Viser innholdet med mest poeng fra 18. mars 2021 i alle områder
  1. Et script som sjekker når du får levert post. 1. Du trenger en referanse til Newtonsoft.Json i ScriptingReferences. 2. Du trenger en virtuell device uten knapper eller statuser. 3. Du trenger en konto hos MyBring, du kan opprette gratis her (du trenger ikke firmanavn): https://www.mybring.com/signup/register/user 4. En API-key som du finner på denne siden: https://www.mybring.com/useradmin/account/settings/api Kjør dette scriptet ved midnatt: Sub Main(ByVal params As Object) Dim devRef As Integer = DIN_DEVICEREF_HER Dim postnummer As Integer = DITT_POSTNUMMER_HER Dim mybring_email As String = "[email protected]" Dim mybring_key As String = "DIN_KEY_FRA_MYBRING" Dim url As String = "https://api.bring.com/address/api/no/postal-codes/" & postnummer & "/mailbox-delivery-dates" Dim source As String = "" Try Using client As New System.Net.WebClient Net.ServicePointManager.SecurityProtocol = Net.SecurityProtocolType.Tls12 client.Headers.Add("x-mybring-api-uid", mybring_email) client.Headers.Add("x-mybring-api-key", mybring_key) client.BaseAddress = url source = client.DownloadString(url) End Using Dim json As Object = Newtonsoft.Json.JsonConvert.DeserializeObject(Of Object)(source) Dim nestePost As String = json.item("delivery_dates").item(0).ToString Dim nestePostDato As Date = DateTime.Parse(nestePostDato) Dim dagerTilPost As Integer = nestePostDato.Date.Subtract(Now.Date).Days Dim output As String = "" For i As Integer = 0 To json("delivery_dates").Count - 1 Dim currentDate As Date = DateTime.Parse(json.item("delivery_dates").item(i)) output &= GetDateDescription(currentDate) & "<br>" Next hs.SetDeviceValueByRef(devRef, dagerTilPost, True) hs.SetDeviceString(devRef, output, False) Catch ex As Exception hs.SetDeviceValueByRef(devRef, -1, True) hs.SetDeviceString(devRef, "Feil: " & ex.Message, False) End Try End Sub Function GetDateDescription(ByVal nextDate As Date) Dim dagerTilPost As Integer = nextDate.Date.Subtract(Now.Date).Days If dagerTilPost = 0 Then Return "I dag" ElseIf dagerTilPost = 1 Then Return "I morgen" Else Return nextDate.ToString("dddd d. MMM") End If End Function Devicen vil da se slik ut: Device Value er antall dager til postleveranse. "0" betyr da at posten blir levert i dag, kan f.eks. brukes som trigger til noe. EDIT: Takk til @daniel.h.iversen som fant ut at Posten har oppdaget at 2020 var i fjor. 👍 EDIT2: Takk til @DeVille som fant ut at siste 1 skal erstattes med 9. EDIT3: Takk til @ZoRaC for sin oppdatering etter API-omleggingen hos Posten versjon som jeg bygget litt videre på.
  2. Enig! Var det jeg satte etter dagens erfaring 🙂
  3. Hadde også satt StDev til 10 øre i et lignende event, men det er nok ikke optimal måte å gjøre det på. Med dagens strømpriservar StDev verdien 9,5 øre, så pristoppen på bildet under ble ikke fanget opp.
  4. Ser ut til at de har endret på nettsidene sine. Dette er URL for Østlandet med Oslo nå: https://pollenkontroll.no/api/middleware/pollen/b5bb4856-2117-433d-bf18-53504ef2f101 (usikker på om den lenken er permanent eller om den endrer seg...) EDIT: Første post er oppdatert med info om nye URLer.
