  1. Bra! Da skal TibberSeer klare å hente oppdaterte priser.
  2. Det kan være. Men det er iallfall fort gjort å sjekke! Det vet jeg ikke. Du kan sjekke på developer.tibber.com. Gå til API Explorer, last din token, og last "Current Price" eksempelet i nedtrekksboksen. Hvis du så bytter ut "current" med "today" så får du en liste over priser. Den skal se slik ut: { "data": { "viewer": { "homes": [ { "currentSubscription": { "priceInfo": { "today": [ { "total": 0.058, "energy": 0.0464, "tax": 0.0116, "startsAt": "2018-05-10T00:00:00+02:00" }, { "total": 0.0562, "energy": 0.0449, "tax": 0.0113, "startsAt": "2018-05-10T01:00:00+02:00" }, { "total": 0.0566, "energy": 0.0453, "tax": 0.0113, "startsAt": "2018-05-10T02:00:00+02:00" }, { "total": 0.0571, "energy": 0.0457, "tax": 0.0114, "startsAt": "2018-05-10T03:00:00+02:00" }, { "total": 0.0565, "energy": 0.0452, "tax": 0.0113, "startsAt": "2018-05-10T04:00:00+02:00" }, { "total": 0.0574, "energy": 0.0459, "tax": 0.0115, "startsAt": "2018-05-10T05:00:00+02:00" }, { "total": 0.0718, "energy": 0.0575, "tax": 0.0143, "startsAt": "2018-05-10T06:00:00+02:00" }, { "total": 0.203, "energy": 0.1624, "tax": 0.0406, "startsAt": "2018-05-10T07:00:00+02:00" }, { "total": 0.3392, "energy": 0.2714, "tax": 0.0678, "startsAt": "2018-05-10T08:00:00+02:00" }, { "total": 0.3456, "energy": 0.2765, "tax": 0.0691, "startsAt": "2018-05-10T09:00:00+02:00" }, { "total": 0.3309, "energy": 0.2647, "tax": 0.0662, "startsAt": "2018-05-10T10:00:00+02:00" }, { "total": 0.3367, "energy": 0.2694, "tax": 0.0673, "startsAt": "2018-05-10T11:00:00+02:00" }, { "total": 0.2989, "energy": 0.2391, "tax": 0.0598, "startsAt": "2018-05-10T12:00:00+02:00" }, { "total": 0.2728, "energy": 0.2182, "tax": 0.0546, "startsAt": "2018-05-10T13:00:00+02:00" }, { "total": 0.2251, "energy": 0.1801, "tax": 0.045, "startsAt": "2018-05-10T14:00:00+02:00" }, { "total": 0.2258, "energy": 0.1806, "tax": 0.0452, "startsAt": "2018-05-10T15:00:00+02:00" }, { "total": 0.253, "energy": 0.2024, "tax": 0.0506, "startsAt": "2018-05-10T16:00:00+02:00" }, { "total": 0.2862, "energy": 0.229, "tax": 0.0572, "startsAt": "2018-05-10T17:00:00+02:00" }, { "total": 0.3529, "energy": 0.2824, "tax": 0.0705, "startsAt": "2018-05-10T18:00:00+02:00" }, { "total": 0.374, "energy": 0.2992, "tax": 0.0748, "startsAt": "2018-05-10T19:00:00+02:00" }, { "total": 0.3758, "energy": 0.3006, "tax": 0.0752, "startsAt": "2018-05-10T20:00:00+02:00" }, { "total": 0.3794, "energy": 0.3035, "tax": 0.0759, "startsAt": "2018-05-10T21:00:00+02:00" }, { "total": 0.2335, "energy": 0.1868, "tax": 0.0467, "startsAt": "2018-05-10T22:00:00+02:00" }, { "total": 0.1656, "energy": 0.1325, "tax": 0.0331, "startsAt": "2018-05-10T23:00:00+02:00" } ] } } } ] } } } Nei, jeg kan ikke se hvorfor det skulle hjelpe. Den feilmeldingen viser at plugin'en prøver å hente data som ikke finnes. Men de aktuelle strømprisene skal den klare å hente. Hvis ikke, sjekk oppskriften over, og post hva du får ut.
  3. Nei, jeg tar det tilbake. TibberSeer fungerer fint her på mine bokser og developer.tibber.com gir fornuftige svar.
  4. Bare det andre. Ikke det første. Du må teste node for node, dessverre... Send gjerne 10 pakker.
  5. "No token defined" viser at du mangler en token... den må du legge inn.
  6. Bra jeg ikke undersøker hos meg selv først... ? Dere har rett. Det ser ut til at Tibber sliter. Jeg skal høre med dem!
  7. Ser du noen feil i loggen? Kjører plugin'en? Sjekk Plugins -> Manage og/eller Windows sin Task manager.
  8. Det ser jo ut som om HS ikke er i stand til å lese alt på node 82. Om det er fordi den er inkludert secure og har hatt litt problemer med nøkkelutvekslingen eller om firmwaren faktisk er forskjellig, det kan vi jo bare spekulere i... Har du testet non-secure?
  9. Kan du sjekke Root -> Z-wave tab om de har forskjellige firmware?
  10. Moskus
    RobonectSeer
    Plugin'en rapporterer KUN det som Robonect rapporterer. Så du må høre med dem i så fall... Hos meg stemmer det stort så vidt jeg har registrert. Vi har en bakke bak huset som er litt i grenselandet for robotklippere... Den setter seg fast, og spesielt hvis gresset er litt for høyt og litt for vått. Denne fikser det i 90% av tilfellene:
  11. Bare bruk C#. Det er støttet. Bare husk .cs endelse på scriptfilen istedenfor .vb.
  12. Jeg pakket ZIP-filen ut og overførte hele innholdet til min Zee2. Fungerte brillefint. … men du sier ikke hvilken feilmelding du får?
  13. Wow, det var en vanvittig forbedring! Takk for tipset, det må vi ta med oss. Må inn i "sjekklista".
  14. Nei, jeg er i mot skytjenester for slike ting. Vil ikke ha det for kaldt (eller for varmt) kun fordi en Internett-tjeneste er nede. Jeg bruker en Global Caché (og en ZXT-120).
  15. Akkurat når den forlater. Ved ideelle forutsetninger. Plugin'en poller gressklipperen... Skal du ha nøyaktig, så er vel magnetbryter det beste alternativet. Ja, det har den.
  16. Som @iceball sa kan det være greit å deaktivere polling. Men polling i seg selv skal ikke egentlig være et problem. Har du mange noder? Det kan være en routing-feil. Da er det et par ting du kan gjøre: 1) Hvis du har mange enheter kan du la Z-wave håndtere routingen selv. Problemet er at du må gjøre en restore av nettverket ditt, og det støtter ikke Z-stick'en. 2) Hvis du ikke har så mange enheter (dvs. mindre enn... øh… 20-30 faste enheter, kanskje?) så kan du prøve å optimalisere nettverket. Det være én node som det henger på. Altså en node som ikke oppfører seg som den skal. Den kan du muligens finne med Z-Seer+ (hvis du har Pro). Hvis du finner den, kan du prøve å ekskludere den og sette den inn på ny. Det siste er at det kanskje kan være et problem med Z-stick'en eller kommunikasjonen mellom PCen og denne pinnen.
  17. Moskus
    RobonectSeer
    Det var da enda godt...
  18. Moskus
    RobonectSeer
    Hva får du når du setter denne URLen inn i nettleseren din? http://robonect_IP/json?cmd=status
  19. Moskus
    RobonectSeer
    Hvilken versjon er det? Har du lagt inn riktig IP?
  20. Ja, når han får plugin'en til å virke får man alle statusoppdateringer.
  21. Nei, men Home Control har jo en tendens til å snakke i litt store bokstaver... Verdensnyheten kan være at de støtter Z-wave. Men forhåpentligvis er det kulere enn det!
  22. En DS90 vil fungere fint. Dette er helt spesifikt en DS10 som ble modifisert fra 311 MHz til 433 MHz...
  23. Moskus
    RobonectSeer
    Wops. Nei. Så hva skjer hvis du trykker "Start" da, eller gjør noe annet som gjør at klipperen endrer status?
  24. Billige kameraer som støtter rtsp (og det er flere og flere) har en tendens til å ikke gi deg direktelink til bildet.
  25. Da kan du helt sikkert bruke oppsettet i linken over.
