Viser innholdet med mest poeng fra 17. feb. 2018 i Innlegg
  1. NodeMCU er egentlig morsommere, da kan man havne ned på 50-lappen i utstyr kanskje. Har imidlertid aldri prøvd en NodeMCU, så dette var kjappere for meg å få i gang ? It's a Unix system, I know this! Ser gjerne shoppingliste og kode for NodeMCU! Mitt koblingsskjema er herfra: http://www.uugear.com/portfolio/using-light-sensor-module-with-raspberry-pi/ Kjøpte en LM393 fra denne karen på FINN: https://www.finn.no/bap/forsale/ad.html?finnkode=72376538 Python-kode vedlagt under. Jeg programmerer vanligvis ikke i Python, men how hard can it be? import sys,time import RPi.GPIO as GPIO import paho.mqtt.client as mqtt import paho.mqtt.publish as publish # Variables pulses_per_kwh = 1000 # GPIO setup GPIO.setmode(GPIO.BCM) GPIO.setup(4, GPIO.IN, pull_up_down=GPIO.PUD_UP) # MQTT Broker = "10.0.42.101" Broker_port = 1883 sub_topic = "godlia/meter" pub_topic = "godlia/kw" # when connecting to mqtt do this; def on_connect(client, userdata, flags, rc): print("MQTT connected with result code "+str(rc)) client.subscribe(sub_topic) # when receiving a mqtt message do this; def on_message(client, userdata, msg): message = str(msg.payload) # Future functionality, maybe to control reporting frequency print(msg.topic+" "+message) def on_publish(mosq, obj, mid): print("mid: " + str(mid)) client = mqtt.Client() client.on_connect = on_connect client.on_message = on_message client.connect(Broker, Broker_port, 60) client.loop_start() prevtime = time.time() prevkw = -20 while True: # wait for a rising edge (optional timeout is in milliseconds) channel = GPIO.wait_for_edge(4, GPIO.RISING) if channel is None: print('Timeout occurred') else: nowtime = time.time() diff = nowtime - prevtime prevtime = nowtime kw = 3600 / (diff * pulses_per_kwh) print("{} {}kW".format(round(diff,4), round(kw,2) )) if kw < (prevkw + 10): # If there is more than a 10kW jump, don't send the value # This smooths out most errors in measurement data = '{"kw": '+ str(kw) +'}' client.publish(pub_topic, str(data)) prevkw = kw
  2. Har satt opp DIY strømmåling i sikringsskapet. En LM393 lyssensor står over den blinkende LEDen på strømmåleren. Den blinker 1000ggr pr kWh, så da er det en smal sak å regne ut kW akkurat nå basert på tiden mellom blinkene. Sensoren er plugget inn i en Raspberry Pi 3, med et Python-script som beregner kW og pusher dette ut via MQTT til Mosquitto-brokeren på hoved-RPi-en (som kjører HomeSeer) Display er veldig enkelt foreløpig, en tablet med eget HTML/CSS-interface kobler seg til MQTT-brokeren og lytter på strømmålerens kanal. Det oppdateres ca. hvert 2. sekund. Planen er å lage et litt mer fancy interface, kanskje med en speedometer-style klassisk strømmåler rundt tallene, og en graf som viser forbruk over tid. Vurderer å dytte data inn i emonCMS for dette. Har ikke satt den opp til å dytte data inn i HomeSeer ennå, men det burde være enkelt med MQTT-plugin der, eller kanskje det er bedre at HomeSeer leser fra emonCMS. Når det blir effektbasert prising kan jeg benytte dette til å automatisk skru av gulvvarmen når forbruket i huset blir for høyt, typisk når man lager mat etc. Har også en plan om å gjøre det litt vakrere i sikringsskapet ? Har bestilt en Raspberry Pi Zero W for å få ned størrelsen og vurderer å løsrive selve dioden fra LM393-kortet, så den kan monteres inne i en gummiring e.l. litt mer diskret over den blinkende LEDen.
  3. Vi snakker mye om automasjon her på forumet, og sammen er vi blitt veldig flinke. Jeg lærer noe nytt nesten hver dag, og det synes jeg er gøy! ... men som de sier: "We work hard, we play hard". Så av og til må det være lov med litt off topic. Jeg begynner med litt uhemmet selvskryt. Jeg la et bilde på Reddit der jeg streamer (verdens absolutt beste spill) Red Dead Redemption fra Xbox One hjemme over 4G til båten da vi var på båtferie, og det var jo festlig å se at det bildet ble populært. Faktisk så populært at jeg ble kontaktet av Surface-teamet som ville legge det på Twitter, som de selvfølgelig fikk lov til. ... ikke akkurat direkte relatert til hjemmeautomasjon, men fremdeles godt innenfor "because I can!"-mentaliteten.
  4. Kjøp heller skikkelig. Danfoss f.eks. Du finner det på elfadistelec:) tror neppe den ventilen er godkjent for det trykket du har i rørene.
  5. Jeg endte opp med å koble asus og 4g ruteren sammen trådløst. Endret apn på modemet og det fungerer godt med ddns :-) Sent from my ONE A2001 using Tapatalk
  6. Jeg har delt min på en annen del av forumet:
  7. Fant ut at det enkleste for min del (uten scripting) var en NodeMCU med ESPEasy-firmware, konfigurert med "P003 - Generic - Pulse counter". Koblet den opp med en vanlig LDR og en 10k motstand. Rapporterer blink via MQTT til Homeseer som igjen beregner momentanforbruket(W) for de siste 10s. Rapporterer også til Domoticz via MQTT som gir litt mer total beregning av kWh, både dagens og historikk. Ikke fått disse dataene over til HS enda, men mulig HS kan ordne dette selv med et script eller lignende for dere som er flinkere på sånt. ?
  8. Jeg detekterer blinkene med en nodemcu i utleidedelen min hvor jeg har privat undermåler. Denne rapporterer via json til homeseer. Kan legge ut deleliste og kode hvis det er interesse..
  9. Jeg tror jeg vet årsaken. Det er lagt frem krav om at data skal gjøres tilgjengelig for sluttbruker. Det som skjer er at nett selskapene ønsker å tjene penger på dette. Jeg har hatt kontakt med tredjeparts selskaper som jobber med løsninger for HAN porten som skal gi sluttbrukerne tilgang til sine data gjennom en skyløsning. Planen er at forbrukerne skal kjøpe denne tjenesten. For at de skal kunne sikre at sånne som oss finner andre løsninger med "gratis" tilgang er jo egentlig ikke ønskelig, derfor kryptering. Det er egentlig ingen grunn til å kryptere disse dataene ut fra et personvern hensyn, fordi måleren står i din egen leilighet. Det er ikke noen forskjell på kravet til sikkerhet for HAN grensesnittet versa en blinkende lysdiode. De leverer begge samme data med samme krav til sikkerhet og den er ivaretatt ved at grensesnittet ikke er tilgjengelig for andre enn deg. Hvis det skal komme inn noe krav til kryptering for å sikre personvernet vil det i tilfelle komme på enheter som kopler seg på HAN porten og sender disse dataene inn i en skyløsning, ikke på selve HAN porten.
  10. Oppgradert sikringsskapet fra til Dette sparer jeg 100 kr i året på på forsikringen...
  11. Da tror jeg du må gjøre litt annerledes, IDlock-løsningen vil neppe bli godkjent. Det du trenger er å styre det elektriske sluttstykket som sikkert er der allerede. Det skal bare ha spenning, så man må finne ut hvilken spenning som trengs eller bytte det ut med et man kjenner spenningen til. Så er det bare å styre strømmen, kan gjøres på samme måte som over.
  12. Det du spør etter er veldig spennende, men du kommer nok ikke til et ferdig dekket bord, selv om det ikke er så langt unna. Nye IDlock kan styres med Z-wave, og den kan åpnes/lukkes fra stort sett hvilken som helst Z-wave-gateway. Mange av disse kan styres med enkle HTTP GET-kommandoer, enten direkte eller via skyen. Hvis dere selv står for håndtering av medlemmer, brukernavn/koder og tilhørende app, så er den fysiske delen (å faktisk låse opp døra) relativt enkelt. Jeg vil foreslå også en magnetsensor som kan brukes til å låse døra automatisk når den blir lukket. Brann/rømming er i utgangspunktet ikke noe problem med IDlock (eller tilsvarende låser). De lar seg åpne fra innsiden.
  13. Laget kode for innbruddsmodus, blinker med alle lys i huset, og blinker med rødt på alle fargelys hvis bevegelsessensorer trigges når husalarmen er på (venter 1 min slik at man skal ha sjanse til å skru av alarm og for at OpenHAB skal få bekreftet fra SectorAlarm at alarm er avskrudd). Samt sende pushover til telefon. Blinking varer i 10 minutter, 2 sek venting mellom av/på, det føles litt hardt for gamle dimmere hvis de skal dimme endeløst til jeg får skrudd av manuelt. Prøvde meg en gang å spørre SectorAlarm om jeg kunne få systemet til å vite hvis det skjer innbrudd, men fikk ikke annen respons enn at "vi sender spørsmålet videre til teknisk". Trolig ikke noe vits i å ha noe lydavspilling - SectorAlarm sin alarmsentral skal allerede hyle.
