hkmod25
Alt skrevet av hkmod25
  1. Her er 2 Vannbåren Varme Kontrollere fra Danfoss: https://www.tronika.no/no/zwave-klimastyring/1058-vannbaren-varme-kontroller.html Her er Z-Water: https://www.tronika.no/no/zwave-klimastyring/1060-din-rail-regulator-z-water.html
  2. Her er link til "Danalock Toolbox": https://play.google.com/store/apps/details?id=com.polycontrol.danalocktoolbox Brukes for FirmWare oppdatering av Danalock V3 enheter.
  3. Forandrer du antall av paral. koblede Dallas temp. probes så må FGB enheten re-inkluderes på nytt.
  4. Danalock har kommet med følgende informasjon til alle brukere av Danalock V3 låsen: Dear Danalock User, We have unfortunately received a bad batch of batteries, and unfortunately your lock contains these batteries. As the batteries will drain quickly we wish to send you new batteries. With this batch there is a minimal risk of overheating, and we therefore request you to remove the batteries from the Danalock, and wait for the new batteries to arrive before you continue to use your Danalock. Please forward your address to [email protected] and we will send you new batteries. The new batch of batteries will arrive next week, and immediately after the reception we will ship out new batteries to the address you provided. We are very sorry for the inconvenience, but we are sure you will be very happy with the Danalock going forward with new batteries :-) Thank you. Best regards, Team Danalock I tillegg til dette sier de om Danalock V3, BT + Z-Wave versjon: "Besides the bad batteries, we discovered a minor bug in the Z-Wave FW that prevents the Danalock to go to sleep, which means the battery will drain very fast. With these two issues combined the batteries will most likely drain within 14 days on locks with Z-Wave – 1-2 months for BT locks. This is very unfortunate and frustrating, and we hope for your help to exchange the batteries. We will receive a new batch of batteries next week, and we expect the new FW to be upgradable from the app at the same time."
  5. "Up to 200":
  6. Det er vel ingen prob. å bruke ImperiHome med VERA: http://www.evertygo.com/imperihome https://play.google.com/store/apps/details?id=com.imperihome.lite.unlockerpro
  7. ZSC-01DW har nå mulighet til å bli inkludert som en SECURE device (og etter det bli assosiert med "secure" noder).
  8. Available 2018. Dvs. ganske ubestemt dato...
  9. Kabling for Aeotec ZW100 sensorer skal bli mye mer komplisert om en skal installere flere. Og alle skal drives av (bare en ?) ekstern strømforsyning.
  10. Du har vel kjøpt en LISENS så lenge du bruker Z-Way soft med UZB1 stick?
  11. Det er vel derfor jeg har påpekt: Z-Wave Plus baserte enheter...
  12. Jeg håper at du er klar ang. advarsel fra Qubino (Z-Wave Plus baserte enheter): "WARNING: Service button S must NOT be used when module is connected to 110-230V power supply."
  13. En "standard" feil med dørlåser er at brukeren monterer den først på døren og etterpå prøver å inkludere den i "systemet". Her er avstand ganske viktig...
  14. https://www.tronika.no/no/x10-sikkerhet/237-alarmpakke-rex-10.html
  15. Forklaring til dette kan bli at f. eks. enh. nr. 92 i motsetning av enh. 91 fulførte ikke komplett "interwiev" med HomeSeer. (Viktig) om du inkluderer enh. som "secure" noder - avstand mellom enheten og MASTER CONTROLLER (ved inkludering) må bli kort (da blir det mindre risiko for "Time Out")...
  16. hkmod25
    Fibaro
    Dette er vel interessant og kan undersøkes (bekreftes). Men han snakker ikke akk. om dette.
  17. hkmod25
    Fibaro
    For meg ser dette logisk ut så lenge SOURCE device kan ikke få status oppdatering at DESTINATION device ble satt i "motsatt" stilling av en 3-e enhet.
  18. hkmod25
    Fibaro
    Dette er vel mulig men farlig. En må ha 100% kontroll på N og L ledere for de forskjellige dimmere (som igjen står på det samme kurs) for å ikke lage en kortsluttning, så lenge Sx har 230V spenning (om jeg husker det 99%, fra L leder koblet intern)...
  19. Tror du kommer alt for hard mot Telldus. :-) VERA er et internasjonal selskap med mangeårig erfaring og MIOS som "motor" leverandør: http://www.mios.com/ Telldus sans. bruker et eller annet china basert selskap som har ansvar for softvare utvikling...
  20. Du kan starte å lese herfra: http://manuals.fibaro.com/motion-sensor/ Adding to the network . 3. Place the Motion Sensor within the direct range of your Z-Wave controller. Osv. (ned til SUPPORT, FAQ)
  21. Nei. Dette er ikke et krav. Finnes en del Z-Wave Plus enheter som støtter ikke S0 security (f. eks. Nodon, noen fra Aeotec,...)...
  22. Ja. Ellers: FGS-212 - Z-Wave, FGS-213 - Z-Wave Plus.
  23. FGS-213 er også et relé. Forskjellen fra FGS-212 er at FGS-213 har ikke potensialfri rele utgang (som FGS-212). 230V tilkoblet intern til relé kontakten (noe enklere kobling om en skal ha 230V på utgangen).
  24. OK, viste ikke at HA verden begrenses av HomeSeer ene og alene...
  25. Punkt 3 er ikke helt riktig. Sans. skal se slik ut: 3. Hvis en enhet støtter secure og du velger "Add/include node as SECURE", så vil den bli lagt som secure, velger du "Add/include node as NON-SECURE", så vil den bli lagt som non-secure. Noen produsenter (Aeotec, Popp, Z-Wave.Me f. eks.) i tillegg krever bestemt antall "klikk" ved inkludering for å definere "secure" eller "non-secure" inkludering.
