  1. Katla
    Katla
    • Poeng
  2. SvErD
    SvErD
    • Poeng
  3. Moskus
    • Poeng
  4. PCI
    PCI
    • Poeng
Viser innholdet med mest poeng fra 23. sep. 2022 i alle områder
  1. 1 poeng
  2. Har nettopp oppgradert den ene pi'en til bullseye og fant ut at ser2net bruker .yaml som config fil nå. Så det er litt annerledes config oppsett. Erstatt nano /etc/ser2net.yaml med dette for å få UZB1 til å virke over nett: %YAML 1.1 --- default: name: kickolduser value: true default: name: speed value: 115200n81 connection: &con10003 accepter: tcp,10003 timeout: 120 enable: on connector: serialdev,/dev/ttyACM0 connection: er portnummer. Fant dette her: https://forums.homeseer.com/forum/lighting-primary-technology-plug-ins/lighting-primary-technology-discussion/z-wave-homeseer/1558575-stick7-on-a-rpi-with-ser2net#post1558582 Endre også nano /lib/systemd/system/ser2net.service med å legge til disse to linjene: After=network-online.target Wants=network-online.target [Unit] Description=Allows network connections to serial ports Documentation=man:ser2net(5) After=syslog.target network.target After=network-online.target Wants=network-online.target [Service] EnvironmentFile=-/etc/default/ser2net Type=forking ExecStart=/usr/sbin/ser2net -n -c /etc/ser2net/ser2net.yaml -P /run/ser2net.pid $OPTIONS Restart=always [Install] WantedBy=multi-user.target Alias=ser2net.service restart systemctl sudo systemctl daemon-reload Reboot Raspberrypi'en sudo reboot Etter oppstart, se om ser2net er oppe service ser2net status Skal være ingen feilmeldinger pi@raspberrypi:~ $ service ser2net status ● ser2net.service - Serial port to network proxy Loaded: loaded (/lib/systemd/system/ser2net.service; enabled; vendor preset: enabled) Active: active (running) since Fri 2022-09-23 11:15:16 CEST; 1min 8s ago Docs: man:ser2net(8) Main PID: 587 (ser2net) Tasks: 1 (limit: 1624) CPU: 38ms CGroup: /system.slice/ser2net.service └─587 /usr/sbin/ser2net -n -c /etc/ser2net.yaml -P /run/ser2net.pid Sep 23 11:15:16 raspberrypi systemd[1]: Starting Serial port to network proxy... Sep 23 11:15:16 raspberrypi systemd[1]: Started Serial port to network proxy. Fungerer på en raspberryPi3
  3. Pyscript: @state_trigger("sensor.nordpool_kwh_krsand_nok_3_095_025") def calculate_monthly_average_price(): date = sensor.nordpool_kwh_krsand_nok_3_095_025.raw_today[0]['start'].strftime('%Y-%m-%d') pyscript.electricity_monthly_average_price.stored_values[date] = [n['value'] for n in sensor.nordpool_kwh_krsand_nok_3_095_025.raw_today] avg_num, avg_den = 0, 0 for k,v in pyscript.electricity_monthly_average_price.stored_values.items(): avg_num += sum(v) avg_den += len(v) pyscript.electricity_monthly_average_price = round(avg_num / avg_den, 3) @time_trigger("cron(@monthly)") def reset_monthly_average_price(): pyscript.electricity_monthly_average_price.stored_values = {}
  4. Ikke helt i mål med min løsning men denne gir en snitt på ca 4,83 Da er nordpool sensoren lagt inn som input sensor i utility meter og avkrysset for delta values og monthly reset + denne koden: - platform: template sensors: stromstotte1: friendly_name: "stromstotte1" value_template: >- {% set antall_timer = now().day * 24 %} {% set timer_dag = 24 - now().hour %} {% set sum_timer = antall_timer - timer_dag %} {% set sum_timer2 = sum_timer + 1 %} {{ states('sensor.nordpool_snitt_utility') | float / sum_timer2 | float }}
  5. Fikk dusjhodet fra ali i dag. Har bare montert det og sett at det fungerer som anonnsert. Det virker litt billig i utførelsen, blir spennende å se om det varer...
  6. Da har jeg fått lagt inn en sensor som viser nivå på strømstøtte og som gjør det enkelt å følge med når strømmen er billig/gratis. Foreløpig så viser den ca. 15 øre feil i forhold til den offisielle fra kraftlaget så en liten feilsøking må nok til.
  7. Hei , Dette kortet var perfekt for meg. Fungerer perfekt. Tusen takk Jon Kristian 👍 Jeg er en skikkelig noob når det kommer til hjemme automasjon og Home assistant, så for meg var det litt vanskelig å skjønne hvordan dette skulle gjøres. Her er det jeg gjorde for å få det til å fungere, kanskje det kan hjelpe andre noobs som meg. 1. Gå hit: https://www.home-assistant.io/integrations/entur_public_transport , følg instrukser der for å legge inn Entur komponenten. ett lite tips for å finne stoppested ID er å gå til https://entur.no/avgangstavle søk etter stoppested, når det er funnet vil du se følgende url opp i adresselinjen for browseren din: https://entur.no/nearby-stop-place-detail?id=NSR:StopPlace:43161 det er altså NSR:StopPlace:***** du skal ha, en restart er sikkert på sin plass. 2. Under lovelace må du legge inn "resources" , klikk de tre prikkene til høyre å velg: " Edit dashboard" deretter klikker du nok en gang på de tre prikkene øverst til høyre å velger: " manage resources" deretter trykker du ADD RESOURCES nederst til høyre her legger du inn /local/entur-card.js?v=1 som URL Resource type setter du til Javascript Module. Husk at du må ha kopiert entur-card.js til config/www/ for at dette skal virke 3. Nå kan du legge inn kortet i lovelace (dashboard), trykk de berømte 3 prikkene igjen, og edit dashboard. trykk ADD CARD , let deg nedover til du finner kortet " Custom: Entur Card " klikk på det å legg inn følgende kode: type: custom:entur-card name: Rutetider show_clock: true show_next: true show_human: true show_extra_departures: true entities: - entity: sensor.atb_buss_kattemsenteret name: Kattemsenteret destination: Ranheim du må selvsagt tilpasse koden til ditt behov. Under - entity må du legge inn din sensor for stoppestedet, denne finner du under Developer Tools > STATES skal du finne din sensor, let deg ned på lista til du finner den, i mitt tilfelle er det sensor.atb_buss_kattemsenteret Da er det bare å lagre å du skal ha fått kortet under ditt dashboard. Lykke til !
