  1. Moskus
    • Poeng
      6
  2. ZoRaC
    ZoRaC
    Crew
    • Poeng
      3
  3. Hillmar
    Hillmar
    • Poeng
  4. bjornepappa
    bjornepappa
    • Poeng
Viser innholdet med mest poeng fra 14. okt. 2019 i alle områder
  1. Small update if some are interested. I've got the new board built with a voltage supervisor and it works well. Once programmed, you simply plug it in and it powers up. Turn on of the ESP happens around 3.25V and it disables around 2.65V. I added a couple lines of code to wait for the vcc to reach 3.3V before booting up. At first I was confused by how much current the TSS521 consumes (~1.2ma on my inital build), then I read into the HAN protocol. Slaves are supposed to consume a fixed amount of current as they modulate their current to communicate with the master. Obviously with the buck on the input this design does not conform. Input currents on my design range from 0.5ma (TSS521 only, idle buck), to 7.5ma (when bucking from 24 to 3.3), and 15ma (when bucking from 12 to 3.3). This said, I'm not sure how critical the constant current draw is for this application. I've had such a system running on my han for the last several months without issue. However, I guess they could update the FW on the meter and it could develop problems. I'm slowly working on a method for solving this (current sense feedback into a amplifer to burn the extra current). If others have clever ideas here I'm all ears. This said it runs okay on my Aidon meter with 2.5second messages. I'm averaging ~5.5ma of current consumption from the HAN port. With the slower message speeds of the Kamstrup I think it will consume less. I'll need to put a voltage divider on the run pin of the buck controller so it only pulls power when at the 24V level. Is there still any interest of others for such a device?
  2. Aha! Den tenkte jeg ikke på Ser da også for meg at svigers trykker på den som galninger når de er på besøk for å slukke lyset. Kanskje jeg burde heller gå for en fibaroløsning uten HUE for å ha selve strømbryteren inntakt i kombinasjon med trådløse brytere rundt i rommet. Takker for svar Moskus!
  3. OK da, vi får vel bare hive oss rundt...
  4. Vaskemaskin, tørketrommel - og enda en oppvaskmaskin - klar for testing
  5. Jeg kan stille som tester med platetopp og ventilator, om det skulle være ønskelig.
  6. De har ikke tatt med alle instruksene... Kanskje du må deaktivere Z-way, som beskrevet i den originale tråden?
  7. Riktig. Den ene styrer da den «lokale» Fibaro dimmeren, den andre sender et signal trådløst til sentralen og/eller direkte til en annen Z-wave enhet. Om sentralen kan respondere på det signalet og styre en hue/ikea pære varierer fra sentral til sentral. Det er i hvertfall mulig i HomeSeer.
  8. Hehe, ja når du har sagt A så blir det fort mas om B
  9. Tips: Fibaro Dimmer 2 med doble brytere over alt. Bryter nr 2 kan da f.eks styre en ikea/hue pære i en lampe et annet sted i rommet (som er koblet til permanent strøm/støpsel). vi har det i flere rom, veldig praktisk.
  10. Nei. En impulsfjær vil skru på strømmen igjen til pærene hvis noen skulle trykke på bryterne. Du kan jo velge hvilken side av dekselet du fester fjæren, og da vil du jo velge den siden som gjør at bryteren alltid er på istedenfor at den alltid skal være av...
  11. En pulsfjær. Ellers ingen. Du skal ikke kombinere "smarte" brytere og "smarte" lyspærer, og det er jo heller ikke noen vits i å gjøre det. Teknisk sett er det mulig med en Fibaro Switch, hvis du bruker versjonen som faktisk har et relé, men da må jeg spørre: Hva er poenget?
  12. Nei, vent. Det kan være at det første også en en array... litt usikker på hvordan det løses, jeg må sjekke.
  13. Ja, det er poeng i butikken til HomeSeer fra tidligere kjøp.
  14. Så vart det ny oppvaskmaskin på oss! Om de skulle få til ein halvdårleg betaversjon av plugin så kan eg gjerne melde meg som forsøkskanin ?
  15. Har kjøpt oppgradering til HS4 som sikkert dei fleste andre her inne på HomeSeer-delen av forumet
