Viser innholdet med mest poeng fra 31. okt. 2017 i alle områder
  1. Från FB-gruppen "Svenska Hemautomatiseringsgruppen" (i ett mail från IKEA): We at IKEA would like to inform you about a change to our TRÅDFRI Gateway. We are very happy to see your interest in our gateway and have seen that you are using the CoAP interface. We consider the CoAP interface as our internal interface not developed for third party usage and therefore we do not offer any technical support for this usage. However that does not mean that we want to hinder your work in any way. There are some security improvements in a soon coming update that we would like to inform you about since it will break your implementation. Technically the improvement is that the TRÅDFRI Gateway will start using DTLS Identities which you will need to handle in your application. Please use the Following string to connect to the TRÅDFRI Gateway and create a new DTLS Identity. coap-client -m post -u "Client_identity" -k "SECURITY_CODE" -e '{"9090":"IDENTITY"}' "coaps://IP_ADDRESS:5684/15011/9063" SECURITY_CODE is what is labelled on the Gateway label, IDENTITY is any string that is representing the connection. You will then get back a PRE_SHARED_KEY that can be use in all traffic after that. coap-client -m get -u "IDENTITY" -k "PRE_SHARED_KEY" "coaps://IP_ADDRESS:5684/15001" We also would like to request that the SECURITY_CODE that is printed on the gateway is never stored permanently in your application.
  2. (Fra Facebook) Hjemmeautomasjon i "gamle dager". Jeg er ikke så gammel, men denne videoen, og fyrens entusiasme over X10, får meg til å føle meg gammel...
  3. Jeg forstår regelverket slik at hvis belastningen ikke kan overstige hva bryteren er merket med, typisk taklys i boligrom, da kan den monteres fast på 16A kurs. En 10A bryter kan da altså monteres fast for å styre taklys selv om kursen er 16A. Hvis det er et uttak (stikkontakt) hvor man ikke kan forutsi last, da skal utstyr som monteres fast kunne ta hele lasten på kursen. Altså, en bryter som er merket med 10A kan ikke monteres fast på 16A kurs. Det må da monteres en bryter som er beregnet for 16A. En hvilken som helst (godkjent) veggplugg kan gjerne settes i et stikk med 16A sikringer, men da er det brukerens plikt å passe på at lasten ikke overstiger det veggpluggen er merket for.
  4. Liker godt ting man kan lage med Arduino/ESP8266, så vært artig å sett litt hva andre har laget, utenom det vanlige. Kanskje man kan få noen idéer ? Har jo et par prosjekter jeg kunne tatt med evt, kanskje mulig å koble de opp til testhuset ditt, det kjører HS bla.? Er det noe dimbart tilkoplet der?
  5. Hvorfor ikke? Det er jo hvor mye enheten selv tåler. Wall Plug har samme beskrivelse, men det er jo lov å bruke den på 16A-kurser. Det er bare ikke en god idé å belaste den mer enn 2500W...
  6. Flytter emnet jeg, siden vi har både en kategori for "HomeSeer" og til og med for "Scripts".
  7. Hvis noen har mulighet for å ta med en rfxtrx433e så vil jeg gjerne få testet om den finner noe mot lekkasjestopperen min: http://www.oberge.no/webshop/products/flowstop-tradlos-34-med-1-aktuatorventil-433 Dette er en av de mest solgte her til lands, så hadde vært veldig kjekt i så fall.
  8. Jeg handler inn litt ELKO utstyr for å teste med Raspbee løsningen... Så kan vi vise resultatet på Smarthustreffet
  9. Jeg har en IKEA RGB i utelyset ved døra, som skal lyse orange på tirsdag. Når det ringer på, endres den til knall rød i 10 sekunder, samtidig som denne latteren spilles av på en høyttaler over døra. I vinduet i 2. etg på begge sider av huset, så spilles denne av mot et laken:
  10. Fikk 3 stillegående og energi effektive pcer sist uke, brukes nå til mining av en type bitcoin(verium) og til oppvarming av hjemmekontor(blir relativt varme pga 100% cpu bruk). Så jeg tjener nå penger på oppvarmingen Bruker temperatursensor og strømpris til å utløse av/på av pcene ved hjelp av Wake On Lan,Home Assistant og script. Har rablet ned en liten howto på http://kjetiliot.blogspot.no/2017/10/a-money-making-smart-heater.html
  11. Dette burde kanskje være godt nok bevis på at det funker: http://etne.ro4r.no:4999/ui/ (Klokka nederst ligger 2t bak pga at den er UTM, og den tas fra pakken som kommer hver time)
