Viser innholdet med mest poeng fra 02. jan. 2023 i alle områder
  1. Sorry for writing in English, I'm using speech recognition to avoid having to type out long Norwegian sentences because of tendinitis. I have just started developing an integration for Homely integration for Home Assistant. My initial pull request is currently in review, and once this is accepted we should be able to poll the Homely API for various sensor data. I currently only support the following devices: Door sensor Smoke alarm Motion sensor mini These are the only devices I have, and the documentation is not very extensive. The keypad and siren does not seem to appear in the API. If you have additional devices, please consider downloading the helper package homelypy, run it, and provide me with the dump as described in the readme file. It should provide me with the necessary information to add support for any included device. Or better yet, create a pull request with the additional devices :-). Note that the API is currently only read-only, so we can only receive telemetry data from the devices, not control them. It is therefore not possible to e.g. arm the alarm or sound the siren. I do not know if or when they are planning to improve this, but hopefully soon 🤞 The method for getting things into Home Assistant is a bit slow, so I am only allowed to include a single platform in the first round. I have chosen sensors, so we get temperature, battery level, and signal strength for each device. The binary sensors have already been created (alarm state and battery low state), but I have to wait until the initial pull request is approved. On my list is also to create a separate device that represents the home alarm system to show the various states of arming and alarming. Depending on how slow things go I might get everything approved before the next release, maybe. Unfortunately I have not gotten the web socket interface to work correctly, yet, I have a support request waiting with the guys at Homely. Until I figure this out the integration only supports polling and is set up to do this every five minutes to avoid any throttling issues. My ongoing development branch is here: https://github.com/kolaf/core/tree/homely/homeassistant/components/homely And the associated pull request is here: https://github.com/home-assistant/core/pull/84951 If you have any comments, suggestions, or want to chip in, just let me know. And, of course, feel free to reply in Norwegian. Kolaf
  2. PowerControl er en plugin for HomeSeer som vil forenkle styring av strømforbruk etter strømpriser. Den lager automatisk ett konfigurerbart antall On/Off devicer i HS ved første gangs kjøring. Devicene slås Off og On ettersom prisene er høye eller lave. Det fins to typer devicer, Max og Min. En Max device går Off når prisen går over en grense, en Min device går On når prisen går under en grense. Du kan definere så mange slike devicer som du vil. En parameterfil definerer devicer og prisgrenser etc. Denne kan editeres fra web-grensesnitt. Disse devicene lager da eventer i HS som igjen kan styre fysiske devicer som varme, varmtvann osv. Du kan og definere hvor lenge en device kan være av- eller påslått, eller innenfor et gitt tidsrom. Grensesne kan settes som pris i øre, eller når pris går over eller under gjennomsnittspris. Uansett vil programmet finne de laveste prisene med de gitte kriterier, Du kan også knytte en device opp mot en eksisterende HS device ved hjelp av en Shadow device. I tillegg til ON/OFF kan denne også sende verdier til HS device, som feks termostat setpunkt. PowerControl kan lese effektforbruk ved hjelp av en AMS måler på HAN porten, og sende data til HS. Effektforbruk kan også hentes fra HS om det fins der feks, fra Tibber. Programmet kan redusere maks effektforbruk ved å slå devicer av for å holde forbruket under en bestemt grense pr time for å redusere nettleie. Forbruk og priser vises grafisk, og du kan også logge enkeltforbrukere og vise forbruket i diagram. Eksempler på bruk Du kan kombinere flere devicer i HS ved hjelp av eventer og lage en varmestyring som virker slik: - Sett dag og natt-temperatur i HS. Kombiner så dette med en PriceControl-devicer som: -Setter ned temperatur hvis strømmen blir ekstra dyr basert på en fast grense, eller høyere enn gjennomsnitt den dagen. - Setter opp temperaturen om strømprisen går under en fast grense, under strømstøtte grensen, eller under gjennomsnitt. - Slår av devicer om effektforbruk en time går over en grense. Les mer i Help dokumentet. PowerControl kan også lese effektforbruk ved hjelp av en AMS måler på HAN porten, og sende data til HS samt logges til fil. Dette er ingen skybasert løsning og den er leverandør-uavhengig. Priser hentes gratis fra ENTSO-E. Web status display Visning av priser og forbruk. Dynamisk oppdatering av Charts. Tekst nederst viser øyeblikkets strømpris, forbruk og total for timen. Oppdateres en gang i minuttet. Chart som viser pris og forbruk oppdateres en gang i timen. Kjekt å henge på veggen for å følge med. Konfigurerbare Devicer du kan knytte til events i HS. Her for å styre varmepumpe. Sette ned varme ved høy pris og sette opp varme ved ekstra lav pris. Logging av forbrukere vises grafisk Planlagt videre utvikling Direkte styring av varmepumper, panelovner etc. I dag kan man bruke Powercontrol til å styre en varmekilde som i eksemplet over. Det krever dog ganske mange events i HS når flere devicer skal kombineres. Alternativt kan du lage et script. Enklere er det å kombinere flere devicer i PowerCntrol, og så sende temperatursettpunkt, viftehastighet etc direkte til varmepumpe- eller panelovn-device i HS så slipper du å lage masse events som er vanskelig å endre. Temperatur settpunkt etc vil kunne redigeres i PowerControl web grensesnitt. Release V1.2.0.2 06.03.2023 Nytt Entsoe API Fikset bruk av default verdier om ikke priser blir hentet. Kan slå av prishenting helt ved å sette PriceArea blank Det holder å bytte exe fil om du allerede har PowerControl Release V1.3.0.0 25.03.2023 Bugfix: Feiler pgr av endring av antall priser fra Entsoe Grafikk: Plotter priser og forbruk. se: Grafikk Ny ini fil: PowerControlData.ini. Visning av Månedsmaks og gjennomsnitt av 3 høyste verdier - nettleie avgift. Lese forbruk fra HomeSeer - Tibber Release V2.0.0.0 Forbedret web brukergrensesnitt. Alle parametere du bruker ofte kan endres i web grensesnitt. Parametere lagres og du trenger ikke restarte. Devicer kan legges til og slettes. Beregninger av max og min events kan oppdateres uten restart. Dvs, lett å teste parametersetting. ToolTip hjelp på mange parametere. Grafikk. Total strømforbruk og pris vises grafisk. Logging av device forbruk med grafikk. Du kan sette opp logging av alle HomeSeer devicer, som varmeovner, varmtvann etc og logge dette. Resultatet vises grafisk og som HS devicer om ønskelig. Forenkler identifisering av store forbrukere og feil i automasjonsoppsett. Automatisk bytte til høyere månedsmaksgrense for forbruk. Går du over effektleddet en måned så settes neste maksgrense som limit. Ny max-device paramter OffAboveLimit. Går prisen over denne grensen i øre slås device helt av. Lesing av Euro kurs fra Norges Bank endret til JSON på grunn av endringer i webservice. Standardavvik til døgnpriser lagt til som device i HomeSeer. Kan brukes til å detektere flate priser. Lesing av forbruk fra AMS leser forbedret feilhåndtering Release V2.0.0.2 Det var en bug i V2.0 som gjorde at oppstart feilet om en parameter i ini filen PowerControlData.ini var blank. Du kan legge inn noen dummy data her, som feks DayConsumptionTimes=25.04.2023;13;14;19 DayHourConsumption=0,5;0,0;0,7 Eller laste ned V2.0.02 hvor dette er rettet. Les også kapitlet Minimumskonfigurasjon i det oppdaterte Help dokumentet om hva som minimum må kofiguerers for å få igang plugin. Release V3.0.0.0 For å forenkle oppsett av devicer er det laget forhåndsdefinerte device typer kalt Device Functions. Ved å velge en Function reduserer du parameterantallet. Du kan selv også definere og endre Device Functions. Ønsker du å bruke Device Functions for eksisterende devicer må du legge inn en parameter på hver device som definerer dens funksjon. Se under. Ny strømstøtte-modell av 2023 er lagt inn. Du må sannsynligvis endre noen av device parametere på grunn av dette. Priser med og uten strømstøtte vises. Forbedret lesning av effektforbruk fra HomeSeer/ Tibber. NB! Se manual om oppsett. Eventer er endret slik at også Max type plottes som rødt når de er ON. Ønsker du å beholde det gamle slik at de plottes som blå når de er OFF kan du endre dette i config fanen. Parameter PlotMaxAsRed = False i INI fil under [General] Mere Tooltip help er lagt til. Bytt filen PowerControlTooltip.ini i HomeSeer\Config Release V3.0.0.1 Det snek seg inn en liten bug som gjør at priser uten strømstøtte ikke blir flyttet over til neste dag etter midnatt. Dette har ingen praktisk betydning, for beregninger. 3.0.0.1 er releaset. Det holder å bytte exe fil hvis du oppdaterer fra 3.0.0.0 Release V3.0.0.2 06.04.2024 Bugfix: Tooltip help tekst for Device setup manglet. Bugfix: Strømstøtte priser blir feil når pris er under grense- 73 øre. Nytt: La til timespan for når Max priser-devicer er lov å slå av. Dvs, innenfor dette tidsrommet blir ikke device slått av uansett. (grunnet klage fra kona om kaldt kontor om morgenen) Dynamisk oppdatering av Charts. Tekst nederst som viser øyeblikkets strømpris, forbruk og total for timen. Oppdateres en gang i minuttet. Chart som viser pris og forbruk oppdateres en gang i timen. Kjekt å henge på veggen for å følge med. Ny parameter under Config- Chart & Log «Chart Font Size». Her kan du sette font på Chart for å lette lesing. Default= 12 NB. For detaljer om hvordan oppgradere les nederst i dokumentasjonen. HSPI_PowerControl V3.0.0.2.zip PowerControlHelp - V3.0.0.2.pdf
  3. Jeg har en bunke av dem styrt av HA via Wifi, litt klønete å sette opp lokalt pga uthenting av koden. Men har vært rimelig stabilt og greit for meg. Gikk denne veien for å få satt dem opp. Dette fungerer også på cleveri/nedis fra Kjell.com og Nedis fra Jula. Vær oppmerksom på at vanlige wifi rutere for hjemmebruk ikke liker så mye mer enn 30-40 enheter tilkoblet. Blir fort mye med lyspærer.....
