aleks
Alt skrevet av aleks
  1. Interessant - jeg har 220V IT 3 fase. Noen grunn til at L2 ikke trengs å måles i måleren når den leverer strøm? Jeg er ingen elektriker, så er det mulig å regne ut L2 på hvis måleren ikke måler den?
  2. Kanskje det er noe du umiddelbart ser her: Her er avlesning av smappee (CT-klammer og har faktisk vært svært nøyaktig) Instantaneous values: voltage=238.7 Vrms FFTComponents: Phase 1: current=14.416 A, activePower=1940.644 W, reactivePower=428.337 var, apparentPower=1987.353 VA, cosfi=97, quadrant=0, phaseshift=0.0, phaseDiff=0.0 FFTComponents: Phase 2: current=7.178 A, activePower=899.165 W, reactivePower=413.203 var, apparentPower=989.563 VA, cosfi=90, quadrant=0, phaseshift=0.0, phaseDiff=0.0 FFTComponents: Phase 3: current=14.016 A, activePower=1690.717 W, reactivePower=935.241 var, apparentPower=1932.149 VA, cosfi=87, quadrant=0, phaseshift=0.0, phaseDiff=0.0 FFTComponents: Phase 4: current=3.741 A, activePower=500.929 W, reactivePower=122.928 var, apparentPower=515.792 VA, cosfi=96, quadrant=0, phaseshift=0.0, phaseDiff=0.0 FFTComponents: Phase 5: current=3.654 A, activePower=487.369 W, reactivePower=127.734 var, apparentPower=503.83 VA, cosfi=96, quadrant=0, phaseshift=0.0, phaseDiff=0.0 FFTComponents: Phase 6: current=3.71 A, activePower=498.271 W, reactivePower=115.807 var, apparentPower=511.552 VA, cosfi=97, quadrant=0, phaseshift=0.0, phaseDiff=0.0 FFTComponents: Phase 1, peak active power 5995.763 W at 18/08/2018 17:57:40 Phase 2, peak active power 6578.69 W at 20/08/2018 16:42:05 Phase 3, peak active power 6440.171 W at 20/08/2018 15:38:15 active energy RMS per phase mapping combination phase mapping 210=106.635 kWh [ -1/1] phase mapping 12=217.655 kWh [* -1/3] phase mapping 21=108.926 kWh [ 1/1] phase mapping 102=116.397 kWh [ 1/1] phase mapping 120=256.149 kWh [ 1/0] phase mapping 201=125.505 kWh [ -1/0] active energy RMS (solar) per phase mapping combination phase mapping 210=2.34 kWh [ -1/1] phase mapping 12=166.582 kWh [* -1/3] phase mapping 21=2.432 kWh [ 1/1] phase mapping 102=1.935 kWh [ 1/1] phase mapping 120=110.533 kWh [ 1/0] phase mapping 201=104.035 kWh [ -1/0] Og SLIP data på samme tidspunkt 373335393939323930343437393837327b6b9e00000000004c360b0000000000da0200000000000031042b00000000002a0c000000000000000000004404000019720000160e10040000000000003a08000061095a095909710000006b0087130387ce
  3. Ja, har alle faser tilkoblet. Ser noen felter stemmer, men andre ikke gjør det. Kan være konverteringen jeg har mellom serial og slip data - hvilke kode brukte du fra rådata (buffer) -> slip? Er det korrekt hos deg at total eksport resettes ca kl. 09:05 om morgenen (den teller opp kwH opp til det tidspunktet, så resettes) og import ca 13:30 (dog jeg får de dataene på byte 40-47 Dette kan bunne seg i feil i konverteringen til slip - brukte aidon scriptet til en tidligere her i tråden til å lage slip, og node red til å dekode den. #!/usr/bin/python import serial import time import struct import sys import paho.mqtt.client as mqtt import binascii client = mqtt.Client() client.connect("192.168.1.5", 1883, 60) client.will_set("AMS/raw", payload=None, qos=0, retain=True) # SLIP constants FEND = '\xc0' def parse(pkt): print "".join("{:02x}".format(ord(c)) for c in pkt) print len(pkt) # pkt = pkt[len(pkt)-79:] # print pkt if len(pkt) == 99: client.publish( "AMS/slip", "".join("{:02x}".format(ord(c)) for c in pkt)) else: print "Length mismatch" if len(sys.argv) != 2: print "Missing port argument" sys.exit(0) buf = "" ser = serial.Serial(sys.argv[1], baudrate=9600, timeout=0, parity=serial.PARITY_NONE) while(1): if ser.inWaiting(): buf += ser.read(200) if FEND in buf: # Split message at the SLIP FEND character [pkt, buf] = buf.split(FEND) # Replace escape sequences in SLIP message pkt = pkt.replace("\xdb\xdc", "\xc0") pkt = pkt.replace("\xdb\xdd", "\xdb") parse(pkt) client.loop_forever()
  4. Har du fått verifisert dataene du hentet du av SLIP-meldingen? Hos meg ligger alltid fase 2 på 0, både i W og A Her er et eksempel på eksporten fra AIDON-måleren 37 33 35 39 39 39 32 39 30 34 34 37 39 38 37 32 a6 1d 9e 00 00 00 00 00 29 f9 0a 00 00 00 00 00 da 02 00 00 00 00 00 00 86 c3 2a 00 00 00 00 00 50 0e 00 00 00 00 00 00 00 00 00 00 38 03 00 00 9c 71 00 00 d5 0c b2 03 00 00 00 00 00 00 a3 0a 00 00 5a 09 57 09 59 09 6f 00 00 00 86 00 8b 13 03 3e 45
  5. Da er en enda avhengig av sensorer og programvare. Jeg sitter enda mellom Home assistant og homeseer da jeg ikke vet om ha takler nett bedre, og pluginprisene. Det er alltid noe
  6. Ja, alså den er fin-fin selveste ideen og synes UI-en er bra, men den bærer preg av å bli laget mange år siden. Hadde de tatt UI-en, boksen og kjørt inn 4-8GB ram, en ok CPU og 120GB med lagring hadde jeg betalt en god sum for den. Når de kjører med 512mb ram, en gammel cpu og et par gb med lagring holder det ikke lenge. Nå dropper de hele UI-en og går mobile only.
  7. Prøvde meg på homey, men returnerte den. Sikkert fin i sin tid, men vi snakker her om et system som er så tregt at i en alexa dialog bruker den faktisk 5-6 sekunder på å tenke for å skru på et lys.
  8. Noen erfaringer med stabile USB hubber med power injection. Finnes mye på eBay, men leter etter en kvalitet uten problemer som er stabil og fungerer plettfri med Linux
  9. Hva er den beste plug and play stricken med zwave of ZigBee (433 bonus). Kjører i dag aeotec g5, Converse og rfxtrx, men har lyst på en all in one som faktisk er stabilt.
  10. Er det ikke den måleren ment for å måle hele systemet? Elektroimportøren har målere pr kurs mener jeg. Husk hvis du monterer shuko er de egentlig rated for 6-8A konstant last så kan være smart å oppgradere uansett.
  11. Fikk svar fra produsenten og en kan ikke sjekke W-output fra kontrolleren. Kanskje ikke umulig - noen med noe elektrokunnskap som kanskje vet noe om dette?
  12. Selveste kodene for salto-boksen er faktisk åpen informasjon, ettersom de bruker en kontroller som har lagt ut dokumentasjonen på den, så egentlig er det ikke mye hacking eller reverse eng inne i bildet - alt er basert på offisielle koder og vil ikke engang påvirke garantien da pluggen ligger faktisk klar inni boksen. Regner med de fleste som faktisk har kjøpt en 32A lader ønsker å gjøre dette, da elektriker setter den pr standard til maks 25A siden Hafslund sier det. Dette kan du lett endre selv (igjen hvis du faktisk bestilte 32A, har 32A sikring i skap, tykke nok kabler og er nok en 40A sikring i selveste saltoen). 001170657-an-01-de-EVSE_LADEUEBERWACHUNG_IEC_61851_1_MODE_3.pdf
  13. Det eneste jeg sliter litt med er å kunne lese hvor mye som hentes ut fra laderen på det aktuelle tidspunktet. Kjøpte en HF2211 som konverteter diverse input til TCP/UDP/Telnet etc i direkte passthrough. Ved å koble RS485 porten på laderen direkte til den var det bare å sende en enkel kommando til Salto boksen for følgende 1. Sette maks / minimum ladestyrke (pass på systemet er dimensjonert for større hvis en gjør dette) <- Dette er grunnen til mange kjøper en 16-20A lader med 32A kabler og sikringer for å skru opp til 32A. Ladestasjonene støtter opp til 80A, og er bare programvareendring mellom dem. 2. Starte / stoppe lading 3. Sette maks ladestyrke on the fly til preset A (i gjeldende ladesyklus) 4. Sette ladestyrke i PWM fra 8 - 100% i intervaller 5. Mulighet for å seriekoble ladestasjoner ved å gi hver egen ID 6. Sjekke feilkoder 7. Kontrollere alle statuskoder 8. Sjekke om bil er koblet til 9. Resette koblingsyklusen 10. Resette feilkode f.eks ved feil i lading 11. Lese ut ADC-tallene (det var her jeg hadde håpet på å kunne lese ut W-forbruk, men tror ikke jeg får noe fornuftig ut av det. Får data, men usikker på om det er mulig å regne ut W-forbruk av ADC Pos / NEG / U Har allerede alt dette fungerende i Node-RED og Home Assistant - usikker på hvordan jeg skal slippe koden - som en NR flow, et script eller HA komponent.
  14. Sikker på det? Er det ikke slik porten må være åpen selv med deres egen datastrøm? Jeg ser bare pulser ca en gang i minuttet, så tror ikke det er mye data som kommer ut fra den
  15. Sjekket du siste versjon? Det er en ny opsjon der fra 74 eller 75.
  16. I siste versjon kan du editere entity direkte fra UI. Slipper å rote mer i yaml-filen
  17. Skjønner ikke hvorfor gjøre det så vanskelig hvis kablene er strukket med retur til lampen? Ligger alle ledere i takboksen så trenger en trossalt ikke klusse med bryteren hvis det ikke er plass / boks. Eneste kontakt med bryteren dimmer2 har er jo L inn og Lswitch ut av bryteren som trolig allerede ligger klart mot en enpolet bryter. Hvis du skal koble til bryteren, og den er utenpåliggende har jeg en følelse du ikke har mer enn L inn or retur. Alternativet er jo å borre inn en tabbeboks og montere en innebygget bryter med god plass bak hvis alle lederne går til bryteren. Penere i det minste. Jeg støtter dog de som sier dette er noe for en elektriker. Nevner bare i diskusjonsøyemed - generelt sett bør minimumsgrensen ligge: Er du usikker, ikke gjør det.
  18. Mja først husk det ikke er lovlig å montere selv. Dimmer2 er relativt omfattende enn bare sukkerbit. Men du kan montere den i takboksen hvis du har I (brun), n (blå) og l1 (svart). Svarte er retur fra bryteren. Har du de andre må du kutte, bruke wago og koble brun på l, til og fra bryteren (som går til lampe og bryter) i dag på dimmer2 og blå på n Husk å avmantle korrekt ca 10mm på wago og 6mm på dimmer. Når l og n er så nær er det svært viktig det ikke er synlig kobber. Hvis lederne er svart, hvit og rød er svart l, hvit n og rød retur.
  19. Dette fungerte bra. Har kommer til med enn 2211 og fungerte perfect med tcp queries I none red. Eneste jeg har skirt med er æfåden I m modus og else av faktisk forbruk. Nonenerfaring med det?
  20. Er det noen som har prøvd disse https://ebay.to/2KcXfXe for å kommunisere med AMS? Virker jo som en litt mer AIO løsning?
  21. Ja kjører Home Assistant som har komponent for modbus, men trenger enda en transciever som må kjøre. Så da må en Home Assistant -> IP/WIFI -> NodeMCU/Arduino -> RS tranciever -> Salto Egentlig ikke så komplekst opplegg
  22. Hadde ikke flere max485 moduler så bestilt flere via DHL. Tenkte å kjøre en enkel nodemcu med max485 som henter strøm i laderen og da kan leve livet sitt inni med kobliymot feks Home assistant, evt mqtt. For min del synes jeg i hvert fall det er interessant med en smart ladestasjon uten noe tilknytning til cloud. Tenker å bruke samme teknikk mot solpanel invertere (kjører mqtt i dag på dem). Da er det bare ams så har jeg full lokal kontroll.
  23. Yes, har funnet alle kodene nå. Må bare få interfacet til å fungere så kan vi automatisere nesten alt på disse laderne. Nevner f.eks - Lading av / på - Maks ladestyrke - Ladestyrke nå - Overkjøre Hafslund sin 25A-grense (hvis en har 32A lader) - Manuell / Automatisk lading - Deling av ladestyrke mellom flere elbiler
  24. Mener jeg har kommet fram til at dette er vanlig modbus med B og A på TX og TR / DATA + og - ; Får se hva som er mulig å få til. Burde jo være interesse her
  25. Da kan en i hvert fall kjøre en nodeMCU på Aidon og Kafia da slik jeg ser det?. Så port 7 og 8 er grnd + 5v?
