - Fixed: improved DKW2012 detection to cover variations of the signal - Fixed: Smarthome YC-4000B detection - Fixed: improved RTS packet detection to prevent false positives - Fixed: improved FA500 packet detection to prevent false positives - Fixed: Modified X10 security sensor packet detection - Fixed: Modified maximum humidity limit - Fixed: Improved signal ARC detection - Fixed: Chacon EMW200 detection - Fixed: Nexa WST-512 detection - Fixed: Oregon UV800 - Fixed: CM113 ID - Added: Support for another MiLight remote variant the download is available via our blog. http://www.nemcon.nl/blog2 Skal bli artig å få prøvd MiLight funksjonen, typisk at jeg kjøpte meg en wifi controller igår da ^^ Men nå har jeg heller ikke fått 2,4 ghz kit'et jeg bestilte fra Ebay så vi får se hva som kommer først.
  2. sudo apt-get install mono-complete gjorde susen! Takker, da kan man teste litt :-)
