olsbor
Alt skrevet av olsbor
  1. Brukte en tidligere versjon ja, nå fungerer det. Er det mulig å lage en automation som velger ny modus til ovnene, f.eks setter dem i nattmodus?
  2. Ja så du postet det på HA forumet :) Jeg har fått lagt til integrasjonen din via hacs, men det stopper der. Jeg får følgende feilmelding: https://prnt.sc/uf26tq conf.yaml: https://prnt.sc/uf26b9
  3. Måtte du endre noe for at det skulle virke? Jeg har fortsatt "Invalid date"
  4. Jeg kjører 0.86.2 og har siste filen som ligger her: https://github.com/jonkristian/lovelace-cards Finnes det en nyere .js?
  5. 2019-01-25 00:14:41 ERROR (MainThread) [frontend.js.latest.201901211] https://xxxxxxxx.duckdns.org:8123/local/js/entur-card.js?v=5:94:25 TypeError: undefined is not an object (evaluating 'state.attributes') 2019-01-25 00:22:36 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.transport_kleiva fails Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 159, in _new_conn (self._dns_host, self.port), self.timeout, **extra_kw) File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 57, in create_connection for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM): File "/usr/local/lib/python3.6/socket.py", line 745, in getaddrinfo for res in _socket.getaddrinfo(host, port, family, type, proto, flags): socket.gaierror: [Errno -3] Try again During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen chunked=chunked) File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 343, in _make_request self._validate_conn(conn) File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn conn.connect() File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 301, in connect conn = self._new_conn() File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 168, in _new_conn self, "Failed to establish a new connection: %s" % e) urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x6f0281b0>: Failed to establish a new connection: [Errno -3] Try again During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 449, in send timeout=timeout File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen _stacktrace=sys.exc_info()[2]) File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 398, in increment raise MaxRetryError(_pool, url, error or ResponseError(cause)) urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='api.entur.org', port=443): Max retries exceeded with url: /journeyplanner/2.0/index/graphql (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6f0281b0>: Failed to establish a new connection: [Errno -3] Try again',)) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 221, in async_update_ha_state await self.async_device_update() File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 349, in async_device_update await self.hass.async_add_executor_job(self.update) File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/entur_public_transport.py", line 178, in update self.api.update() File "/usr/local/lib/python3.6/site-packages/homeassistant/util/__init__.py", line 315, in wrapper result = method(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/entur_public_transport.py", line 121, in update self._api.update() File "/usr/local/lib/python3.6/site-packages/enturclient/api.py", line 108, in update headers=headers) File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 116, in post return request('post', url, data=data, json=json, **kwargs) File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 60, in request return session.request(method=method, url=url, **kwargs) File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 533, in request resp = self.send(prep, **send_kwargs) File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 646, in send r = adapter.send(request, **kwargs) File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 516, in send raise ConnectionError(e, request=request) requests.exceptions.ConnectionError: HTTPSConnectionPool(host='api.entur.org', port=443): Max retries exceeded with url: /journeyplanner/2.0/index/graphql (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6f0281b0>: Failed to establish a new connection: [Errno -3] Try again',)) Fant feilmeldingen - her var det mye ting. Noen tips?
  6. Funka fjell - helt til jeg kjørte siste oppdatering av HA nå, kortet ble helt borte. Finner ingen feilmelding heller som kan peike meg i riktig retning. Andre som har samme problemet?
  7. Noen som har fått til å styre Adax Wifi panelovner?
  8. olsbor
    Ifttt
    Porten styres via appen EWeLink. Jeg kjører i dag en webhook via Iphone for å åpne porten ved bruk av Ifttt. Lurer på hvordan jeg kan opprette en switch som styrer denne funksjonen.
  9. olsbor
    Ifttt
    Jeg kjører et applet i Ifttt for å åpne garasjeport. Er det en enkel måte å importere funksjonen inn i Home Assistant?
  10. olsbor
    Duck Dns
    Noen som kan hjelpe meg litt med oppsett av Duckdns? Skal forwarde porter i min Canal Digital ruter, er usikker på om dette blir rett. LAN-IP: 10.0.0.XX er ip til Hass.io (Pi)
  11. olsbor
    Verisure
    Her er oppskriften dersom andre ønsker å få dette til. Koden kan legges til i configuration.yaml. Endre "hovedinngang" med navn på din lås. Husk også å legg inn passordet ditt i secrets.yaml. (verisure_lock_code: "din kode"). #dørlås verisure switch: platform: template switches: yale_lock: friendly_name: 'Lås inngangsdør' value_template: "{{ is_state('lock.hovedinngang', 'locked') }}" turn_on: service: lock.lock data: entity_id: lock.hovedinngang code: !secret verisure_lock_code turn_off: service: lock.unlock data: entity_id: lock.hovedinngang code: !secret verisure_lock_code
  12. Tusen takk for hjelp @ZoRaC! Imponert over tålmodighet og vilje til å hjelpe Fikk lånt en Switch2, den fungerte med en gang. Min enhet går i retur i morgen.
  13. Tok ut Z-way sticken og prøvde kortslutning s1 mot L. Samme feil, lysne på 1 sekund og så av igjen. Kanskje det er LED lysene den ikke støtter, er jo også rimelig liten last.
  14. Helt samme feil dersom jeg kobler bort dimmer - hvor det ikke er noen tilkoblinger på S1 og L. Begynner å tro at det er noe i Home Assistant (Z-way) som sier at releet skal gi en av-på funksjon.
  15. Led, tilsammen 15w.
  16. Det vil ikke ha noe for seg. Lysene har allerede "N", det er kun "L" som brytes. Dimmeren er 1-polt, bryter kun "L" kretsen
  17. Det stemmer. Om jeg kobler bort dimmer og bare kortslutter S1 og L (som funsksjon sompå en bryter) så er det samme feil.
  18. Kan det være en innstilling inne på Home Assistant, som gjør slik at det sendes en av/på impuls? I stede for at det sendes kun en "på-impuls?".
  19. L/N + bryterledning inn på Switch. Og i tillegg dimmer er koblet på switch.
  20. Stod en Elko rs 16 der tidligere. Tenkte det kunne være greit å fortsatt dimme lysene, men å bruke Single Switch for å bare slå av og på lysene ved behov.
  21. Takk for svar, jeg har dobbeltsjekket koblinger så det skal være riktig. Men tar en ekstra sjekk. Har lest om parametre, men klarer ikke helt å se hvor jeg kan endre disse fra home assistant. Har du en enkel forklaring, som ikke er alt for teknisk Tusen takk for hjelp!
  22. Har satt opp en Single Switch 2, som styrer 5 led spotter. Som bryter bruker jeg en dimmer. Har koblet opp iht. koblingsskjema. (Har fagbrev som elektriker og kan dermed utføre slike ting i mitt eget hjem), Når jeg slår på dimmer eller trykker på "b-knappen" så slår bare lysene seg på og så av igjen etter 1 sekund. Er det en form for mode jeg må endre?
  23. olsbor
    Verisure
    Takk for svar Er helt fersk med HA, installerte det førsta i går. Prøvde å søke opp dette via Google men fant ikke noe veldig relevant. Har du noe mer informasjon som kan peke meg i riktig retning, feks. hvor jeg skal legge inn script/automasjon På forhånd tusen takk
  24. olsbor
    Verisure
    Har koblet opp Verisure til systemet, alt fungerer meget bra. Eneste er at jeg skulle ønske jeg slapp å trykke inn koden manuelt hver gang jeg skal åpne dørlåser. Er det noen måte man kan slippe dette på?
  25. olsbor
    Home Assistant
    Det er led spotter jeg skal dimme ja. Har L & N i boksen, så det er fullt mulig. Takk for tips
