Erling
Alt skrevet av Erling
  1. Erna sa ikke noe om at vi ikke kunne «hamstre» annet enn dagligvarer vel. Uansett, dette er ikke min feil. ?
  2. Ja, derfor er det litt pussig. Eneste jeg tenker det kan være at disse går på batteri.
  3. Hei. Rydder, har 6 objekter som har flyttet nordover. Glemte å ekskludere de før jeg solgte de. Google gav meg denne: https://forums.homeseer.com/forum/lighting-primary-technology-plug-ins/lighting-primary-technology-discussion/z-wave-homeseer/103974-how-do-i-delete-a-phantom-device?p=1061650#post1061650 Da blir det bare feilmeldinger i liggen: apr-05 21.59.01 Z-Wave Warning EB: Node 106 was not removed because the interface EB does not have that node in its memory. (It may already be removed.) apr-05 21.58.40 Z-Wave Warning EB: Node 103 was not removed because the interface EB does not have that node in its memory. (It may already be removed.) apr-05 21.58.17 Z-Wave Warning EB: Node 101 was not removed because the interface EB does not have that node in its memory. (It may already be removed.) apr-05 17.33.14 Z-Wave Warning EB: Node 100 was not removed because the interface EB does not have that node in its memory. (It may already be removed.) apr-05 17.32.31 Z-Wave Warning EB: Node 99 was not removed because the interface EB does not have that node in its memory. (It may already be removed.) apr-05 17.32.03 Z-Wave Warning EB: Node 98 was not removed because the interface EB does not have that node in its memory. (It may already be removed.) De ligger i Node Information, kan jeg bare fjerne de fra Device List? Selv om det kommer advarsel: God påske!
  4. Venter på varme, men limen er på plass.
  5. Polen sender ingen pakker nå: Dear Sir/ Madam We kindly inform that due tot he epidemic situation regardsin corona virus flights were suspended to the further notice. You cannot send the shipment at all at the moment . Regner ikke med gebyr.
  6. Multisensor 6 m/innbyggingskit. Takk @Moskus x 2, fikk brukt opp bonusen hos Tibber. Bra priser hos de.
  7. Sirenen fungerer! endelig Impulskjøp for «ørten» år siden, antar 2014-2015. Ble lagt til HS3 men aldri gjort noe mer med, har byttet til nyere z-wave dings og dermed ble det håp. Som en følge av korona/sommertiden lå jeg i natt uten å få sove, dermed ble det liv i den, fra senga/iphone. ? Du verden så dette bråker, kan plage naboen som reagerer når folk trekker i toalettet om natten. ? Her er trikset: https://forums.homeseer.com/forum/lighting-primary-technology-plug-ins/lighting-primary-technology-discussion/z-wave-homeseer/84538-support-for-aoetec-aeon-labs-siren-solved?p=1125504#post1125504 Du må gjøre noe jeg lærte for 25+ år siden, denne fixer det: https://www.binaryhexconverter.com/hex-to-decimal-converter Backlogg...
  8. Tusen takk, jeg fikser det.
  9. Klips for hue outdoor - på glass? På terrassen har jeg glassvegg, den går vel 120 cm. opp fra gulvet, der vil jeg gjerne feste hue outdoor led-strips. Dobbeltsidig tape holder ikke, konstant vind på vestlandet. «Hobbytvinger» gjør jobben, men ser teit ut. 6 meter, 6 flak hver på 1 meter. Bør vel ha noe hver 10-15 cm. Noen Petter Smart-forslag her inne? Originalt "klips": Outdoor montert:
  10. Tror dette virker bra, men ikke sikker. Oppdateringer i kø hos meg.
  11. Erling
    If/else i event?
    Jo, ofte mørkt da. Jeg ser poenget ditt, tiden er ikke rund som en klokke. TAKK, visste det var noe jeg hadde glemt. + Følger forslaget til @Guahtdim.
  12. Erling
    If/else i event?
    Ny if-then-else «utfordring» Hver gang døren åpnes kjøres en event som igjen kjører denne: Men hvorfor «trigger» den selv om klokken er før 20:30? Garantert veldig logisk, men... Egentlig ville jeg hatt den avgrenset til mellom 8-10 og 20:30-22:30, men la oss begynne med denne.
  13. Jeg har rotet - igjen. Hvordan kan jeg bytte disse, har byttet/rotet slik at det som vises i HS-Touch og brukes i eventer ikke samsvarer. Batterifjerning hjelper kanskje, men litt bakvendt slik 2 er plassert.
  14. Hei igjen. I det siste ar serveren bootet selv om alt er som du sier. Disse filene har dato 12. mars, siste boot. Reboot_AC Reboot_Battery Har du løsningen?
  15. Temp.-måler for kjøleskap og fryser? https://www.teknikmagasinet.no/produkter/hjemmeelektronikk/husholdningsdingser/termometer-vaerstasjoner/remote-thermo-sensor Vet noen om denne fungerer med Rfxcom? Evt. andre modeller.
  16. Takk @Moskus Selvsagt, men... Har flere skjermer, med forskjellig bruk. Hadde ønsket å ha 1 project til de like enhetene. Løste det med duplisering av fila, fjernet autoshift på den det gjaldt nå. Utfordringen blir å huske - når jeg rydder til høsten, om noen år.
  17. Folkens, slik jeg tenkte gikk ikke... ? Har flere tablets som bytter «layout» (skjerm) hvert minutt. I HSTouch har jeg satt return to main etter 1 min., et script går hvert 2. minutt som bytter til den andre «layout»’en. Dette fungerer utmerket! Men, det er alltid et men. Hvis jeg vil vise 1 annen layout fast og dermed avbryte automatikken på 1 tablet innimellom. Hva blir enkleste måten å gjøre det på? Finnes det en if layoutchanges then... Noen som skjønte den forklaringen?
  18. Egentlig skulle jeg «bare» bytte lyspære, #okker at den dyre Hue-pæra til 400,- var defekt allerede. Mens jeg prøvde å demontere lampen for å få ut pæra, skjedde det noe. ? Fikk tak i nytt glass, monterte lampen med ny pære og alt var like dødt. Noen forsøk med feilsøking av Homeseer og boot av Hue-hubben hjalp ikke. Men når jeg kom på at vaskehjelpen hadde vært her nylig og hun hadde skjøvet skjenken nærmere veggen, og dermed belastet on/off-bryteren som henger på ledningen. Jaja, det kunne vært verre. Kunne f.eks. ødelagt den nye «dingsen». ?
  19. Hei, jeg blir skrullete. Har 2 slike hubber, den ene får jeg ikke til å bli norsk. Kan det være 2 forskjellige produksjoner? Begge fra Power, forskjellige sendinger. God jul.
  20. https://www.tronika.no/no/smarthus/zwave-produkter/zwave-sikkerhet/roykdetektorsirene-9402.html?search_query=POPE009402&results=1 Ca. 2 år gamle, selges samlet rundt halv pris. Evt. skambud. Send PM. ? Tekst fra Tronika - hvor jeg kjøpte de:
  21. Takk for innspill. Må sove på det, har 6 slike https://www.tronika.no/no/smarthus/zwave-produkter/zwave-sikkerhet/roykdetektorsirene-9402.html?search_query=POPE009402&results=1 som kun er 2 år gamle. Z-Wave Plus 10Years Smoke Detector and Siren - 9402 from Popp Blir dumt å pensjonere de. ?
  22. Hei, hva gjorde du med dette? Gikk du for Nest? Kjørte test av 6 stk. Popp - og, vel, ja - vurderer å bytte ut disse og få noe "enklere". ?
  23. Noen som jevnlig oppdaterer? Det ble nevnt flere ganger, muligens rundt "tullete oppførsel" fra multisensor fra 2015-2016. ? Tolker ditt svar som oppdatering av firmware på z-wave enhetene ikke er viktig.
  24. Hei, jeg har "forlagt" USB-pinnen + bokmerkene som var huskelapp. https://shop.homeseer.com/products/z-wave-firmware-update-software-kit Noen som jevnlig oppdaterer? Har Z-Net. #backlog2016
  25. Erling
    «Ghost-device»?
    Takk, nei, det er ikke i hubben. Har aldri lagt inn noe der utover navn/rom. Det skjer 1 time før sunset hver dag. Har gått over alke eventer som ble kjørt i dag uten å bli klokere. Må nok bare fjerne lyset og adde de igjen.
