prnordmarken
Alt skrevet av prnordmarken
  1. Mye av grunnet til at jeg kjøpte homeseer er dette scriptet. Men jeg bruker det til og styre lys i hønsehus og det skal IKKE stoppe. Ser at det hender det stopper opp. Er det slik at om jeg fjerner det jeg klippet ut her så bare går det? ' Need to declare this so that I don't bail at the first iteration dim Previouslevel as integer = Startvalue for each cc as HomeSeerAPI.CAPIControl in hs.CAPIGetControl(deviceRef) for Newlevel as integer = Startvalue to Stopvalue step DeltaValue ' Check if there is an override - i.e. the device has been changed outside the script if ((hs.DeviceValue(deviceRef) = Previouslevel) orElse (Previouslevel = Startvalue)) then ' Set the correct dim level cc.ControlValue = Newlevel hs.CAPIControlHandler(cc) ' Wait the required amount of time System.Threading.Thread.Sleep(Waittime) Previouslevel = Newlevel else ' Manual override - You openend the pod bay doors yourself :-/ if writeLog then hs.WriteLog("ChangeDimmer", deviceName & " - Manual override, bailed out at " & Previouslevel & "%") exit sub end if next
