Brian P
Alt skrevet av Brian P
  1. Perhaps has to do with the interval HA is updating the element status data?
  2. This was my issue. Had to download two separate .zip files to complete the repo. Uploaded both directory and subdirectory to config/custom_components/climate folder (with /pynobo subfolder) Config file works. Will continue to test after back from travelling in two weeks.
  3. Jag ska prova att byta code av nobo_hub.py som här: https://github.com/home-assistant/home-assistant/issues/8051
  4. Apologies, I'm very new to the HA environment and am not really a programmer. I tried installing the repo through configurator/samba share (I'm not a python programmer) by doing the following: Cloned the repo https://github.com/echoromeo/hanobo similar to what is suggested here: https://github.com/custom-components/climate.e_thermostaat config/custom_components/climate/<cloned HAnobo repo here> Put the put the following in my config/configuration.yaml file: # Nobø Energy Control climate: platform: nobo_hub # host: [your nobø serial] # You can use the 3 last digits if using discovery IP_ADDRESS: 10.24.1.79 Saved changes Soft and hard rebooted multiple times Home assistant's check config says: Configuration invalidCHECK CONFIG Platform not found: climate.nobo_hub Any thoughts on what i'm doing wrong?
  5. Jag ska prova den idag i HA. Jag är ny till HA, så jag hoppas alt fungerar okej. Om där är en HA official component, Jag är glad att prova den också.
