Viser innholdet med mest poeng fra 11. jan. 2018 i alle områder
6 poeng
PCB ENC28J60 Ethernet Module for Arduino TTL to RS485 Module for Arduino (Works with Official Arduino Boards) CH340G Serial Port Debugger USB to TTL Converter for Arduino Pro Mini Sensor Shield v5.0 Expansion Board for Arduino - Deep Blue OPEN-SMART ESP-12 ESP8266 Serial Wi-Fi Wireless Module for Arduino ESP-07 ESP8266 Serial Wi-Fi Wireless Transceiver Module for Arduino Produino LM393 Soil Moisture Sensor/Soil Detection Module for Arduino Gold-Plated Pin Header Kit for Arduino Expansion Board - Black + Gold 400-Hole Mini Breadboard + Power Supply Module + 65 Jump Wires Kit MB102 Breadboard Power Supply Module for Arduino Original 3.5" LCD TFT Touch Screen Display for Raspberry Pi 2 / Raspberry Pi 3 Model B Board + Acrylic Case + Stylus white 2.8" TFT LCD Touch Screen LCD Shield Kit w/ TF card UNO R3 for Arduino Experimental Platform for Raspberry Pi 2 Model B / B+ / Arduino UNO R3 ESP8266 ESP-12E Wi-Fi Development Board Module Acrylic Bottom Plate Case Fixed Shell for Arduino UNO R3 UNO R3 Board Module + Ethernet Shield W5100 Module for Arduino - Blue Wireless Control V03 Shield Module for Arduino (Works with Official Arduino Boards) ESP8266 ESP-12F Wi-Fi UNO Development Board Module Usable with Arduino IDE Built-in CH340G Driver Multifunctional Fundamental Learning Expansion Board Kit for Arduino UNO R3 Micro USB Socket ATmega328P Board for Arduino - Blue + Black Geekworm ESP8266 NodeMCU LUA ESP-12E Wi-Fi Development Board + ESP8266 NoteMcu Base Board IoT Kit Improved UNO R3 ATMEGA328P Board + Ethernet Shield W5100 for Arduino GPRS A6 Module Wireless Extension Module GSM GPRS Board w/ Antenna Geeetech 9V 1A Power Adapter for Arduino - Black (EU Plug) LCD Keypad Shield for Arduino Duemilanove & LCD 1602 I2C / IIC LCD 1602 Display Module for Arduino, Raspberry Pi, AVR, ARM OPEN-SMART New I2C / IIC LCD 2004 Blue Display Module for Arduino1 poeng
Samme Steve har laget SDJ-health som kan brukes på z-wave enheter i hvert fall https://forums.homeseer.com/forumdisplay.php?f=15471 poeng
HA har den absolutt beste prisen ja. Pass på at prisene på intin.no kan vise eks. mva. for eksempel om du ser siden fra utlandet (eller utenlandsk IP adresse). Pris ut januar på forhåndssalg er 4290,- fra oss. Deretter blir den 4395,- for lås og 525,- for Z-Wave modul1 poeng
Jeg tror ikke det er batteriene sin feil. Det samme skjedde meg med det samme jeg satte opp låsen, det vil si at meg tok det faktisk to uker. Jeg fikk oppdatert firmware fra en test versjon og til den de leverer nå (4,05). Verifisert at den har mange koblinger mot GW (Neighbors). Satt polling til 12 timer, det påvirker ikke oppdatering av status på låsen. Etter det har jeg ikke byttet batterier, det er nesten et år siden. Jeg har i tillegg lagt inn støtte for en del funksjoner som ikke automatisk kommer opp:1 poeng
Jeg tok å bestille en sånn OSRAM plug så kan jeg også få testet om den kjører sammen med IKEA / deCONZ1 poeng
Kan rapportere at jeg har fått Roomba 896 til å fungere med plugin (BLRoombaWifi) mot HS. Plugin er skrevet for Roomba 980, men virket litt overraskende også mot 896. Maskinen var på salg til 5000, salget er slutt nå men dukker vel opp igjen. Har ikke prøvd andre modeller, men huset har ikke vært så støvfritt før!1 poeng
Hei igjen! Da har jeg fått til ett tilbud fra intin. Hjemmeautomasjon får sin egen rabattkode hvor vi får lås for 3890,- og Z-wave modul for 450,-, porto er gratis ?? Så, sleng meg en PM om du ønsker rabatt koden, evt om du ønsker en godt brukt Id-lock v1 da min ryker til fordel for dette tilbudet PS, låsene sendes direkte til deg og ikke via meg. PS2, det er ett begrenset tilgang til disse. Så om vi tipper over første bestilling så må en påvente noe ventetid før en får låsen. Etter hva jeg forstår varer dette tilbudet for oss HA medlemmer ut Januar!1 poeng
Sjekket pris på intin siden nå og både ID Lock 150 og Z-wave modulen ligger lavere enn prisen du har fått. Er det et gammelt tilbud?0 poeng
