5
Alt skrevet av Tor Magnus
Da er hele huset over på Home Assistant. Noen som er interessert i å kjøpe en Fibaro Home Center 2?
- 25 svar
- ikea trådfri
- home assistant
(og 6 andre)
Men det er her jeg synes de fleste "smarte" løsninger feiler. Det er da sanneligmeg mer komplisert å dra telefonen opp av lomma, låse den opp, lukke applikasjonen du har åpen, bla til riktig side på home skjermen, åpne applikasjonen, klikke på knappen enn det er å gå bort til maskinen og trykke på riktig knapp. En app betyr ikke at en device er smart. Til tider vil jeg si at det er dummere.
Beside the improved Wink support which was contributed by @w1ll1am23, ships this release a wide variety of new components and platforms. The input_slider components has received a makeover by @BioSehnsucht and is now input_number. @tinloaf added a feature that allows you to enter dates: input_datetime. Both will help you to improve your automation rules. DuckDNS Using Home Assistant with DuckDNS for Dynamic DNS (DDNS or DynDNS) is an old story. DuckDNS is also integrated in Hass.io. 0.55 ships a component for no Hass.io users to get a similar feature. Recorder The purging of data was improved. With purge_interval you can schedule regular purges of older events and states. In combination you can specify with purge_keep_days the amount of days you want to keep. The new service recorder.purge allow to handle this task when needed. Owntracks Owntracks is an easy way to track your devices. For some times we have the device tracker which depends on MQTT but thanks to a new feature in Owntracks we can now offer support for HTTP. The new platform doesn't require a MQTT broker but sends messages directly as HTTP requests to Home Assistant. Tibber This release introduces a new sensor: Tibber. The sensor provides the current electricity price if you are a Tibber customer. This will allow you to make automation for turning off the heater when the electricity price is high or only charge your electric car when the prices are low. We further plan to add support for showing future electricity prices and historic electricity consumption data. Tibber is currently only available in Norway and Sweden The Things Network The Things Network (TTN) is a LoRaWAN based network especially designed for IoT devices. With this integration one can observe the state of devices which are out of range of the local WiFi network as long as they are connected to a TTN gateway. New Platforms GeoRSS sensor (@exxamalte - #9331) (sensor.geo_rss_events docs) (new-platform) Add DuckDNS component (@balloob - #9556) (duckdns docs) (new-platform) Add OwnTracks over HTTP (@balloob - #9582) (http docs) (device_tracker.owntracks docs) (device_tracker.owntracks_http docs) (new-platform) Add an input_datetime (@tinloaf - #9313) (input_datetime docs) (new-platform) Cover component for RFlink (@passie - #9432) (rflink docs) (cover.rflink docs) (new-platform) Introducing support to Melnor RainCloud sprinkler systems (@tchellomello - #9287) (raincloud docs) (binary_sensor.raincloud docs) (sensor.raincloud docs) (switch.raincloud docs) (new-platform) MQTT climate platform [continuation of #8750] (@tinloaf - #9589) (climate.mqtt docs) (new-platform) Add Tibber sensor (@danielhiversen - #9661) (sensor.tibber docs) (new-platform) Updating clicksendaudio component based on feedback (@jeroenterheerdt - #9692) (notify.clicksendaudio docs) (new-platform) Support for The Things Network (@fabaff - #9627) (thethingsnetwork docs) (sensor.thethingsnetwork docs) (new-platform)
Jeg har ikke Netatmo selv så vet ikke hvordan den virker. Er det HASS som poller eller er det netatmo som pusher? Hvis det er sistnevnte så tipper jeg du må sette dette i netatmo (enheten?).
Oppdaterte første post da huset er i full fart på vei over til Home Assistant!
- 25 svar
- ikea trådfri
- home assistant
(og 6 andre)
Litt sent ute, men verdt å nevne uansett. Ny versjon ble sluppet 23. september med flere nye integrasjoner, blant annet DoorBird. Noen breaking changes, ikke minst fra yours truly, så sjekk config når du oppgraderer. Release notes: https://home-assistant.io/blog/2017/09/23/release-54/
0.53 lansert med støtte for Tesla, bedre editor ++
Tor Magnus svarte på Dennis87 sitt emne i Home Assistant
Her er en liten oversikt over kommandoer som er nyttige: # Hent docker image fra docker hub docker pull homeassistant/home-assistant # Lag et container oppsett basert på et image docker create --name="home-assistant" --restart always --net=host --device="/dev/ttyACM0:/dev/ttyACM0" -v /etc/homeassistant/config:/config -v /mnt/1wire:/onewire -v /etc/localtime:/etc/localtime:ro homeassistant/home-assistant # Her definerer jeg et navn på kontaineren, at den skal startes på nytt når den krasjer eller # maskinen er rebootet, at den skal få tilgang til nettet til maskinen, at den skal ha tilgang # til z-wave devicen, at den skal mounte diverse kataloger inn i containeren # (-v /fra_host:/til_container), og til slutt hvilket image jeg skal bruke. # Stop en kjørende container (basert på name som jeg definerte over) docker stop home-assistant # Slett en definert container docker rm home-assistant # Start en container som er stoppet docker start home-assistant # Vis alle kjørende containere docker ps # Vis alle containere, kjørende og stoppede docker ps -a # Vis hvilke images du har lastet ned docker images- 15 svar
For de som allerede kjører linux på en server vil jeg slå et slag for å kjøre Docker containeren. https://hub.docker.com/r/homeassistant/home-assistant/ Å bruke docker image gjør det utrolig lett å holde koden oppgradert, jeg har full styring av konfigurasjonen utenfor kontainerenen, med backup av konfigurasjonen via git. Jeg har også fått inn en pull request på 1-wire komponenten, men siden den ikke er inne i master ennå så legger jeg den enkelt inn automatisk ved oppdatering av imaget. Dette er seriøst enkelt å vedlikeholde, jeg kan enkelt jobbe med konfigurasjonen på laptop og få den automatisk oppdatert på boksen når jeg committer. Jeg kan flytte den fra en boks til en annen uten noe pes, bare å kjøre et lite skript som laster ned docker imaget, cloner konfigurasjonen fra git og så er man oppe og går. På en NUC kjører jeg nå HA, Owntracks, MQTT, Elasticsearch, Grafana, Plex, Sonarr, nzbget, Couchpotato, deluge, Unifi controller og NGINX. Load ligger og vaker under 0.5 mesteparten av tiden.- 15 svar
Jeg kjører kontrolleren i en Docker kontainer på plex PC'en min. Dersom han har fiber så trenger han strengt tatt ikke modem heller men kan kjøre fiberen rett inn i f.eks. en USG. (Har ikke kjøpt GBIC'en ennå, men det er på planen.)
La til to modus i tv stua slik at jeg kan bruke bryterne på fibaro dimmeren til å sette ekstra lys (for når kona står der og stryker mens vi ser på tv) eller mindre lys (for når jeg tar meg en liten lur). Dette er i tillegg til dimming når chromecast spiller og er nødvendig fordi lysnivået settes automatisk avhengig av tid på døgnet.
Ikke glem at hver gang den skal rapportere så må den vekke nettverksmodulen og bruker mer strøm. Sett alltid terskelverdiene så høyt du kan tolerere for å få batteriet til å vare. ?
Etter forslag fra @Moskus legger jeg inn mitt chromecast til fibaro HC2 skript her. Jeg sjekker kun etter status på chromecastene, om de spiller eller buffrer og setter en global variabel til "True". Hvis du pauser eller stopper streamen så settes variabelen til "False". Jeg bruker scenes til å reagere på endringer av denne variablen. Jeg ville tro at dette også kan brukes mot HCL. Det forutsettes nå at denne variablen finnes og heter cc_<Chromecast_Name>. F.eks. har jeg en Chromecast som heter "TV Lounge" med en variable i HC2 som heter "cc_TV_Lounge". Altså legges det på cc_ foran og mellomrom byttes ut med _. https://gist.github.com/tcastberg/b4ceb4763c2b6c86f8b8d22658281de3
- 1 svar
Ny versjon ferdig og jeg tror den skal fungere ok. Husk å lage variabel for hver chromecast i Home Center før du kjører skriptet. Formatet på variablene er cc_ChromeCast_Navn (mellomrom i navnet på chromecasten byttes ut med _) https://gist.github.com/tcastberg/b4ceb4763c2b6c86f8b8d22658281de3
- 25 svar
- ikea trådfri
- home assistant
(og 6 andre)
Er i testing av nytt script nå som bruker callback og derfor er mye mer responsivt. Litt endring i når den slår variablen av og på også, slik at lyset går opp når avspilling er pauset.
- 25 svar
- ikea trådfri
- home assistant
(og 6 andre)
Skjemmes litt over det jeg postet så det kommer en ny versjon som er bedre snart.
- 25 svar
- ikea trådfri
- home assistant
(og 6 andre)
https://github.com/bootsc5/monitor-ccs Denne er kanskje ikke så dum for de som har en løsning som bruker mqtt.
- 25 svar
- ikea trådfri
- home assistant
(og 6 andre)
Bare så du er advart, det funker men er ikke elegant. Det burde nok ha en "Under Construction" stemplet over hele. For øyeblikket er den begrenset til å sjekke mot kun en chromecast, men det skal kunne kjøre mot alle. <Fjernet så man ikke bruker noe som ikke fungerer så bra.>
- 25 svar
- ikea trådfri
- home assistant
(og 6 andre)
Intensjon Hovedmålet mitt med automasjonen i huset er vi aldri skal behøve å tenke på å slå lys av og på. Hvis noen føler behov for å ta i en lysbryter så er det en feil i automasjonen. Dette har vist seg å ikke alltid være så lett, spesielt når enkelte er veldig vant til å bruke brytere. Vi ser noen spesielle anledninger hvor det kan være nyttig å kunne overstyre, spesielt på tv stua. (F.eks. når man stryker klær og ser på TV eller når man vil da seg en liten ettermiddagslur...) Ideen er at all automasjon skal styres via hendelser, ikke via scheduler. System Sentral: Intel NUC (NUC7I5BNH) med Docker kjører: Home Assistant Prometheus Grafana Plex Unifi Couchpotato Sonarr nzbget deluge NGINX Aeotec Z-stick Gen5 iM871A-USB - Wireless M-Bus USB-adapter Ikea Trådfri Hub Aktuatorer: 19x Fibaro Dimmer 2 3x Fibaro Relay 2 6x Fibaro Wall Plug 3x Fibaro RGBW 1x Idlock 101 1x DCH-Z510 Siren 7x Ikea Trådfri pærer 4x Ikea Trådfri drivere Sensorer: 7x Sensative Strip 3x Aeotec Multisensor 6 8x Fibaro Motion Sensor 1x Fibaro Door/Window Sensor 1x Fibaro Universal Binary Sensor Temperatur i varmtvannsbereder 1x NodeMCU Ringeklokke Netatmo inne/ute/vind (hjemme og hytta) Tibber pulse Varme: 1x Mill Wifi varmeovn 1x Mill Wifi oljeovn Kamera: 1x Foscam C1 6x RTSP stream fra DVR (2 til ligger i eske og venter på å bli montert) Alarm: Verisure (API/Plugg) A/V: 4x TV med Chromecast 1x Xiaomi IR Remote 1x Sonos Play:1 1x Sonos Play:3 Drivhus: NodeMCU Relé for styring av vannventil Relé for styring av ventilering DS18B20 temperatur i jord Kapasativ fuktsensor for jord DHT22 sensor for temperatur og fuktighet i luft Annet: Tesla Model X 3x Google Home Mini Xiaomi Roborock S50 Automasjon Lys slås av dersom lysnivået i rommet er høyt fra naturlig lys. I noen rom hvor det er bevegelsessensorer er det kun minimal belysning som justeres opp når det er bevegelse. Lysintensitet / farge er justert per aktuator i perioder av Morgen/Dag/Kveld/Natt eller via Flux. Utelys slås av og på basert på soloppgang/solnedgang Alle bad og vaskerom er på sentral ventilering som er justert via fuktsensor i alle disse rommene. Jeg kalkulerer gjennomsnittsfuktighet og avvik og bruker dette til å slå ventilasjon av og på. Når oppvaskmaskin, vaskemaskin og tørketrommel er ferdig annonseres dette via Sonos og til telefoner. Vekke/morgenlys i nattbordlampe. På bad er speillys på konstant, mens taklys slåes av og på basert på bevegelse. Når Chromecast i tv stua begynner å streame dempes lyset. Notification via HTML5 rett på telefonene, via Sonos og på mail. Ringeklokkeknapp koblet til NodeMCU som trigger bjellelyd på alle Google Home og Sonos høytalere når noen ringer på, notification med bilde fra dørkamera til alle telefoner og justerer opp lyset i gangen. Varmvannsbereder har fått Fibaro Universal Sensor med 3 temperaturprober koblet på, venter på få montert Aeotec Heavy Duty. Annonsering i huset når vi er på vei hjem. Mill Wifi ovn har nattsenking og feriesenking via Home Assistant i stedet for i appen. Ved å kombinere Z-wave plug på TV, IR remote og chromecast, passer jeg på at TV er av når CC er idle, og at CC streaming stoppes hvis TV slås av. Rødt "nattlys" i hele huset hvis man er oppe om natten, slik at man ikke forstyrrer søvnrytme for mye. Setter sovemodus ved å si god natt til Google Home. Integrasjoner Home Assistant har plugin for å polle Verisure API på internet og via en Verisure plugg som slår på et nattlys når alarmen er på, hvor jeg trigger på forbruk via en Fibaro plugg. Dette brukes til å hente ut state på alarmen og for å vise data for alle sensorer i verisure anlegget slikt som dører, temperature og luftfuktighet. Jeg bruker Google Maps for location tracking. Integrasjon mot Unifi kontrolleren som kjører på samme server som gir presence detection. Chromecast og Sonos er selvfølgelig integrert og gir både oversikt over hva som skjer og mulighet til å kontrollere disse. Google Home er integrert mot Home Assistant og gir mulighet til å dimme, slå av og på lys. Lading av elbil styres av HA på grunnlag av priser fra Tibber. Integrert mot Netatmo hjemme og på hytta. Driver foreløpig ingen automasjoner da det er litt flaky. Fremtidsplaner Lage en haug med NodeMCU temp/hum/lux/motion sensorer for å teste hvordan de sammenligner med Fibaro Motion Sensor. Gjøre det enklere å håndtere gjester. Automatiske rullgardiner fra Ikea, hvis man får tak i de snart... Video til chromecast(s) når det ringer på døren (testet, chromecast liker ikke oppløsningen foreløpig). Implementere komplett feriemodus. Implementere komplett alarm via HA. Heatit Z-trm(3?) når de kan lever noe skikkelig. Slik ser det ut den 3. september 2019 I likhet med @Fermate er jeg også en eks-Funcommer fra AO perioden.
- 25 svar
- 7
- ikea trådfri
- home assistant
(og 6 andre)
Litt sent men, ja det finnes. https://developer.fibaro.com/docs
Den boksen så innmari lik ut boksen som kommer med led stripene som Clas Ohlson selger. Slik koblet jeg det: 12/24V - + fra strømforsyning og VCC fra led stripe GND - - fra strømforsyning R - Rød fra led stripe (ikke nødvendigvis rød kabel!) G - Grønn fra led stripe (ikke nødvendigvis grønn kabel!) B - Blå fra led stripe (ikke nødvendigvis blå kabel!) Dersom du kobler RGB feil så gjør det ingenting, de kan du lett bytte på når du finner ut hvilken kabel som er hvilken farge. Eneste konsekvens av å feilkable de er at du får feil farge når du justerer fargeparameterne. Og lyset blir ikke helt hvitt når alle er slått på nei, men det er helt greit for hva det er. Jeg har en montert bak TV på soverommet og en bak senga til jenta. Veldig stas. Mvh, Tor Magnus
