Viser innholdet med mest poeng fra 07. juli 2019 i Innlegg
  1. https://homeseer.com/support/newsletters/current-promo.htm
  2. Nop Alle commands kan sendes uten aktivitet, tror det er litt dårlig dokumentert, men alle commands står i harmony_harmony_hub.conf. Så skriver jeg dette i scripts.yaml: harmonyhub_tv_ok: alias: TV OK sequence: - service: remote.send_command data: command: OK device: 52818462 Og GUI-generert automations.yaml: - id: '1562496661150' alias: Klikk OK når TV er på trigger: - entity_id: binary_sensor.ping_finlux_tv_lan from: 'off' platform: state to: 'on' condition: [] action: - service: script.harmonyhub_tv_ok
  3. Tronika har fått inn et par dimmere med hjul til Zwave. Kommer i 2 utgaver der ene er tilpasset elko ramme. https://www.tronika.no/no/dimmer-zv2400tac-sl-b.html
  4. Kjøp deg en Pi 4. De kommer vel i butikkhyllene snart ?
  5. Og en liten test av innganger fra SP30, med Arduino UNO, 5V, og optocouplere. int FAN_LEVEL_1_PIN = 7; int FAN_LEVEL_2_PIN = 8; int HEATING_PIN = 9; int FAN_MIN_PIN = 10; int FAN_NORMAL_PIN = 11; int FAN_MAX_PIN = 12; int HEATING_LED_PIN = 13; void setup() { pinMode(FAN_LEVEL_1_PIN, INPUT_PULLUP); pinMode(FAN_LEVEL_2_PIN, INPUT_PULLUP); pinMode(HEATING_PIN, INPUT_PULLUP); pinMode(FAN_MIN_PIN, OUTPUT); pinMode(FAN_NORMAL_PIN, OUTPUT); pinMode(FAN_MAX_PIN, OUTPUT); pinMode(HEATING_LED_PIN, OUTPUT); } void loop() { int fanLevel1 = digitalRead(FAN_LEVEL_1_PIN); int fanLevel2 = digitalRead(FAN_LEVEL_2_PIN); int heating = digitalRead(HEATING_PIN); digitalWrite(FAN_MIN_PIN, fanLevel1 == 1 && fanLevel2 == 1 ? HIGH : LOW); digitalWrite(FAN_NORMAL_PIN, fanLevel1 == 0 ? HIGH : LOW); digitalWrite(FAN_MAX_PIN, fanLevel2 == 0 ? HIGH : LOW); digitalWrite(HEATING_LED_PIN, 1 - heating); delay(20); }
