Viser innholdet med mest poeng fra 22. des. 2016 i alle områder
  1. I dag har jeg sittet ned og gjort en del endringer på kjøkken-nettbrettet. Lagt inn mer relevante ting, samt endret ikoner og etter egen mening fått det ganske elegant. Med endringsbegrensingene i ImperiHome er jeg faktisk veldig fornøyd med resultatet. Alle ikoner er fra http://www.flaticon.com/
    4 poeng
  2. 30 stk batteridrevne julelys med RGBW-moduler styrt med IR fra en iTach. Siden det er IR, så må alle kommandoer sendes tre ganger for å være helt garantert at de kommer frem, men det fungerer utmerket med det forbeholdet. Det er denne pakken, men den finnes i andre pakker med flere eller færre lys. IR-koder for Global Cache for de som er interesserte: [OFF] sendir,1:1,1,36982,1,1,343,168,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,22,22,22,22,62,22,62,22,62,22,62,22,22,22,22,22,22,22,62,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,3698 [ON] sendir,1:1,1,37091,1,1,343,169,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,22,22,22,22,62,22,22,22,22,22,62,22,22,22,22,22,22,22,62,22,22,22,62,22,62,22,22,22,62,22,62,22,62,22,3709 [MODE] sendir,1:1,1,37091,1,1,343,169,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,22,22,22,22,62,22,22,22,62,22,62,22,22,22,22,22,22,22,62,22,22,22,62,22,22,22,22,22,62,22,62,22,62,22,3709 [LED] sendir,1:1,1,36982,1,1,343,168,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,22,22,62,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,3698 [5STD] sendir,1:1,1,36982,1,1,343,168,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,22,22,22,22,62,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,3698 [WHITE] sendir,1:1,1,37091,1,1,343,169,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,22,22,62,22,62,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,3709 [RED] sendir,1:1,1,36873,1,1,343,168,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,22,22,22,22,22,22,62,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,22,22,62,22,62,22,62,22,62,22,62,22,3687 [BLUE] sendir,1:1,1,36982,1,1,343,168,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,22,22,62,22,22,22,62,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,22,22,62,22,62,22,62,22,62,22,62,22,3698 [GREEN] sendir,1:1,1,36982,1,1,343,168,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,22,22,22,22,62,22,62,22,22,22,22,22,22,22,22,22,22,22,62,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,3698 [ORANGE] sendir,1:1,1,37091,1,1,343,169,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,22,22,62,22,62,22,62,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,3709 [YELLOW] sendir,1:1,1,37091,1,1,343,169,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,22,22,22,22,22,22,22,22,62,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,22,22,62,22,62,22,62,22,62,22,3709 [PURPLE] sendir,1:1,1,36982,1,1,343,168,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,62,22,22,22,62,22,22,22,22,22,62,22,22,22,22,22,22,22,22,22,22,22,62,22,62,22,22,22,62,22,62,22,62,22,62,22,3698
  3. @tonheim hvorfor ikke bruke RFXcom sin virtuelle termostat for styring?
  4. Jeg øker stadig antall z-wave enheter i huset. Dette inkluderer også plug-in brytere for å kunne kutte strømmen på diverse enheter for å senke brannfaren. Dette gjelder f.eks. vannkoker. I vårt nye tilbygg vurderer jeg nå å plassere en micro bryter eller dimmer innebygget i samtlige kontakter. Men etterhvert har jeg begynt å tenke: Kan alle disse z-wave enhetene som er koblet til strømnettet i huset utgjøre en økt brannfare over tid? Dimmere inne i stikkontakter vil jo sannsynligvis ikke få noe ettersyn, og vil kanskje gjennom årenes løp bli slitt og kanskje enkelte enheter vil utvikle mer varme? Selv når mine Aeotec pluginbrytere er skrudd av er de jo i aksjon, og jeg kan høre se svak høyfrekvent piping fra samtlige av dem. Jeg benytter bare kjente merker som Aeotec og Fibaro. Er det noen andre som har reflektert litt rundt dette? Noen som har noen synspunkter?
  5. BigBox 57 høy ring stender - Elnummer: 1223766 er ok. Std 71mm dyp veggboks går også bra. Det blir vel ikke så mange bokser at prisen er vesentlig. Husk, dette gjør du én gang, gjør det skikkelig!
  6. Fibaro er marginalt større, og kunne jeg valgt på nytt ville jeg valgt Fibaro. Får plass til to Qubino i standard veggboks, men det er ikke å anbefale Sent from my iPhone using Tapatalk
  7. Regner med noen legger ut en DIY her på en slik skjortekanon snart.
  8. Får vel ikke prisen for årets design, men virker. Sent fra min SM-G935F via Tapatalk
  9. Hei! Mulig jeg er litt smådum her, men jeg har funnet ut hvordan jeg legger inn kontakter/dimmere, og temperatur-måler, men er det noen måte jeg kan legge inn vanlige Nexa brytere også? Det er tilsvarende som Input device, altså som temp-måler ikke sant? Legger man den inn, og så trykke på knappen for å registrere den? Edit: Fant ut av det, det var så enkelt som jeg trodde. Jeg måtte bare trosse regn og vind for å løpe ut i garasjen og hente en bryter
  10. " Rådet om 20mm rør var også veldig bra å få med seg og om du skal ha 3 eller flere tjenester bør det altså være 2 stk 20mm rør " Herlig! ? Kjekt med lesestoff fra slike tilstelninger på hjemmeautomasjon.no
  11. ... men det er her det skjer.
