Viser innholdet med mest poeng fra 10. jan. 2019 i Innlegg
  1. Jeg har bestilt min første smarte... ... wait for it ... ...KAFFEKOPP! ??☕
  2. Så blir det en oppgradering av nettverket og brannmuren. Jeg har hatt Gbit hele veien i dag også, samt EdgeRouter POE, men nå er det et step opp Utfordringen jeg har nå er at Lyse nekter å bytte ut den fordømte HET-3012 boksen med en skikkelig fiber-terminering som jeg kan putte rett i SFP-modulen på USG.
  3. Etter 1. januar i år skal alle ha tilgang til en HAN-port og alle nettselskaper skal åpne den på forespørsel. Bare ta kontakt med Agder Energi, så burde det ordne seg.
  4. Leker litt i hstouch om dagen. Trengte litt oppfriskning.
  5. Klipper inn dette, Her finnes noe grunnlag for hvordan man kan styre forbruk etter pris,. Når den tid kommer... Electricity prices steering tellstick... by PetriK » Fri Nov 10, 2017 8:16 pm Found this nice software nordpool-ifttt by samuel rinnetmäki that sends messages to ifttt depending on nordpool prices. Did some finetuning for it like finding the cheapest and most expensive hours in a day (initially the software only worked with fixed prices which is nice but not really suitable to control hot water heater or EV charing). Basically you can set how many expensive and how many cheap hours you want to have in a day and the software controls thee rest. The old limits like 40c and 10c low are there still too. You can also limit how many consequent hours can be expensive or cheap e.g. to avoid a situation where house gets cold. Currently the messages are sent to IFTTT which is then linked with telldus but I will rewrite the code to use local tellstick api just in case the internet live.telldus.com is down when have a bit more time. It runs on node.js (v8.9 is needed) so you can have it on pc, linux, apple or almost any device. I installed mine on Synology NAS. Dev environment I use is Atom which runs node as part of the coding desktop making development extremely easy. Code is found here: https://github.com/PetriKarjalainen/nordpool-ifttt/tree/PetriK NPM installation packages is found here: https://www.npmjs.com/package/petrikarjalainen-nordpool-ifttt In case youre interested in co-implementing tellstick native api just drop me a line petrik (a) tikkari.net Here is console log for todays prices and what IFTTT events are created:[TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option) /root/.pm2/logs/index-out-0.log last 15 lines: 0|index | Running at (UTC) 2017-11-10T19:18:13.817Z 0|index | CET Expensive hours: 8,17,16,13 0|index | CET Cheap hours: 1,2,23,0 0|index | Scheduling: Friday 4:00 26.65 nordpool-price-normal 0|index | Scheduling: Friday 9:00 38.27 nordpool-price-high 0|index | Scheduling: Friday 10:00 32.1 nordpool-price-normal 0|index | Scheduling: Friday 14:00 36.9 nordpool-price-high 0|index | Scheduling: Friday 15:00 35.63 nordpool-price-normal 0|index | Scheduling: Friday 17:00 37.17 nordpool-price-high 0|index | Scheduling: Friday 19:00 36.52 nordpool-price-normal 0|index | Scheduling: Saturday 0:00 26.06 nordpool-price-low
  6. Hei, Jeg er er også hos Agder Energi Nett, med Kamstrup måler. Jeg kontaktet de i mars i fjor - da var det ennå ikke klart for å åpne. Jeg sendte en oppfølging i mai og fikk følgende svar: Jeg returnerte skjemaet og fikk kort tid etter tilsendt i posten modulen med RJ45-kontakt (plugges inn øverst på måleren etter at du har fjernet et plombert deksel). Veldig ryddig og greit. Så tok det et halvt år til før jeg laget elektronikk for å lese måleren... ? Men det har gått stabilt nå siden starten av desember. Agder Energi Nett Kundesenter E-post: kundesenter.nett@ae.no | Telefon: 38 60 72 72
  7. Nei, det tviler jeg veldig sterkt på. Det vil i så fall være en fullstendig idiotisk strategi, de kan ikke trenere det i det uendelige. Og min Aidon-måler fra Lyse gir jo informasjon. Bare ikke så ofte som NVE sier den skal.
  8. Det var den jeg mente. Der logger du jo hva du vil til en fil.
  9. Innstillinger finner du sammen med innstilliger for andre plugins. altså under fanen "plug-ins" i homeseer. Der har du et eget meny punkt for "LSoftVerisure"
  10. Dessverre, men søk på "project box" på aliexpress, så finner du.
  11. ... men lokk dem gjerne hit. Det er så mye lettere å søke på forum enn Facebook.
  12. Akkurat plass nok til dette, det svarte innerdekselet går på etterpå (stikker såvidt ut) og også det hvite til slutt.
  13. Denne websida er verdt en titt for snømåling! http://voksenlia.net/met/sno.php
  14. Det tviler jeg på, det er ikke bare HS som sliter innimellom. https://www.facebook.com/groups/smarthusnorge/permalink/2040258802755522/ @bjornepappa, sjekk developer.tibber.com. Får du data der (dvs. fra Pulse, se første post) så skal plugin'en også fungere (og da burde det holde med 1) "Restart Listener" eller 2) en omstart av plugin'en). Får du timeout så er det Tibber som gjør noe.
  15. Folk må seriøst slutte å referere til design på årstall NN når de tydeligvis ikke husker hvordan årstall NN så ut...
  16. Mulig du allerede har funnet en løsning. Jeg skal gjøre det samme som deg. Jeg tenker å kjøre poe fra skap frem til punkt. Såfremt du ikke skal trekke over 70-80meter med ethernet så tror jeg ikke spenningsfall er ett reelt problem. Boks tror jeg ikke er noe stress altså, mange som dropper bokser i dag på led-downlights også, mest brukt for å holde isolasjonen unna Når det er sagt tror jeg kanskje det finnes bokser som er av en slags gummi man kan smette inn... Tenk på hvor mye jall halogenbelysning folk hadde i takene sine før, uten bokser
  17. En oppdatering. Har nå utviklet en modul for styring av disse wifi varmegjennvinnings enhetene(Bluberg Vento Expert Wifi, Vents Twinfresh Expert Wifi, Flexit Roomie Wifi) via MQTT protokollen. MQTT(Message Queing Telemetry Transmission) er en lettvekt industri standard protokoll som støttes av de fleste automasjonsystemer på markedet idag. Modulen kjører jeg på en Raspberry Pi og den kan styre en vifte eller et cluster av vifter satt opp i master slave modus. Hvis man ønsker å styre flere vifter/cluster så kan man kjøre flere instanser av modulen på en eller flere controllere(pi,windows,Mac eller linux). Det administreres lett ved å benytte Pm2(prosess manager) for linux. Dette opplegget muliggjør at man kan kontrollere alle viftene i en etage eller seksjon av bygningen ved hjelp av en enkelt kommando. Da er enkeltromsviftene plutelig blitt transformert til et fullverdig balansert ventilasjonsystem uten de ulempene disse har. Har nå testet dette systemet og funnet ut at det kjører på hvilken som helst datamaskin med pyton 2 eller 3. Det være seg Windows, linux, Mac eller andre. Mqtt protokollen er virkelig effektiv, og det er kontant repons. Ved f.eks. brann i bygningen kan man med en enkelt kommando slå av alle viftene. Ta kontakt hvis interesse. Legger ved cfg og doc fila. mqtt2fan-doc.txt
  18. Det er din lykkedag i dag @Moskus! Det har vi faktisk fått i form av en eminent oppskrift fra herr Per Erik Nordbø i BKK, som har gått opp hele løypa, og tom. lastet opp hele raspbian-imaget for Rpi man trenger!
  19. Siden målet er å ha en enhet som ikke trenger noen PSU, kun trekker strøm fra M-BUS-en, er Zigbee et greit alternativ. Jeg har sett litt kjapt på mulighetene, og Texas sin CC2530 virker som en kandidat ved første øyekast. http://processors.wiki.ti.com/index.php/Tutorial_on_the_Examples Det finnes flere ferdige brett med denne (The Easy Way (TM)) https://www.aliexpress.com/item/CC2530-Zigbee-UART-Wireless-Core-Board-Development-Board-CC2530F256-Serial-Port-Wireless-Module-24MHz/32767470382.html Eller denne med forsterker, hvis man har måleren lengre vekk: https://www.aliexpress.com/item/ZigBee-Wireless-Module-CC2530-CC2591-PA-Module/1831284083.html Så da gjenstår det å se om man kan parse dataene på CC2530, men med de små mengdene det er snakk om, tror jeg det bør være overkommelig. Deretter må de sendes på Zigbee-protokoll, og her er det nok litt research som må til for å få det opp å gå. Det enkleste kan være å "kopiere" en implementasjon av en HAN-leser som allerede bruker Zigbee.
  20. NodeMCU, er veldig bra egnet. Man må selvfølgelig laste inn egnet programvare på den, men det er jo ikke slik at alle må finne opp kruttet på nytt her. Vi finner en eller flere implementasjoner som fungerer og så deler vi. Det kommer i post 2 eller 3 som er reservert. Så slipper vi at de som kommer hit senere må lese seg gjennom hundrevis av innlegg for å finne det de trenger for å komme opp på 1-2-3, The Easy Way (TM) ?
  21. Dette skjedde først for to uker siden, men da regnet jeg med det hadde sammenheng med mine Fibaro RGBW-problemer, og tenkte ikke mer over det, for RGBW-problemet ble løst. Men for et par netter siden skjedde det igjen! Vi bråvåknet av at rullegardinet til yngste jenta var i ferd med å gå opp av seg selv, midt på natten ca. kl. 03:00. Flere lys var skrudd på, helt tilfeldig! "Nei, nå er systemet fullstendig ute og sykler!" var første tanke som slo meg. Jeg sprang ned på kjøkkenet for å kikke på den store skjermen, og der kunne jeg se at et og et lys ble skrudd på med noen sekunders intervall! Dette var snodig! Helt til jeg tok på meg brillene... Da så jeg en liten flue spankulere oppover skjermen. Da den gikk over en "knapp" skrudde den dermed på det tilhørende lyset. Jeg ble helt fascinert, og stod og studerte flua. Den gikk lenger og lenger opp over skjermen og kom inn på bildet for 1. etasje. Der snudde den og gikk nedover til den møtte en "slider", og dermed dimmet den lyset på kjøkkenet der jeg stod. Det var et hint om at det er på tide å få tilbake logikken som skrur av skjermen om natten, ja...
  22. Dette er min personlige erfaring med å investere i solpaneler, og siden det er snakk om så mye penger synes jeg at jeg burde informere litt åpent om ting som har skjedd her. Begynte å planlegge solpaneler i fjor vår, og Otovo var svært raske ut for å selge solpaneler, som virket til å være en grei pris, og virket som å være en større seriøs bedrift som har tingene på stell, og gikk derfor for tilbudet de ga meg. Planleggingen gikk veldig fort, for fort, og ingen kommentarer, eller problemer ble påpekt. Lovet gull og grønne skoger med så og så mye produksjon. I midten av monteringen begynte tingene å komme, og ble opplyst om at solforholdene var oppdaget å ikke være optimale, og pipene ga mye skygge - da skulle de selge meg optimizere og ble satt litt ut av at jeg måtte legge ut mer for å få produksjonen - de monterte også 4 ekstra paneler, og prisen ble rundt 50.000 høyere, en totalregning på underkant av 200.000 I etterkant har jeg aldri hatt nær produksjon til hva som var originalt lovet, selv om jeg kjøpte flere paneler, inverterne som var levert er 2x 6kw, noe som ikke kan teoretisk ta full solpanelstyrke, men bare bygget for praktisk verdi (selger solpaneler som skal kunne gi 13-14kw, men montere 12kw invertere virker litt rart) - har vært mye tull med AP-punktene, bruk av kinesiske merker som spytter ut grid info til kinesiske nettsider mv. Fikk heldigvis nye wifi sticks, men enda synes jeg ikke disse inverterne skriker kvalitet (Solis) Så kom en regning på ca 160.000 og ble betalt med en gang, all informasjon hos Otovo viste alt var betalt, og jeg regnet med de hadde tatt til vettet og trukket fra noe grunnet feil i planlegging. Flere måneder etterpå klaget de på jeg ikke hadde betalt, og ga beskjed joda, regning var fullbetalt, og notert på sidene deres som fullbetalt, men Otovo hadde rotet det til slik regning ikke ble komplett, og midt i klaging og prøve å få et svar på mangel på planlegging etc så sendte de regningen til inkasso, et svært uetisk og truende steg når en er midt i en klagerunde med firmaet. Betalte regningen da jeg var midt i kreftoperasjon og ikke orket å krangle mer med dem. Det jeg reagerte på nå er de reklamerer på offentlig media, og når spørsmålet om snø kommer opp, sier Otovo offentlig problemer som takvinkling, ikkeoptimale forhold etc vil alt bli opplyst om - jeg har ikke optimal takvinkling for snø som kan skli av etc, og ble aldri informert om dette. Derfor står jeg nå med et solanlegg som kostet 200.000, er totalt ubrukelig hvis NOE snø kommer fra takvinkling er alt for lav til at snø faller av, har skyggeproblemer rundt alle pipene og må ettermontere optimzere til en etterkostnad, og har to invertere som ikke kan ta av en optimal produksjon. Ønsker ikke henge ut et firma, men mener et stort firma burde være seriøse og ikke først selge inn noe som en pakkepris, begynne midt i jobben og å legge på penger og ikke dimensjonere inverterne for opimal produksjon - jeg mener hvis jeg betaler for teoretisk sum burde de levere invertere til å ta den summen. Grunnen til jeg skriver her er jeg har klaget i flere måneder til Otovo, og ingen av punktene over er svart på fra Otovo eller ønske å rette opp i - de har fått pengene sine nå og da er det 100% tyst fra dem.
    0 poeng
  23. 0 poeng
