AG78
Alt skrevet av AG78
  1. Hi Frankis, Thanks for helping me. There is no specific command, it generally accepts the first command and then goes into the error state that the SensiboClimate is down and is not running. During this point no other commands will work. I am using degree C. Anything else I can try? Thanks so much for your ongoing support.
  2. Hi, Thanks for your reply. I can confirm that I only have the SensiboConfigpanel.xml file in the config folder. My API key is still there. I deleted all the devices and they recreated themselves fine again. I am just using it from the device list at the moment to test and have not created any events. Whilst some commands do actually work it appears to not be reliable and not all the commands will send and work. I'm using homeseer version 3.0.0.500 on Windows 10 with the latest updates. May-05 3:09:52 PM Info Plugin SensiboClimate with instance: has disconnected May-05 3:09:47 PM SensiboClimate Debug Get AC Id for device #0 is done: 5 May-05 3:09:47 PM Device Control Device: Ground Floor Ground Floor AC Change Mode to Off (0) by/from: CAPI Control Handler May-05 3:09:45 PM Info Plugin SensiboClimate has connected. IP:127.0.0.1:63624 May-05 3:09:45 PM Warning I/O interface SensiboClimate is down, executable is not running, restarting ... May-05 3:09:28 PM Error Calling SetIOMulti in plugin SensiboClimate:Object reference not set to an instance of an object. May-05 3:09:28 PM Device Control Device: Ground Floor Ground Floor AC Change Mode to Off (0) by/from: CAPI Control Handler May-05 3:09:21 PM Info Plugin SensiboClimate with instance: has disconnected May-05 3:09:14 PM Info Plugin SensiboClimate has connected. IP:127.0.0.1:63587 May-05 3:09:14 PM Warning I/O interface SensiboClimate is down, executable is not running, restarting ... May-05 3:09:09 PM Info Plugin SensiboClimate with instance: has disconnected May-05 3:09:03 PM SensiboClimate Debug Get AC Id for device #5 is done: 6 May-05 3:09:03 PM Device Control Device: Ground Floor Ground Floor AC Change Mode to Heat (5) by/from: CAPI Control Handler What else can I try to hopefully get this resolved? Appreciate your help once again. Thanks
  3. Hi, I wanted to say a big thank you for developing this plugin. I have been unsuccessful in getting it to work properly. Every time I try and use an option to turn it on or off or change a parameter it keeps failing. This is my log file. Apr-27 10:19:07 AM Info Plugin SensiboClimate has connected. IP:127.0.0.1:57342 Apr-27 10:19:06 AM Warning I/O interface SensiboClimate is down, executable is not running, restarting ... Apr-27 10:18:42 AM Info Plugin SensiboClimate with instance: has disconnected Apr-27 10:18:35 AM Info Plugin SensiboClimate has connected. IP:127.0.0.1:57302 Apr-27 10:18:35 AM Warning I/O interface SensiboClimate is down, executable is not running, restarting ... Apr-27 10:18:04 AM Info Plugin SensiboClimate has connected. IP:127.0.0.1:57266 Apr-27 10:18:04 AM Warning I/O interface SensiboClimate is down, executable is not running, restarting ... Apr-27 10:17:39 AM Info Plugin SensiboClimate with instance: has disconnected Apr-27 10:17:32 AM Warning I/O interface SensiboClimate is down, executable is not running, restarting ... Apr-27 10:17:19 AM Error Calling SetIOMulti in plugin SensiboClimate:Object reference not set to an instance of an object. Apr-27 10:17:19 AM Device Control Device: Ground Floor Ground Floor AC Change Mode to Off (0) by/from: CAPI Control Handler Apr-27 10:17:08 AM Info Plugin SensiboClimate with instance: has disconnected Apr-27 10:17:01 AM Info Plugin SensiboClimate has connected. IP:127.0.0.1:57184 Apr-27 10:17:01 AM Warning I/O interface SensiboClimate is down, executable is not running, restarting ... Apr-27 10:16:56 AM Error Calling SetIOMulti in plugin SensiboClimate:Object reference not set to an instance of an object. Apr-27 10:16:56 AM Device Control Device: Ground Floor Ground Floor AC Change Swing to Stopped (0) by/from: CAPI Control Handler Apr-27 10:16:36 AM Info Plugin SensiboClimate with instance: has disconnected Apr-27 10:16:30 AM Info Plugin SensiboClimate has connected. IP:127.0.0.1:57144 Apr-27 10:16:30 AM Warning I/O interface SensiboClimate is down, executable is not running, restarting ... Apr-27 10:16:25 AM Info Plugin SensiboClimate with instance: has disconnected Apr-27 10:16:18 AM SensiboClimate Debug Get AC Id for device #3 is done: 4 Apr-27 10:16:18 AM Device Control Device: Ground Floor Ground Floor AC Change Swing to Both (3) by/from: CAPI Control Handler Any help you can provide would be greatly appreciated. I am running the latest version 1.2.0.2 Thanks to everyone.
