Viser innholdet med mest poeng fra 22. mars 2019 i Innlegg
  1. For min del, det mest verdifylle med produktet er "User manual" for dimmer enheten. En får ganske detaljert beskrivelse av feilsøking prosess. Kan absolutt anbefales for feilsøking med alle eksisterende dimmere fra alle produsenter. Troubleshooting 230V Dimmer problems. 230V Phase Cutting dimmers can (by their nature of operation) cause problems with some types of Light fixtures. The 230V Dimmer Standalone unit supports Standard Bulbs, Halogen and (most) Dimmable LED type lights, but may not always operate correctly with the default settings. The defaults have been chosen to provide the widest possible range of compatibility, but they may also cause some unwanted effects. The most common problems are: - Buzzing Noise from Dimmer or Light Fixture This is caused by the Dimmer Mode being Leading Edge, and is usually not very prominent. Try changing the dimmer mode to Trailing Edge Mode by setting Configuration Parameter XX to Value Y, to solve the problem. Turn the Lights OFF and ON again for the configuration to take effect! WARNING! Some light fixtures operate poorly in Trailing Edge mode. If you experience general instability (not only at Low Dimmer levels) or a loss of usable Dimming range, it’s recommended to switch back to Leading Edge mode. For some light fixtures, the buzzing noise is simply not possible to fix! - Light is unstable at low Dimmer levels This can be fixed by increasing the MIN level via Configuration Parameter XX. Start by increasing the MIN level by steps of 5, until the Lights stops flickering at the Minimum Dimmer level. Then try adjusting the level down 1 step at a time, until the Flickering or instability returns. Finally increase the MIN level by 1 to get stable Operation. WARNING! Make sure that the Light will turn ON when the Level is at its minimum. Dial the Dimmer Level down to the Minimum, and turn the Light OFF. Then turn it back ON and verify that the light turns ON. If the Light does not turn back ON, or becomes unstable, increase the Cold Start Minimum Level configuration up until the Dimmer starts consistently at the Minimum level. - Light Dimming Range is very Narrow If the range from MIN level to MAX level is very low (some times not even noticeable) or only change in the lower part of the dimming range, the culprit is usually one of the following: o The Light fixture does not operate well in Trailing Edge Mode. Switch the mode back to Leading Edge (Configuration Parameter XX, value Y) and check if this solves the problem (Remember to turn Light OFF and ON to activate the change). Note that in some cases, buzzing from the Dimmer and/or Light Fixture is impossible to remove completely. o The MAX level is too high. Some Light Fixtures have no noticeable dimmer level change above MAX level 60-70 (in rare cases even lower), and the MAX level should be adjusted down accordingly. Please note that MIN and MAX level change DOES NOT affect the “resolution” of the dimming, only the maximum and minimum voltage output. The resolution is fixed to 99 steps regardless of MIN and MAX settings. o The MIN level is too high. Note that some Light fixtures will only dim significantly below a certain level, but may not start stably at that same level. Try adjusting the MIN level down, but make sure the light turns ON at the MIN level after being switched off. If the light does not turn ON at the lowest dim level, adjust the Cold Start Minimum level configuration up until it turns ON consistently. In some rare cases there is no way to improve the Dimming Range of the Light fixture due to this problem. NOTICE! It is very important to know that there are Light Fixtures on the market which claim to be “dimmable” which in reality is not (or does not perform very well). It is highly recommended that Light Fixtures intended for Dimming is acquired from Light Fixture professionals or professional Electrical equipment suppliers with experience with dimmable Light Fixtures. This includes Light Bulbs and replaceable LED Bulbs as well.
  2. De fleste har en USB-kontroller som f.eks UZB1 og den er som regel koblet til serveren man kjører HS3 på. I noen tilfeller må/ønsker man å ha denne et annet sted. F.eks pga USB-problemer på serveren, serveren står bortgjemt og man vil ha controlleren mer sentralt eller man vil ha muligheten til å enkelt ta med seg controlleren bort til dørlåsen for inkludering, i stedet for å slepe hele PCen bort til ytterdøra. Da kan "USB-over-nettverk" med en Raspberry Pi være løsningen! (denne løsningen skal også kunne brukes med f.eks RFXtrx433E og guiden er i stor grad basert på dette innlegget til @mk1 black limited, som igjen har hentet det fra Bert i RFXCOM) 1. Installere OS på Raspberry Pi Hvis du allerede har en fungerende RPi med OS, hopp til del 2! Du trenger en RPi og et minnekort for OSet. Jeg har valgt å kjøre dette på en egen RPi som ikke kjører noe som helst annet, rett og slett fordi jeg ikke vil at andre tjenester på den skal bruke opp ressursene, slite ut minnekortet eller på en eller annen måte "krasje" den. Det finnes mange OS å velge blant, jeg ville ha et minimalt OS, som bruker minst mulig ressurser og som krever minst mulig vedlikehold (desto mer software den kjører, desto flere potensielle sikkerhetshull dukker opp som krever patching). Valget falt på Minibian - en minimalistisk variant av det mest brukte OSet for RPi. a. Last ned Minibian, pakk ut tar.gz-filen til en tar-fil og pakk ut tar-filen så du får en img-fil (7-Zip kan pakke ut tar.gz) b. Bruk WIN32DiskImager (hvis du har Windows) til å legge img-filen på minnekortet, se guide her. c. Sett minnekortet i RPi'en og sett i nettverkskabel og strømkabel d. Du kan enten koble til skjerm/tastatur eller koble deg til den via SSH (PuTTy f.eks), finn IPen via DHCP-serveren din e. Logg på med root/raspberry (bytt passord ved å kjøre passwd) 2. Konfigurere USB-deling a. Du trenger noen programmer, kjør "apt-get update" og "apt-get upgrade" (det kan hende du må skrive "sudo" foran alle kommandoer, avhengig av ditt oppsett) b. Deretter kjører du "apt-get install raspi-config nano usbutils keyboard-configuration ser2net" c. Valgfritt: kjør "raspi-config" og gå igjennom innstillingene som f.eks hostname, tidssone, tastaturlayout, o.l d. Koble til UZB1 og følg oppskriften som @mk1 black limited har lagt ut her, men på punktet "nano /etc/ser2net.conf", legg til dette i tillegg: 10003:raw:0:/dev/ttyACM0:38400 8DATABITS NONE 1STOPBIT (UZB1 legger seg på "ACM0" i stedet for USB0) e. Gå inn på HomeSeer, plugins, Z-wave, controller management f. Sett opp Z-wave interfacet til å bruke "Ethernet interface", skriv inn IPen til RPi og port 10003 g. Start interfacet og se at det virker. Fremgangsmåten for RFXCOM er omtrent den samme.
  3. Dette er eit viktig og interessant tema. Sjølv tenker eg frå eit sikkerhetsperspektiv at ingenting bør vera tilgjengelig utanfor heimen. Men for bekvemmeligheten sin del er det veldig greit å ha det tilgjengelig. Som eit minimum må det vera passordbeskytta. Eg har ikkje bestemt meg for kor eg skal legge lista for min egen del. Eg vurderer å sette opp VPN på ruteren og koble telefonen mot den, slik at telefonen alltid er på innsida.
  4. Ja, OpenHAB er merkelig nok ikke utstyrt engang med basic authentication. Det er snodig! Alle OpenHAB-brukere bør lese denne:
  5. Hele is_state()-funksjonen sjekker jo hva som er state-komponenten til en entity. Derfor er det ikke riktig å skrive "<entity_id>.state" i if-setningen.
  6. Skriver det nå her siden det fortsatt dreier seg om øl ? Skulle ikke være noen som har laget en plugin for PLATO? Hadde jo vært helt perfekt og kunne styre temp i gjæring-skapet automatisk alt etter hvor langt i gjæringsforløpet man var kommet. If FG 1.014 then Cold Crash liksom
  7. Jeg fikk svar fra Thermo-Floor i dag om at ny FW for TRM2fx trolig vil komme rundt månedsskiftet, og de ber meg følge med på heatit.com :-)
  8. Jepp, har hatt dette kjørende et par år snart:
  9. OK, festlig at det finnes på HomeAss-forumet og ikke i Fibaro-manualen...
  10. Da har jeg fått laget en video som viser hva som skjer om noen taster feil kode. Tror ikke de forsøker seg på nytt etter dette ? Jeg bruker en teller i HS for å holde styr på antall forsøk og "LAPD" scene på Fibaro RGBW kontrolleren for LED lysene på 3. forsøk. Telleren nullstilles etter x antall minutter.
