Viser innholdet med mest poeng fra 21. feb. 2022 i alle områder
  1. import datetime @time_trigger("cron(1 * * * *)") def update_saving_hours(): today_prices = state.getattr(sensor.nordpool_kwh_oslo_nok_3_00_025).get("today") hour_price_pairs = zip(range(24), today_prices) hour_price_pairs = sorted(hour_price_pairs, key=lambda v: v[1]) most_expensive_today = {} for i,(hour, price) in enumerate(hour_price_pairs): most_expensive_today[hour] = i tomorrow_prices = state.getattr(sensor.nordpool_kwh_oslo_nok_3_00_025).get("tomorrow") hour_price_pairs = zip(range(24), tomorrow_prices) hour_price_pairs = sorted(hour_price_pairs, key=lambda v: v[1]) most_expensive_tomorrow = {} for i,(hour, price) in enumerate(hour_price_pairs): most_expensive_tomorrow[hour] = i now = datetime.datetime.now() current_hour = now.hour log.info("Ran power saving script at %s" % now) for i in range(1,24): least_n_expensive = [{v: most_expensive_today[v] < i} for v in range(0,24)] least_n_expensive_tomorrow = [{v: most_expensive_tomorrow[v] < i} for v in range(0,24)] state.set("sensor.powersaving_%s_least_expensive" %i, most_expensive_today[current_hour] < i, new_attributes={"today_prices": today_prices, "today": least_n_expensive, "tomorrow_prices": tomorrow_prices, "tomorrow": least_n_expensive_tomorrow})#, new_attributes={"hours": }) n_most_expensive = [{v: most_expensive_today[v] > 23-i} for v in range(0,24)] n_most_expensive_tomorrow = [{v: most_expensive_tomorrow[v] > 23-i} for v in range(0,24)] state.set("sensor.powersaving_%s_most_expensive" %i, most_expensive_today[current_hour] > 23-i, new_attributes={"today_prices": today_prices, "today": n_most_expensive, "tomorrow_prices": tomorrow_prices, "tomorrow": n_most_expensive_tomorrow})#, new_attributes={"hours:": map(lambda v: most_expensive[current_hour] >= i, range(0,24))}) Jeg syntes det ble litt tungvindt med template for hver time så jeg skrev dette snippet som kan brukes med pyscript (som finnes under HACS). Denne lager 23 sensorer med billigste og dyreste time. Husk å bytt ut "nordpool_kwh_oslo_nok_3_00_025" med din sensor.
  2. Som oppdatering her så har jeg i dag vært i kontakt med Systemair og så etterpå med en service partner. Mitt anlegg har EC1 hovedkort og display, og med det så er det ikke støtte for Modbus. Jeg må ha minst EC2, per i dag kan man bytte til EC4 som er det nyeste. Dette gir meg ikke noe mer enn å få Modbus, men det hadde jo vært en stor fordel å fått fikset. Alt dette ble drevet av det faktum at klokka på mitt anlegg ustiller seg med minst 30 minutter per døgn, og det gjør dermed ukeprogram helt ubrukelig. Det finnes en oppdatert software, 1.29.00, som løser problemet med klokka, og det koster ca 1500,- for å få en teknisker til å komme her og flashe systemet. Skal jeg ha nytt hovedkort for å få Modbus så er prisen ca 3500,- for hovedkort+display (må også byttes), og ca 2 timer jobb med å bytte det. Totalt ca 6.000,-. Jeg er litt i tenkeboksen, men kjenner at jeg har lyst til å ha Modbus mulighet på plass slik at det kan styres mer intelligent med tanke på CO2, fukt på våtrom mm. Uansett, ville bare gi en oppdatering siden jeg vet det er flere i samme båt som meg når det gjelder VR400 her på denne tråden.
  3. Hvis det er noen som har litt diverse av komponenter liggende på lur, går det helt fint å bygge en HAN-TTL med et par motstander, en zenerdiode og en optokopler som absolutt minimum hvis man ikke skal drive alt med strøm fra porten. Det forutsetter at man er i stand til å tilpasse med det man finner i skuffen. Optokopleren i skjemaet er en SFH610A-3. Det er ingen annen grunn til det, enn at jeg har mange av dem. Denne har CTR, current transfer rate (kall det strømforsterkningsfaktor) på 100 - 200%. Andre optokoplere kan ha ulik benplassering, så sjekk med aktuelt datablad. Det kan muligens være en fordel å ikke bruke en optokopler som har veldig lav CTR. Kretsen i PDF-en er mer komplisert enn nødvendig, for den inneholder en brolikeretter så man ikke behøver å tenke på polariteten på signalet fra HAN, og en lysdiode som viser at det kommer data. Hvis man har tilgang til en variabel spenningskilde som går opp til 24V, kan man se at lysdioden slukker når spennnigen blir lav nok, og tenner igjen når spenningen øker litt igjen.. Hvis det er sånn passe midt mellom 15V og 24V bør det være OK. Jeg har bevisst valg å drive kretsen litt hardt med 15 mA, for det er nok å hente fra Aidon. Zenerdioder vil helst ha minst 5 mA for å regulere. Zenerdioder kan seriekoples for å få ønsket verdi, og en vanlig silisiumdiode i serie med den i lederetning gir ca. 0,6V ekstra spennigsfall. Røde, gule og grønne lysdioder har ca. 2V spennigsfall og blå og hvite ca. 3V. Det er mange måter å få til et passende spenningsfall for denne kretsen hvis man har litt liggende. Det er summen av spenningsfallene fra D1, R1, D2, D3 og lysdiodedelen i optokopleren som bestemmer skiftepunktet. En brolikeretter har dobbelt så stort spenningsfall som en enkelt diode. Denne kretsen har jeg brukt uten problemer i to år på min Aidonmåler. very_simple_han_to_ttl.norsk.pdf
  4. Har Z-water men ikke Temp2. Har sett på Temp2 selv men siden de ikke har gulv føler har det ikke blitt kjøpt enda. Har du mange Temp2 ? Og er det tilfeldig hvem som detter ut ? Om homey mister kontakten med Temp2, ville jeg sett på dekningen. Er det langt mellom eller om du har mye tykke vegger kan det lønne seg med noen repeterende noder. Batteri noder repeterer ikke. Jeg har får å få kontakt med Garasjen satt en veggplugg i den nærmeste stikkontakten mot garasjen og en tilsvarende i garasjen.
  5. @Venin Det er riktig, når du gjør et kall via API så vil enheten ikke lenger følge rom innstillingene og gå i "Uavhengig" modus Så da faller ukeplan/timere helt bort og dette var en bevist valg som ble gjort da REST API først ble tilgjengelig i sin tid. Det er ikke noe teknisk i veien for å gjøre det tilgjengelig, men dette blir nok implementert når vi har migrert til en ny plattform (under utvikling) en gang til høsten 2022 Da vil man også kunne hente ut statistikk data etc @Mathias Hei Matias, Det stemmer, jeg jobber hos Mill og er ansvarlig for alt Wi-Fi/Server/App/ API etc, har ikke hatt så mye med gen2 å gjøre da det var før min tid men hovedsakelig gen3. Feilen som du får, kommer den når du skal navngi enheten eller dukker den opp tidligere eller senere ? Jeg regner med at du har fått langt til enheten via Android telefonen nå ? Hvis ikke så send meg gjerne en PM så kan jeg sende deg en test app som kan loggføre hva som skjer, så kan vi lett finne ut hva som skjer. Men om du ikke har forsøkt det enda, prøv å avinstaller appen på IOS og restart telefonen og installer den inn på nytt...før du samme feil da ? Det var ren tilfeldig at jeg kom fant dette forumet og så at det var noe diskusjoner om Mill ovner så følger med og prøver å ta takk i problemer som blir diskutert Ønsker deg en fortsatt fin kveld
  6. @Mathias Hei, Generasjon 3 ovner fungere på følgende måte: 1: Ovnen scanner for alle nettverk den kan koble seg til, det inkludere nettverk som sender både 2.4ghz og 5ghz på samme SSID 2: Du velger deretter ønsket nettverk, om du velger et nettverk som sender 2.4ghz og 5ghz så vil den fint greie å koble seg mot 2.4ghz Fint om du deler med oss hva denne feilmeldingen sier, om du får en melding som sier "Failed please try again" så er det nok feil enten på app/server og ikke selve ovnen. Minner på at firmware som kommer på ovnen fra fabrikken ikke støtter WPA3, du må i så fall koble den opp mot en nettverk som støtter WP2 og du vil da automatisk få nyeste versjon som støtter WPA3. Ta gjerne kontakt med support så vil du få hjelp med dette @Kålgrim Hei, Vi skal legge ut en liten oppdatering slikt at du kan hente ut fuktighet via REST API, husker ikke om det allerede ligger på lokal REST API eller ikke men skal ta en titt. Det kommer en app til HA snart som er direkte fra oss her i Mill, der vil du kunne få mulighet til å styre alle funksjonene i gen3 Når en ekstern app tar kontroll over en Mill ovn så vil den automatisk gå i individuell kontroll, den vil ikke lenger følg timere eller ukeplan. Så om man ønsker timere eller ukeplan styring via HA så må det implementeres på HA siden, men vi skal se på det en gang i 2022 men det er ikke først prioritet. @Miriam Matter sertifisering starter i Mars ifølge Matter Alliance, så vi venter på start signalet fra dem. Vi kunne ha laget integrasjon mot Alexa, Google og Homekit, men det hadde blitt dobbelt arbeid og vi har begrensede ressurser dessverre. Det kommer fortløpende oppdateringer og forbedringer
  7. Å hente data maskinelt fra Nordpool er ikke i gråsonen - det er eksplisitt ikke tillatt. Jeg har laget litt kode som henter strømpris fra ENTSO-E og valutakurs fra exchangeratesapi.io , og publiserer dette bl.a. på et MQTT-endepunkt. Topics m.m. er dokumentert på https://gillhub.org/index.php?view=article&id=8&catid=21 .
  8. Kjempestolt av meg selv. Ved hjelp av Pyscript la jeg til attributter til sensor.regulator_energy_usage slik at jeg kan få kurvediagram. Pussig nok klarte jeg ikke å gjøre dette ved hjelp av Customize devices: https://www.home-assistant.io/docs/configuration/customizing-devices/. state.set("sensor.regulator_energy_usage", state_class="measurement", unit_of_measurement="%", friendly_name="Pådrag varme", device_class="power_factor")
  9. Mens du designer, er det i mellomtiden kanskje interessant å koble opp en av moduler - bare for å se hvordan det funker. Holder en knapp på ESP32 -alternativet. For meg virker WiFi'en bedre. Gadd ikke å designe/ skrive ut egen boks. Fikk klemt inn ESP32 + Mbus/TTL interface i en innbyggingsboks fra Kjell&Co (#89043). Enda bedre etter jeg satte på vinklet microUSB som tar en 270grader sving før den kommer ut av boksen ams2mqtt-1.1.pdf
  10. Jeg har flere Victor Smart-Kill både på hytten og hjemme. De er litt kostbare, men fungerer så bra at jeg kjøpte flere. Ikke noe søl, og det virker som de avliver raskt. Batteriet på mine varer ganske lenge når det ikke er noen fangst, da de bare rapporterer på wifi 1 gang i døgnet når ingenting har skjedd. Jeg har også laget en integrasjon (https://github.com/toreamun/victorsmartkill-homeassistant) for den til Home Assistant, og deretter laget en Home Assistant automasjon slik at min Sonos meg med tale når det er fangst...
  11. Har motatt ny evse, og gjør meg kjent med den på livestream nå
