Eksempel på en sesjon fra en RPi4 (men en hvilken som helst Linux-boks med nyere blåtann burde funke):
Finn BLE-dingser i nabolaget:
root@idefix:/tmp# hcitool lescan
LE Scan ...
F3:BA:84:AA:5A:48 Netti_01452ec784
F3:BA:84:AA:5A:48 (unknown)
58:93:D8:8C:7C:72 (unknown)
80:6F:B0:A9:EA:0F (unknown)
^C
Koble deg til en av de interessante. Her en Airthings Wave Mini:
root@idefix:/tmp# gatttool -I
[ ][LE]> connect 80:6F:B0:A9:EA:0F
Attempting to connect to 80:6F:B0:A9:EA:0F
Connection successful
Finn ut hvilke variable du kan lese/skrive ("characteristics" i BLE lingo):
[80:6F:B0:A9:EA:0F][LE]> characteristics
handle: 0x0002, char properties: 0x02, char value handle: 0x0003, uuid: 00002a00-0000-1000-8000-00805f9b34fb
handle: 0x0004, char properties: 0x02, char value handle: 0x0005, uuid: 00002a01-0000-1000-8000-00805f9b34fb
handle: 0x0006, char properties: 0x02, char value handle: 0x0007, uuid: 00002a04-0000-1000-8000-00805f9b34fb
handle: 0x0009, char properties: 0x20, char value handle: 0x000a, uuid: 00002a05-0000-1000-8000-00805f9b34fb
handle: 0x000d, char properties: 0x02, char value handle: 0x000e, uuid: b42e3b98-ade7-11e4-89d3-123b93f75cba
handle: 0x0011, char properties: 0x2c, char value handle: 0x0012, uuid: b42e3ef4-ade7-11e4-89d3-123b93f75cba
handle: 0x0015, char properties: 0x10, char value handle: 0x0016, uuid: b42e41c4-ade7-11e4-89d3-123b93f75cba
handle: 0x001a, char properties: 0x1c, char value handle: 0x001b, uuid: f000ffc1-0451-4000-b000-000000000000
handle: 0x001e, char properties: 0x1c, char value handle: 0x001f, uuid: f000ffc2-0451-4000-b000-000000000000
handle: 0x0022, char properties: 0x14, char value handle: 0x0023, uuid: f000ffc5-0451-4000-b000-000000000000
handle: 0x0027, char properties: 0x02, char value handle: 0x0028, uuid: 00002a23-0000-1000-8000-00805f9b34fb
handle: 0x0029, char properties: 0x02, char value handle: 0x002a, uuid: 00002a24-0000-1000-8000-00805f9b34fb
handle: 0x002b, char properties: 0x02, char value handle: 0x002c, uuid: 00002a25-0000-1000-8000-00805f9b34fb
handle: 0x002d, char properties: 0x02, char value handle: 0x002e, uuid: 00002a26-0000-1000-8000-00805f9b34fb
handle: 0x002f, char properties: 0x02, char value handle: 0x0030, uuid: 00002a27-0000-1000-8000-00805f9b34fb
handle: 0x0031, char properties: 0x02, char value handle: 0x0032, uuid: 00002a29-0000-1000-8000-00805f9b34fb
properties forteller hva som er read/write/notify. 0x02 er read. Blir fort ekstra nysgjerring på UUIDer som ikke startert med 0000. Listen overnfor to handles for hver characteristic. Vi er naturlig nok mest interessert i "value". Så f.eks:
[80:6F:B0:A9:EA:0F][LE]> char-read-hnd 0x000e
Characteristic value/descriptor: 00 00 14 6e 84 c7 57 0f 58 00 00 00 96 57 13 00 ff ff ff ff
Nå skal du jo jobbe litt for å få meningen ut av det der om ikke Airthings hadde publisert koden for å parse deler av det. Dette er 6 * le16 og 2 * le32 integer der vi har:
00 00 - ukjent
14 6e - temperaturen i centi-Kelvin (0x6e14/100 - 273,15 = 8,65 °C)
84 c7 - ukjent
57 0f - relativ luftfuktighet i % * 100 (0x0f57 / 100 = 39 %rH)
58 00 - VOC i ppm. (0x0058 = 88 ppm)
00 00 - ukjent
96 57 13 00 - ukjent
ff ff ff ff - ukjent
Ikke helt rett fram... Men om man tar en del samples sammen med dekodede verdier fra app eller display så er det ofte mulig å gjette ganske mye. Vet ikke hvor lang tid jeg hadde brukt på å innse at temperaturen var gitt i Kelvin, dog 🙂
Mange av de andre verdiene er bare ren ascii og dermed nokså lett å få noe fornuftig ut av. Som f.eks.
[80:6F:B0:A9:EA:0F][LE]> char-read-hnd 0x0032
Characteristic value/descriptor: 41 69 72 74 68 69 6e 67 73 20 41 53
Altså "Airthings AS". Når du er ferdig:
[80:6F:B0:A9:EA:0F][LE]> disconnect
(gatttool:979948): GLib-WARNING **: 16:32:19.458: Invalid file descriptor.
[80:6F:B0:A9:EA:0F][LE]> exit
