Viser innholdet med mest poeng fra 15. april 2019 i alle områder
  1. Nei, du må laste ned og installere Python 2.7 for Windows: https://www.python.org/downloads/windows/ Scriptet kan du trigge fra et event, noe lignende som dette: Så først lager du deg en device med gyldig range 0-10000 (e.l.) (må være "controllable, ikke "status only"). Selve scriptet ("ginlong.py") blir vel da noe sånt: #!/usr/bin/python import urllib, urllib2, hashlib from xml.etree import ElementTree as ET #config username = '' #your portal username password = '' #your portal password baseURL = 'http://www.ginlongmonitoring.com:10000' #base url stationid = '' #station id, get this via the station python script # example: Working base urls: # http://www.ginlongmonitoring.com:10000/ # http://www.omnikportal.com:10000/ # http://log.trannergy.com:10000/ # http://www.solarmanpv.com:10000/ #domoticz settings hs_host = 'localhost' hs_port = '80' hs_url = 'JSON' hs_ActualPower = '1234' #refid of new device m = hashlib.md5() m.update(password) #building url requestURL = baseURL+'/serverapi/?method=Login&username='+username+'&password='+m.hexdigest()+'&key=apitest&client=iPhone' #login call root = ET.parse(urllib.urlopen(requestURL)).getroot() token = root.find('token').text print 'Logged In: '+username #info url infoURL = baseURL+'/serverapi/?method=Data&username='+username+'&stationid='+stationid+'&token='+token+'&key=apitest' print 'Getting Info... ' #login call infoRoot = ET.parse(urllib.urlopen(infoURL)).getroot() income = infoRoot.find('income') TodayIncome = income.find('TodayIncome').text ActualPower = income.find('ActualPower').text etoday = income.find('etoday').text etotal = income.find('etotal').text multiply='1000.0' etotal1000 = float(etotal) * float(multiply) TotalIncome = income.find('TotalIncome').text etotalstr=str(etotal1000) #logging values print 'TodayIncome: '+TodayIncome print 'ActualPower: '+ActualPower print 'etoday: '+etoday print 'etotal: '+etotal print 'etotal 1000: '+etotalstr #uploading values to HomeSeer url = ("http://" + hs_host + ":" + hs_port + "/" + hs_url+ "?request=controldevicebyvalue&ref=" + hs_ActualPower+ "&value=" + ActualPower) urllib.urlopen(url) stationid.py kjører du bare som det der for å finne "stationid".
  2. Ah, selvsagt! Jeg leste ikke så nøye at jeg tenkte over hvilke verdier som faktisk var brukt... ? for lite ☕ eller for mye ?!
  3. Ja, men ikke her. Range[0,3000] er det samme som "less than 3000". Range[4000,1000000++] er i prinsippet det samme som "greater than 4000".
  4. Nå har det visst kommet (beta) støtte for RTSP på kameraet denne tråden originalt handlet om: https://support.wyzecam.com/hc/en-us/articles/360026245231-Wyze-Cam-RTSP
  5. Termostat som du refererer til (Lev. nr: 014G0158) kan ikke brukes så lenge den bruker "lukket" protokoll. Den er kompatibel BARE med Danfoss Link system. Ellers Danfoss Link RS-Z utgaven ((Lev. nr: 014G0160) bruker standard Z-Wave kommunikasjon protokoll (kan brukes): https://www.tronika.no/no/zwave-klimastyring/829-temperatur-sensor-link-rs-z.html
