Mack1979
Alt skrevet av Mack1979
  1. Hi, I saw the error message here and focused on that. I do have a big debug message which has pulled loads of values back in what looks like JSON format. I can paste or IM you that if that's what's needed to debug? Thanks!
  2. Thanks for the plugin! I've managed to install OK for my Ecodan heat pump. The log says connected OK and response received. It is populating my name and address but then I get an error message and despite the huge debug log it isn't creating any other devices. 3/05/2024 09:52:34 Legacy-Plugin/Script MelcloudClimate-Error Error on InitIO: The given key was not present in the dictionary. 3/05/2024 09:52:34 Legacy-Plugin MelcloudClimate Info Could not connect to Melcloud to fetch devices: Microsoft.CSharp.RuntimeBinder.RuntimeBinderException: Cannot convert null to 'double' because it is a non-nullable value type at CallSite.Target(Closure , CallSite , Object ) at HSPI_MelcloudClimate.HSPI.CreateMelcloudDevice(Object device) at CallSite.Target(Closure , CallSite , HSPI , Object ) at HSPI_MelcloudClimate.HSPI.GetDevices(Int32 retry) 3/05/2024 09:52:34 Legacy-Plugin MelcloudClimate Debug Parent id 99605401 3/05/2024 09:52:34 Legacy-Plugin MelcloudClimate Debug Process all devices pr devices 3/05/2024 09:52:34 Legacy-Plugin MelcloudClimate Debug No client devices found 3/05/2024 09:52:34 Legacy-Plugin MelcloudClimate Debug Process all devices pr clients 3/05/2024 09:52:34 Legacy-Plugin MelcloudClimate Debug No area devices found 3/05/2024 09:52:34 Legacy-Plugin MelcloudClimate Debug Process all devices pr area 3/05/2024 09:52:34 Legacy-Plugin MelcloudClimate Debug No floor devices found 3/05/2024 09:52:34 Legacy-Plugin MelcloudClimate Debug Process all devices pr floor 3/05/2024 09:52:34 Legacy-Plugin MelcloudClimate Debug Got a successful response from melcloud
