Lasse Magnussen
Alt skrevet av Lasse Magnussen
  1. Fikk det til å funke; resatte key, fjernet node fra HA og la den til på nytt. Resatte også IdLock zwave modulen. Tusen takk for feedback!
  2. Ok, jeg skal gjøre et ekstra forsøk. Det sagt jeg unpair'et låsen fra sticken (ved å trykke på knappen i 2 sek til den blinket gult for så å kjøre *2*5 rutina på låsen) Jeg har opprettet egen network key. Her er en bit av loggen fra når jeg brukte Add Secure Node: 2019-04-06 17:37:28.626 Info, Adding node ID 3 - Secure 2019-04-06 17:37:28.627 Detail, Notification: ControllerCommand - InProgress 2019-04-06 17:37:28.933 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x05, 0x03, 0x00, 0xbe 2019-04-06 17:37:28.933 Detail, 2019-04-06 17:37:28.933 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK: 2019-04-06 17:37:28.933 Info, ADD_NODE_STATUS_PROTOCOL_DONE 2019-04-06 17:37:28.933 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4 2019-04-06 17:37:28.933 Detail, Notification: ControllerCommand - InProgress 2019-04-06 17:37:28.933 Detail, 2019-04-06 17:37:28.933 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4 2019-04-06 17:37:28.985 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x06, 0x03, 0x00, 0xbd 2019-04-06 17:37:28.986 Detail, 2019-04-06 17:37:28.986 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK: 2019-04-06 17:37:28.986 Info, contrlr, ADD_NODE_STATUS_DONE 2019-04-06 17:37:28.986 Info, Node003, Basic device class (0x04) - Routing Slave 2019-04-06 17:37:28.986 Info, Node003, Generic device Class (0x40) - Entry Control 2019-04-06 17:37:28.986 Info, Node003, Specific device class (0x03) - Secure Keypad Door Lock 2019-04-06 17:37:28.986 Info, Node003, COMMAND_CLASS_BASIC will be mapped to COMMAND_CLASS_DOOR_LOCK 2019-04-06 17:37:28.986 Info, Node003, Mandatory Command Classes for Node 3: 2019-04-06 17:37:28.986 Info, Node003, COMMAND_CLASS_BASIC 2019-04-06 17:37:28.986 Info, Node003, COMMAND_CLASS_DOOR_LOCK 2019-04-06 17:37:28.986 Info, Node003, COMMAND_CLASS_USER_CODE 2019-04-06 17:37:28.986 Info, Node003, COMMAND_CLASS_MANUFACTURER_SPECIFIC 2019-04-06 17:37:28.986 Info, Node003, COMMAND_CLASS_VERSION 2019-04-06 17:37:28.986 Info, Node003, COMMAND_CLASS_SECURITY 2019-04-06 17:37:28.986 Info, Node003, Mandatory Command Classes controlled by Node 3: 2019-04-06 17:37:28.986 Info, Node003, None 2019-04-06 17:37:28.986 Detail, Node003, Queuing (Security) SecurityCmd_SchemeGet (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x98, 0x04, 0x00, 0x25, 0x0b, 0x54 2019-04-06 17:37:28.986 Info, Node003, Optional command classes for node 3: 2019-04-06 17:37:28.986 Info, Node003, COMMAND_CLASS_ZWAVEPLUS_INFO 2019-04-06 17:37:28.986 Info, Node003, COMMAND_CLASS_MANUFACTURER_SPECIFIC (Existing) 2019-04-06 17:37:28.986 Info, Node003, COMMAND_CLASS_SECURITY (Existing) 2019-04-06 17:37:28.987 Info, Node003, COMMAND_CLASS_DEVICE_RESET_LOCALLY 2019-04-06 17:37:28.987 Info, Node003, COMMAND_CLASS_POWERLEVEL 2019-04-06 17:37:28.987 Info, Node003, COMMAND_CLASS_CONFIGURATION 2019-04-06 17:37:28.987 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1 2019-04-06 17:37:28.987 Detail, Node003, QueryStage_ProtocolInfo 2019-04-06 17:37:28.987 Detail, Node003, Queuing (Query) Get Node Protocol Info (Node=3): 0x01, 0x04, 0x00, 0x41, 0x03, 0xb9 2019-04-06 17:37:28.987 Detail, Node003, Queuing (Query) Query Stage Complete (ProtocolInfo) 2019-04-06 17:37:28.987 Info, Node003, Initializing Node. New Node: true (true) 2019-04-06 17:37:28.987 Detail, Node006, Expected reply was received 2019-04-06 17:37:28.987 Detail, Node006, Message transaction complete
  3. Hei! Er det noen som kan gi meg en status på hvordan dette funker pr. i dag? Jeg har satt opp IdLock 150 mot Home Assistant 0.90.2 med zwave network key osv. Låsen kommer opp, men jeg får ikke brukt lock/unlock kommandoene. Jeg la til låsen via `Add Secure Node` (gjorde vom. feil først og gjorde dette via usb-sticken, Z-Stick Gen 5). Gjorde reset på IdLock modulen og la til på nytt etter å ha slettet alle HA zwave innstillingene. Får som regel responser ala denne: 2019-04-06 17:45:23.701 Error, Node003, ERROR: Dropping command, expected response not received after 1 attempt(s)
