Viser innholdet med mest poeng fra 20. mars 2020 i alle områder
  1. Sub Main(ByVal parameters As Object) 'Moskus 2020 Dim devID As Integer = parameters.ToString Dim useHTMLtable As Boolean = True Dim url As String = "https://www.vg.no/spesial/2020/corona-viruset/data/norway-table-overview/" Dim source As String = "" Try Using client = New System.Net.WebClient Net.ServicePointManager.SecurityProtocol = Net.SecurityProtocolType.Tls12 client.Encoding = System.Text.Encoding.UTF8 source = client.DownloadString(url) End Using Catch ex As Exception hs.WriteLog("CoronaScript", "Net Feil: " & ex.Message) End Try If source = "" Then hs.WriteLog("CoronaScript", "Got no response from url: " & url) Exit Sub End If Dim json = Newtonsoft.Json.JsonConvert.DeserializeObject(Of Object)(source) Dim output As String = "" Try Dim confirmed As Integer = json("totals")("confirmed") If useHTMLtable Then output &= "<table border=0 cellspacing=0 cellpadding=0>" output &= "<tr><td><b>Totalt</b></td><td align='right'>" & json("totals")("confirmed") & "</td><td align='right'>" & json("totals")("dead") & "</td><td align='right'>" & json("totals")("recovered") & "</td></tr>" For i As Integer = 0 To json("cases").Count - 1 output &= "<tr><td>" & json("cases")(i)("name") & "</td><td align='right'>" & json("cases")(i)("confirmed") & "</td><td align='right'>" & json("cases")(i)("dead") & "</td><td align='right'>" & json("cases")(i)("recovered") & "</td></tr>" Next output &= "</table>" Else output &= "<b>Totalt: " & json("totals")("confirmed") & " / " & json("totals")("dead") & " / " & json("totals")("recovered") & "</b><br>" For i As Integer = 0 To json("cases").Count - 1 output &= "• " & json("cases")(i)("name") & ": " & json("cases")(i)("confirmed") & " / " & json("cases")(i)("dead") & " / " & json("cases")(i)("recovered") & "<br>" Next End If hs.SetDeviceString(devID, output, False) hs.SetDeviceValueByRef(devID, confirmed, True) Catch ex As Exception hs.WriteLog("CoronaScript", "Net Feil: " & ex.Message) End Try End Sub Trigger: Kjøres hvert 5. minutt Parameter: DeviceIDen til en virtuell device som skal holde verdien. Du kan endre variabelen "useHTMLtable" til False hvis du vil ha det i HStouch, for HStouch viser ikke pene HTML-tabeller... Oppdatert med data fra RapidAPI siden jeg ble lei av at VG er så dårlig på å oppdatere tallene sine: Sub Main(ByVal parameters As Object) 'Moskus 2020 Dim devID As Integer = parameters.ToString Dim url As String = "https://covid-193.p.rapidapi.com/statistics?country=Norway" Dim source As String = "" Try Using client = New System.Net.WebClient 'TLS1.2 and encoding (UTF8) Net.ServicePointManager.SecurityProtocol = Net.SecurityProtocolType.Tls12 client.Encoding = System.Text.Encoding.UTF8 'Headers client.Headers.Set("x-rapidapi-host", "covid-193.p.rapidapi.com") client.Headers.Set("x-rapidapi-key", "DIN_RAPIDAPI_KEY_HER") 'GET the url source = client.DownloadString(url) End Using Catch ex As Exception hs.WriteLog("CoronaScript", "Net Feil: " & ex.Message) End Try If source = "" Then hs.WriteLog("CoronaScript", "Got no response from url: " & url) Exit Sub End If Try Dim json = Newtonsoft.Json.JsonConvert.DeserializeObject(Of Object)(source) Dim confirmed As Integer = json("response")(0)("cases")("total") Dim output As String = "" output &= "<b>Aktive: " & json("response")(0)("cases")("active") & " (" & json("response")(0)("cases")("new") & ") " & "</b><br>" output &= "Totalt: " & json("response")(0)("cases")("total") & "<br>" output &= "Dødsfall: " & json("response")(0)("deaths")("total") & " (" & IIf(json("response")(0)("deaths")("new").ToString = "", "0", json("response")(0)("deaths")("new")) & ") " & "<br>" output &= "Testede: " & json("response")(0)("tests")("total") & "<br>" output &= "<i>Sist oppdatert: " & json("response")(0)("time") & "</i><br>" hs.SetDeviceString(devID, output, False) hs.SetDeviceValueByRef(devID, confirmed, True) Catch ex As Exception hs.WriteLog("CoronaScript Error", "Parsefeil: " & ex.Message) End Try End Sub Kjøres nå hver time, jeg vet ikke begrensningene hos RapidAPI.
  2. Jeg digger disse infrarøde terrassevarmerne! Gir skikkelig god varme uten at man på død og liv skal prøve å varme opp lufta rundt, for det er stort sett fåfengt når man er ute, IMHO. Vår er riktignok en sak man setter på bordet, men jeg er på andre hytter hvor de er fastmonterte, både avlange og runde. Jeg styrer den med et on/off utendørs relé med Z-wave. Finnes vel også i Zigbee-format? Her fra den gamle terrassen:
  3. Velg det du vil slette og trykk på sletteknappen på tastaturet
  4. Jeg holder på å kjøre opp Home Assistant i parallell nå, så jeg tok inn Pulse der, og eksponerer sensorer i Home Assistant via KNX ip:
