stuntteam
Alt skrevet av stuntteam
  1. RFLink Gateway versjon 45 lansert! R45 Changelog: - New Device: Silvercrest switch set IAN276299 - New Device: Silvercrest switch set IAN113854 - New Device: Silvercrest switch set IAN91210 - New Device: Quigg switch set GT-9000 (Tevion/Globaltronics/ALDI) - New Device: Unitec switch set 4811 model 50028 (Intertek) - New Device: Cotech switch set 36-6361 - New Device: Sartano switch set, Model 50028, HN 10047 - New Device: Electro Depot switch set, article code 940557 - New Device: BL999 weather sensor - New Device: Digi-Tech 4-LD14554 Outdoor temperature sensor (Thanks: PJA) - New Device: PLC-T4022G X10 RF to Powerline - New Device: X10 UR76 E Remote Control - New Device: Konig Alarm system sensors - New Device: Alecto 1200 alternative protocol version - New Device: Oregon EW99 - New Device: Smartwares RM174RF Smoke detector - New Device: FirstLine FWS802 Pool Thermometer (Thanks: BC) - New Device: Liwin Shutters / Blinds controller - Fixed: MiniGPIO command structure - Fixed: Conrad RSL pair command added - Fixed: Warema EWFS (Thanks: SH) - Fixed: Removed Ningbo debug message - Fixed: Mebus protocol detection for Auriol Z29536 IAN55982 - Fixed: Removed debug messages on Atlantic protocol - Fixed: Milight color and brightness changing on groups - Fixed: DKW2012 Humidity conversion - Fixed: DKW2012 Wind speed conversion (Thanks: HJ) - Fixed: Xiron ID sometimes had an incorrect bit - Fixed: Blyss/Avidsen transmit - Fixed: Aster protocol split on/off and dim/bright into separate devices - Fixed: Improved detection of WH5029 - Fixed: Improved HE800 protocol detection - Fixed: Improved detection of Cleverwatts, Kerui and compatible devices - Fixed: Proper handling of incoming serial commands for KAKU and related devices - Fixed: Improved Chacon EMW200 detection - Added: RTS protocol option to swap ON/OFF command - Added: RTS long TX option to extend the RTS transmit time - Added: "Settings reset" feature - Added: Extended Gaposa protocol - Added: Lacrosse V3 protocol support for negative temperature values Available on www.nemcon.nl/blog2 Enjoy!
