Ontrack
Alt skrevet av Ontrack
  1. Ja her må Heatit skjerpe seg, jeg har 12 slike av dimmere og termostater. Basert hele huset på dette. Heatit Thermofloor trenger å gi ut en ny OTA for å få denne funksjonen .
  2. Seint svar, men jeg ha en telegesis Den ser ikkje ut til å samarbeide med aqura/xiaomi serlig godt Går for conbee nå og skal teste den ut
  3. rule "high kwh" when Item TibberLiveAveragePower changed then // If the avarage is above 4800 kWh we need to bring the current usage below 4500w if ((TibberLiveAveragePower.state as Number) > 4800) { var current_w = TibberLiveAveragePower.state as Number // Turn off Stue if (current_w > 4500 && ZWave13ThermostatStueThermostatMode.state == 1) { ZWave13ThermostatStueThermostatMode.sendCommand(0) current_w -= ZWave13ThermostatStueMeterWatts.state as Number } // Turn off bad oppe if (current_w > 4500 && (ZWave14ThermostatBadOEtgThermostatMode.state as Number) == 1) { ZWave14ThermostatBadOEtgThermostatMode.sendCommand(0) current_w -= ZWave14ThermostatBadOEtgMeterWatts.state as Number } // Turn off barnerom oppe if (current_w > 4500 && (ZWave15TermostatBarneromOEtgThermostatMode.state as Number) == 1) { ZWave15TermostatBarneromOEtgThermostatMode.sendCommand(0) current_w -= ZWave15TermostatBarneromOEtgMeterWatts.state as Number } // Turn off Entre if (current_w > 4500 && ZWave17ThermostatGangUEtgSone1ThermostatMode.state == 1) { ZWave17ThermostatGangUEtgSone1ThermostatMode.sendCommand(0) current_w -= ZWave17ThermostatGangUEtgSone1MeterWatts.state as Number } // Turn off kjellergang if (current_w > 4500 && (ZWave16ThermostatGangUEtgSone2ThermostatMode.state as Number) == 1) { ZWave16ThermostatGangUEtgSone2ThermostatMode.sendCommand(0) current_w -= ZWave16ThermostatGangUEtgSone2MeterWatts.state as Number } // Turn off bad nede if (current_w > 4500 && (ZWave22BadUEtgThermostatMode.state as Number) == 1) { ZWave22BadUEtgThermostatMode.sendCommand(0) current_w -= ZWave22BadUEtgMeterWatts.state as Number } // Turn off vaskerom if (current_w > 4500 && (ZWave19ThermostatVaskeromThermostatMode.state as Number) == 1) { ZWave19ThermostatVaskeromThermostatMode.sendCommand(0) current_w -= ZWave19ThermostatVaskeromMeterWatts.state as Number } // Turn off Soverom1 if (current_w > 4500 && (ZWave21ThermostatSoverom1ThermostatMode.state as Number) == 1) { ZWave21ThermostatSoverom1ThermostatMode.sendCommand(0) current_w -= ZWave21ThermostatSoverom1MeterWatts.state as Number } // Turn off Soverom2 if (current_w > 4500 && (ZWave20ThermostatSoverom2ThermostatMode.state as Number) == 1) { ZWave20ThermostatSoverom2ThermostatMode.sendCommand(0) current_w -= ZWave20ThermostatSoverom2MeterWatts.state as Number } // Turn off Soverom3 if (current_w > 4500 && (ZWave18ThermostatSoverom3ThermostatMode.state as Number) == 1) { ZWave18ThermostatSoverom3ThermostatMode.sendCommand(0) current_w -= ZWave18ThermostatSoverom3MeterWatts.state as Number } // Turn off Varmtvannsbereder if (current_w > 4500 && (ZWave23PowerVVTSwitchBinary.state as Number) == ON) { ZWave23PowerVVTSwitchBinary.sendCommand(OFF) current_w -= ZWave23PowerVVTMeterWatts.state as Number } } end rule "low kwh" when Item TibberLiveAveragePower changed then //logDebug("ams", "LOW KWH START") // If the avarage is below 4600 kWh we can start to bring the current usage up to (max) 6000w if ((TibberLiveAveragePower.state as Number) < 4600) { var current_w = TibberLiveAveragePower.state as Number // Turn on stue if (current_w < 6000 && ZWave13ThermostatStueThermostatMode.state == 0) { ZWave13ThermostatStueThermostatMode.sendCommand(1) current_w += 2470 // Estimate 2470w for now } // Turn on bad oppe if (current_w < 6000 && (ZWave14ThermostatBadOEtgThermostatMode.state as Number) == 0) { ZWave14ThermostatBadOEtgThermostatMode.sendCommand(1) current_w += 925 } // Turn on barnerom oppe if (current_w < 6000 && (ZWave15TermostatBarneromOEtgThermostatMode.state as Number) == 0) { ZWave15TermostatBarneromOEtgThermostatMode.sendCommand(1) current_w += 489 } // Turn on entre if (current_w < 6000 && ZWave17ThermostatGangUEtgSone1ThermostatMode.state == 0) { ZWave17ThermostatGangUEtgSone1ThermostatMode.sendCommand(1) current_w += 605 } // Turn on kjellergang if (current_w < 6000 && ZWave16ThermostatGangUEtgSone2ThermostatMode.state == 0) { ZWave16ThermostatGangUEtgSone2ThermostatMode.sendCommand(1) current_w += 1327 } // Turn on bad nede if (current_w < 6000 && ZWave22BadUEtgThermostatMode.state == 0) { ZWave22BadUEtgThermostatMode.sendCommand(1) current_w += 526 } // Turn on vaskerom if (current_w < 6000 && ZWave19ThermostatVaskeromThermostatMode.state == 0) { ZWave19ThermostatVaskeromThermostatMode.sendCommand(1) current_w += 561 } // Turn on soverom1 if (current_w < 6000 && ZWave21ThermostatSoverom1ThermostatMode.state == 0) { ZWave21ThermostatSoverom1ThermostatMode.sendCommand(1) current_w += 741 } // Turn on soverom2 if (current_w < 6000 && ZWave20ThermostatSoverom2ThermostatMode.state == 0) { ZWave20ThermostatSoverom2ThermostatMode.sendCommand(1) current_w += 737 } // Turn on soverom3 if (current_w < 6000 && ZWave18ThermostatSoverom3ThermostatMode.state == 0) { ZWave18ThermostatSoverom3ThermostatMode.sendCommand(1) current_w += 822 } // Turn on Varmtvannsbereder if (current_w < 6000 && ZWave23PowerVVTSwitchBinary.state == OFF) { ZWave23PowerVVTSwitchBinary.sendCommand(ON) current_w += 3000 } } end
  4. Bruker Oh selv og har sett litt på dette, men jeg tror må legge meg på 5-10kw grensen. 5kw blir for trangt med 5 i familien og kun el oppvarming (varmekabler) Å kunne unngå fx at alle varmekablene er inne samtidigt, eller at de jobber i tandem uten at det kan bli for kaldt i enkelte rom. Der en ender opp med kabler som må ta igjenn det tapte over lang tid.
  5. Noen her som har laget noen regler for efekktledd handtering? Eller en regel som sørger for at ikkje alle varmekabler og eller varmtvannstank slår inn samtidigt for å unngå effektledd stigning?
  6. Har startet en dusør for å få laget en Tibber Binding for OH https://www.bountysource.com/issues/71944325-start-building-tibber-binding-for-openhab
  7. Er offshore, hjemme 13. Hopp over meg om det ikke passer
  8. Hei, vil gjerne låne kabelen, har 2stk (multireg zwave) regner den er samme som heatit
