Viser innholdet med mest poeng fra 20. mars 2022 i alle områder
  1. // ArduinoMqttClient - Version: Latest #include <ArduinoMqttClient.h> #include <WiFiNINA.h> #include <ArduinoMqttClient.h> ///////please enter your sensitive data in the Secret tab/arduino_secrets.h char ssid[] = SECRET_SSID; // your network SSID (name) char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP) int status = WL_IDLE_STATUS; // the Wifi radio's status // ---------------------------------------------------------------- // // Arduino Ultrasoninc Sensor HC-SR04 // Re-writed by Arbi Abdul Jabbaar // Using Arduino IDE 1.8.7 // Using HC-SR04 Module // Tested on 17 September 2019 // ---------------------------------------------------------------- // #define echoPin 2 // attach pin D2 Arduino to pin Echo of HC-SR04 #define trigPin 3 //attach pin D3 Arduino to pin Trig of HC-SR04 // defines variables long duration; // variable for the duration of sound wave travel int distance; // variable for the distance measurement WiFiClient wifiClient; MqttClient mqttClient(wifiClient); const char broker[] = "ip"; int port = port; const char topic[] = "avstand_i_garasje"; //const char topic2[] = "real_unique_topic_2"; //const char topic3[] = "real_unique_topic_3"; //set interval for sending messages (milliseconds) const long interval = 8000; unsigned long previousMillis = 0; int count = 0; void setup() { //Initialize serial and wait for port to open: // Serial.begin(9600); // while (!Serial); // attempt to connect to Wifi network: while (status != WL_CONNECTED) { Serial.print("Attempting to connect to network: "); Serial.println(ssid); // Connect to WPA/WPA2 network: status = WiFi.begin(ssid, pass); // wait 10 seconds for connection: delay(10000); } // you're connected now, so print out the data: Serial.println("You're connected to the network"); Serial.println("----------------------------------------"); printData(); Serial.println("----------------------------------------"); pinMode(trigPin, OUTPUT); // Sets the trigPin as an OUTPUT pinMode(echoPin, INPUT); // Sets the echoPin as an INPUT Serial.begin(9600); // // Serial Communication is starting with 9600 of baudrate speed Serial.println("Ultrasonic Sensor HC-SR04 Test"); // print some text in Serial Monitor Serial.println("with Arduino UNO R3"); Serial.print("Attempting to connect to the MQTT broker: "); Serial.println(broker); if (!mqttClient.connect(broker, port)) { Serial.print("MQTT connection failed! Error code = "); Serial.println(mqttClient.connectError()); while (1); } Serial.println("You're connected to the MQTT broker!"); Serial.println(); } void loop() { // check the network connection once every 10 seconds: while (status != WL_CONNECTED) { Serial.print("Attempting to connect to network: "); Serial.println(ssid); // Connect to WPA/WPA2 network: status = WiFi.begin(ssid, pass); delay(5000); if (!mqttClient.connected()) { Serial.println("mqtt client not connected"); // mqttClient.connect(broker, port); delay(5000); } delay(1000); printData(); Serial.println("----------------------------------------"); // wait 10 seconds for connection: delay(10000); // Clears the trigPin condition digitalWrite(trigPin, LOW); delayMicroseconds(2); // Sets the trigPin HIGH (ACTIVE) for 10 microseconds digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW); // Reads the echoPin, returns the sound wave travel time in microseconds duration = pulseIn(echoPin, HIGH); // Calculating the distance distance = duration * 0.034 / 2; // Speed of sound wave divided by 2 (go and back) // Displays the distance on the Serial Monitor Serial.print("Distance: "); Serial.print(distance); Serial.println(" cm"); } void printData() { /* Serial.println("Board Information:"); // print your board's IP address: IPAddress ip = WiFi.localIP(); Serial.print("IP Address: "); Serial.println(ip); Serial.println(); Serial.println("Network Information:"); Serial.print("SSID: "); Serial.println(WiFi.SSID()); // print the received signal strength: long rssi = WiFi.RSSI(); Serial.print("signal strength (RSSI):"); Serial.println(rssi); byte encryption = WiFi.encryptionType(); Serial.print("Encryption Type:"); Serial.println(encryption, HEX); Serial.println(); */ // call poll() regularly to allow the library to send MQTT keep alive which // avoids being disconnected by the broker mqttClient.poll(); unsigned long currentMillis = millis(); if (currentMillis - previousMillis >= interval) { // save the last time a message was sent previousMillis = currentMillis; //record random value from A0, A1 and A2 int Rvalue = (distance) ;//analogRead(A0); // int Rvalue2 = analogRead(A1); // int Rvalue3 = analogRead(A2); Serial.print("Sending message to topic: "); Serial.println(topic); Serial.println(Rvalue); mqttClient.beginMessage(topic); mqttClient.print(Rvalue); mqttClient.endMessage(); Serial.println(); } } /* void connectMQTTClientIfNeeded() { if (!mqttClient.connected()) { Serial.println("mqtt client not connected"); // mqttClient.connect(broker, port); } // // tasks.after(30000, connectMQTTClientIfNeeded); // after 30 seconds call connectMQTTClientIfNeeded() again } */ (Så skal jeg naturligvis rydde opp litt i koden når jeg har fått det til å virke som jeg vil. Får skylde på at jeg er litt i tåka etter Corona... Hei, kopierte linjene fra void setup(): while (status != WL_CONNECTED) { Serial.print("Attempting to connect to network: "); Serial.println(ssid); // Connect to WPA/WPA2 network: status = WiFi.begin(ssid, pass); delay(5000); ) if (!mqttClient.connected()) { Serial.println("mqtt client not connected"); // mqttClient.connect(broker, port); delay(5000); } Der sjekkes det om WiFi er koblet til og det blir ikke gjort noe i koden før du har tilkobling til WiFi. Det sjekkes så om MQTT er koblet og hvis det ikke er det så kobles det til igjen. Denne kan kanskje legges i en While loop slik at den ikke går videre før MQTT er koblet til igjen. Dette er ikke en god løsning hvis det skal styres noe lokalt feks uavhengig av WiFi og MQTT, men i dette tilfellet går det greit
  2. Jeg har løst det ved å bruke en annen virtuell enhet som jeg kaller for "x - forrige". I eventet så trigger jeg på den faktiske sensoren og sammenligner med "x - forrige". Og under actions bruker jeg Easy Trigger pluginen til å sette "x - forrige" til det sensoren nå er.
  3. Takk. Trenger flere merkebånd. Jeg liker denne printeren. Den kan printe så smått at det kan settes oppå bryteren på vippen.
  4. Og her har jeg en beta versjon av den plugin'en som støtter IR koder fra samme RM Tasker Bridge. Jeg har kalt den RMIR av mangel på noe annet. Denne er litt halvferdig da jeg ennå ikke har fått fjernet en bug som gjør at man må først starte plugin'en for å la den generere nødvendig devicer avhengig av det du har lagt inn av IR koder(til TV, prosjektor, Apple TV mm). Når dette er gjort må man restarte plugin'en og da skal den funke med kodene. Frykter at jeg har samme bug i mine to tidligere plugin'er. Men er på saken.. Prøv denne og kom med tilbakemeldinger. :-) Installasjonen er enkel. kopier fila inn i HS3 rota og refresh interface siden i HS3. Der kan du aktivisere plugin'en. Så går du inn i RMIR->config og taster inn ipadressen til din android bridge som kjører RM Tasker Plugin. Som med RMTasker så tar det litt tid å bygge opp devicene så vær tolmodig. Lykke til! HSPI_RMIR.exe
  5. Broadlink RM3, for å kunne styre TV med Alexa. Basert på følgende omtale på Amazon, må dette være midt i blinken for meg:
