Alt skrevet av howi
Her er litt info : RauchWohn homely Fire (binary_sensor.rauchwohn_homely_fire) MQTT discovery data: Topic: homeassistant/binary_sensor/edeffb64-fac3-4f02-845e-6f5ea98bdb0f/fire/config Payload device: identifiers: - edeffb64-fac3-4f02-845e-6f5ea98bdb0f name: RauchWohn sw_version: 1 model: Intelligent Smoke Alarm manufacturer: Homely hw_version: 1 suggested_area: Floor 1 - Wohnzimmer unique_id: edeffb64-fac3-4f02-845e-6f5ea98bdb0f_fire name: homely Fire device_class: smoke unit_of_measurement: null state_class: null command_topic: null config_topic: homeassistant/binary_sensor/edeffb64-fac3-4f02-845e-6f5ea98bdb0f/fire/config availability_topic: homeassistant/edeffb64-fac3-4f02-845e-6f5ea98bdb0f/online state_topic: homeassistant/edeffb64-fac3-4f02-845e-6f5ea98bdb0f/fire/state platform: mqtt Subscribed topics: homeassistant/edeffb64-fac3-4f02-845e-6f5ea98bdb0f/online 7 most recently received message(s) homeassistant/edeffb64-fac3-4f02-845e-6f5ea98bdb0f/fire/state 0 most recently received message(s) Som du ser, de kommer aldri en message ang. 'fire/state'
Spørsmål: Ser jeg det riktig at ditt image husker hvilken devices har blitt laget i HA ? Vil si, sletter jeg en device i HA, må jeg restarte containeren ?
På HA siden er det ingen forandring. I portainer loggen ser jeg alle devicene.
Ok, tror den er bedre, håper jeg ... test
Selv de som er der, er bare delvis korrekt : RauchWohn har alltid state: Unknown Alarm Motion Sensor 2 har bare 2 entities, det skulle ha vært også entities ang. battery
Her er en fil. Devices in HA : Alarm Motion Sensor 2 Flood Alarm HitzeKueche RauchWohn Alle andre dukker opp i filen, men ikke i HA. Røykmelder : RauchFlurUnten RauchSchlaf RauchWerkstatt Gateway _laughing_khayyam_logs (6).txt
Jeg har litt problemer å få ut den loggen som du trenger. Men jeg ser dette : [11:56:16.799] DEBUG (1): [DB][[object Object]ms] Executing (default): SELECT `id`, `home_id` AS `homeId`, `location`, `model_id` AS `modelId`, `model_name` AS `modelName`, `name`, `serial_number` AS `serialNumber`, `created_at` AS `createdAt`, `updated_at` AS `updatedAt` FROM `devices` AS `HomelyDevice` WHERE `HomelyDevice`.`id` = 'adf357c0-70eb-47e1-884c-df949903e0de'; [11:56:16.805] DEBUG (1): Device found: RauchWerkstatt [11:56:16.809] DEBUG (1): [DB][[object Object]ms] Executing (default): SELECT `id`, `device_id_suffix`, `device_id`, `state_class`, `command_topic`, `published`, `icon`, `path`, `unit`, `format`, `type`, `name`, `device_class`, `entity_category`, `config_topic`, `availability_topic`, `state_topic`, `created_at` AS `createdAt`, `updated_at` AS `updatedAt` FROM `features` AS `HomelyFeature` WHERE `HomelyFeature`.`device_id_suffix` = 'adf357c0-70eb-47e1-884c-df949903e0de_temperature' LIMIT 1; Men ingen device in HA.
Fire er nok en magisk grense. Jeg slettet alle devices in HA og startet containeren på nytt. De første fire devices som sender noe, ble lagt in korrekt, resten ser jeg i MQTT loggen, men ser også at det aldri ble lagt en device til de. ( og de første fire er nok ikke det samme hver gang jeg startet helt på nytt ) Bare for å nevne det : Hvis jeg bruker kolaf sin integrasjon ( 0.1.5), kommer alle røykmeldere korrekt inn, men ingenting annet.
Er dette viktig ? (node:1) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead. (Use `node --trace-deprecation ...` to show where the warning was created)
Payload info kan jeg lage i morgen. Litt info ellers: Alarm status kommer korrekt til HA, men ingen device blir laget. Jeg ser meldinger fra flere røykvarsler i HA, men ingen device blir laget. Heat sensor blir et komplett device, samme for en røykvarsler og en dørsensor. En annen røykvarsler har bare en eneste entity, 'fire', men med korrekt state. Den neste røykvarsler har alle entities, men 'fire' forblir unknown, alle andre entities are ok. (alle røykvarsler er av samme typen) Mini Plugger dukker ikke opp. Sirener dukker ikke opp. Motion sensor har jeg ikke satt opp endå. Selve gatewayen dukker ikke opp.
Skal se etter. Her er forskjellen mellomen som finnes i HA og en som ikke finnes : [18:21:46.512] INFO (1): Publishing state for Temperature [18:21:46.512] INFO (1): topic: "homeassistant/adf357c0-70eb-47e1-884c-df949903e0de/temperature/state" message: 17.4 opts: { "qos": 1, "retain": true } [18:21:46.513] INFO (1): topic: "homeassistant/020000010000E23F/armed/state" message: "disarmed" opts: { "qos": 1, "retain": true } gateway status blir aldri published.
Neste ville ha vært en røykmelder. Hvis jeg forandrer rekkefølegen i Homely appen, har det ingen betydning, det samme fire enheter blir fremdeles oppdatert og det kommer ingen nye. Om jeg starter HA nå på nytt, ingen forandring. Starter jeg containeren på nytt etter jeg har forandret rekkefølgen, blir ingenting i HA oppdatert mer. Sletter jeg all enheter i HA, kommer det inn noe igjen, men de samme som før. Men : Det er åpenbart en forskjell med enabled: true og enabled: false. Med setting 'false' ser jeg alt jeg har i Homely i containerloggen, med setting 'true' er det helt annerledes, vil si, i loggen ser jeg bare de som senere dukker opp i HA. Aldri med i HA er Gateway status.
Det funker, men med det samme begrensninger som andre har sett. Bare fire enheter dukker opp i HA. de fire første i Homely appen. Hos meg er det Alarm entry sensor 2 Intelligent smoke alarm ( 2 ) Intelligent Heat alarm I container loggen finner jeg resten og, men ikke i HA.
Takk for hjelpen. Nå ser jeg MQTT meldinger i logfilen og jobber videre med det. Eksempel : [10:05:01.804] INFO (1): Publishing state for Temperature [10:05:01.804] INFO (1): topic: "homeassistant/adf357c0-70eb-47e1-884c-df949903e0de/temperature/state" message: 13.3 opts: { "qos": 1, "retain": true }
Jeg forstår. Har ikke nok erfaring med Dokker eller Portainer. Problemet mitt er at jeg finner ingen mulighet å legge det til noen plass. Portainer henter bare hele pakken og gir meg mulighet å kjøre det.
Jeg kjører homely-mqtt i Portainer og få dette : WARNING: No configurations found in configuration directory:/app/dist/config WARNING: To disable this warning set SUPPRESS_NO_CONFIG_WARNING in the environment. /app/node_modules/config/lib/config.js:179 throw new Error('Configuration property "' + property + '" is not defined'); ^ Error: Configuration property "logLevel" is not defined at Config.get (/app/node_modules/config/lib/config.js:179:11) at Object.<anonymous> (/app/dist/utils/logger.js:9:35) at Module._compile (node:internal/modules/cjs/loader:1256:14) at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) at Module.load (node:internal/modules/cjs/loader:1119:32) at Module._load (node:internal/modules/cjs/loader:960:12) at Module.require (node:internal/modules/cjs/loader:1143:19) at require (node:internal/modules/cjs/helpers:121:18) at Object.<anonymous> (/app/dist/index.js:17:18) at Module._compile (node:internal/modules/cjs/loader:1256:14) Node.js v18.17.1 Hva kan jeg gjøre nå ?
@gert Den addon du har satt sammen, er det noe som kan prøves ut ?
Trenger også litt hjelp. Prøvde med på versjon 0.1.5 fra @kolaf. Jeg ser bare alle røykvarsler, status, heat sensor og dørsensorene mangler. Er den versjonen fremdeles det som skal ( kan ) brukes eller er det noe annet jeg kan prøve meg på ? Dørsensorene og status hadde vært det som trengs.
Jeg forsøker å finne ut hva forskjellen mellom Homely sentralen versjon 1 og 2 er. Kan noen hjelpe meg med det ? Vil si, er det et problem å kjøpe en brukt versjon 1 ?
Strømstøtte fra og med september 2023
howi svarte på stigvi sitt emne i Strømsparing og strøm-overvåkning
Jeg må bare spørre : Hvordan gjorde du dette : "Template for additional cost" via webinterface -
Først, en sensor : med som eksempel en query for 'cost' og 'consumption' , 'MONTHLY' og 12 måneder rest: - resource: "https://api.tibber.com/v1-beta/gql" scan_interval: 3600 method: POST payload: '{"query": "{ viewer { homes { consumption (resolution: MONTHLY, last: 12) { nodes { from cost consumption } }} } } "}' headers: Authorization: !secret tibberAuthorization Content-Type: application/json sensor: - name: tibber_monat_date_1 value_template: '{{ value_json.data.viewer.homes.0.consumption.nodes.0.from }} ' json_attributes: - "data" Resultat ( sensor attributes ) blir dette : Attributes Data viewer: homes: - consumption: nodes: - from: '2021-12-01T00:00:00.000+01:00' cost: 6337.83502785 consumption: 2855.022 - from: '2022-01-01T00:00:00.000+01:00' cost: 3693.5323019 consumption: 2091.36 - from: '2022-02-01T00:00:00.000+01:00' cost: 2890.0519197125 consumption: 1897.162 - from: '2022-03-01T00:00:00.000+01:00' cost: 3269.835485575 consumption: 1390.317 - from: '2022-04-01T00:00:00.000+02:00' cost: 2759.9224379625 consumption: 1259.916 - from: '2022-05-01T00:00:00.000+02:00' cost: 2073.228999575 consumption: 964.274 - from: '2022-06-01T00:00:00.000+02:00' cost: 770.6099757625 consumption: 308.307 - from: '2022-07-01T00:00:00.000+02:00' cost: 2757.3187822125 consumption: 850.927 - from: '2022-08-01T00:00:00.000+02:00' cost: 2451.6382636875 consumption: 507.456 - from: '2022-09-01T00:00:00.000+02:00' cost: 2562.2602708625 consumption: 591.231 - from: '2022-10-01T00:00:00.000+02:00' cost: 2688.7950699875 consumption: 1562.747 - from: '2022-11-01T00:00:00.000+01:00' cost: 2278.7636694125 consumption: 1610.012 Nå mangler bare et apex-chart : type: custom:apexcharts-card graph_span: 365d yaxis: - id: first min: 0 max: 8000 decimals: 0 - id: second min: 0 max: 3000 decimals: 0 opposite: true header: title: Kosten - Verbrauch (12 Mon ) show: true show_states: false series: - entity: sensor.tibber_monat_date_1 type: column name: Kosten show: legend_value: false yaxis_id: first data_generator: > return entity.attributes.data.viewer.homes[0].consumption.nodes.map((start, index) => { return [new Date(start["from"]).getTime(), entity.attributes.data.viewer.homes[0].consumption.nodes[index]["cost"]]; }); - entity: sensor.tibber_monat_date_1 type: column name: Verbrauch show: legend_value: false yaxis_id: second data_generator: > return entity.attributes.data.viewer.homes[0].consumption.nodes.map((cost, index) => { return [new Date(cost["from"]).getTime(), entity.attributes.data.viewer.homes[0].consumption.nodes[index]["consumption"]]; });
- 4 svar
Jeg kommer med en beskrivelse litt senere i kveld.
- 4 svar
Hei, jeg har laget meg en sensor via Tibber APIen som har disse attributtene : Attributes Data viewer: homes: - consumption: nodes: - from: '2021-11-01T00:00:00.000+01:00' cost: 2444.0790312625 consumption: 1774.194 - from: '2021-12-01T00:00:00.000+01:00' cost: 6337.83502785 consumption: 2855.022 - from: '2022-01-01T00:00:00.000+01:00' cost: 3693.5323019 consumption: 2091.36 - from: '2022-02-01T00:00:00.000+01:00' cost: 2890.0519197125 consumption: 1897.162 - from: '2022-03-01T00:00:00.000+01:00' cost: 3269.835485575 consumption: 1390.317 - from: '2022-04-01T00:00:00.000+02:00' cost: 2759.9224379625 consumption: 1259.916 - from: '2022-05-01T00:00:00.000+02:00' cost: 2073.228999575 consumption: 964.274 - from: '2022-06-01T00:00:00.000+02:00' cost: 770.6099757625 consumption: 308.307 - from: '2022-07-01T00:00:00.000+02:00' cost: 2757.3187822125 consumption: 850.927 - from: '2022-08-01T00:00:00.000+02:00' cost: 2451.6382636875 consumption: 507.456 - from: '2022-09-01T00:00:00.000+02:00' cost: 2562.2602708625 consumption: 591.231 - from: '2022-10-01T00:00:00.000+02:00' cost: 2688.7950699875 consumption: 1562.747 Jeg vil lage meg en Apex-chart med 'cost' og 'consumption', men har problemer med å få access til dataene korrekt. Som eksempel har jeg noe lignende med Nordpool-data, men sliter med data generatoren. Eksempel som fungerer bra : type: custom:apexcharts-card experimental: color_threshold: true graph_span: 24h header: title: Strompreis Morgen show: true span: start: day offset: +1d series: - entity: sensor.nordpool_kwh_krsand_nok_3_10_025 type: column data_generator: | return entity.attributes.raw_tomorrow.map((start, index) => { return [new Date(start["start"]).getTime(), entity.attributes.raw_tomorrow[index]["value"]]; }); color_threshold: - value: 0 color: green opacity: 1 - value: 3 color: yellow - value: 6 color: red Noen som kan hjelpe med med generator formuleringen ?
howi svarte på roarfred sitt emne i Strømsparing og strøm-overvåkning
Jeg gjorde det samme, gikk bra til slutt. Lurte meg selv først. Når man gar lagt inn egen broker, etc., har Pulse ingen webserver mer på den nye adressen. Dermed trodde jeg , at det hadde gått galt., selv om alt fungerte bra.
