Alt skrevet av Torill Iversen
Jeg bruker Homey. Jeg ville tro at man kan lage en flow der som sier at når en (ekstern ikke tilkoblet) sensor er x grader - > så juster termostat til.. Torill
I just used a regular one. Then I took the little pin out (from picture 2)and used that to macht the hole in the sylinder from picture 1,instead of the long original pin from yale x.
- 38 svar
It is the one that was in our (new) door, I think you can work with whatever, - just need some heavy adapting ?. Your carpenter needs to be positive, and solution orientated ?, then you will be fine
Ahhh, I wish I had thought of an video myself! I have never done anything with a door before I started on this. I used an old door, took out the lock and just tried understanding the parts and then figure out what had to be done. I actually had a locksmith over, but he said it couldn't be done ??. I knew it could, because my brother had done it already. Sending a picture of approximately how the dor case looked like. Since I didn't have the tools, (or the skills), I used a carpenter to do the cutting and so on, - I just had the plan of which steps that needed to be done.
I had to do a lot of mcGyver stuff;) You need to drill a bigger hole for the front piece. Also, for it to be attached, I had to cut the round metal (se pictures) so it got all the way into the door. You can then use the original pins - but i needed some adjustments ( and you need other screws). The back piece also needs some adjustment. I had to build it out by cutting a similar shaped piece of an piece that is supposed to be in a IKEA closet. You can use whatever you have available. I did not use the original lock bolt. I used just a cylinder extension and the original locking case. At last I took out the little square piece inside the original nest lockbolt (the one that the pin comes into). I cut this, and then clued it onto the cylinder extension so that its tight when the motor turns around and locks. This last step might not be necessary on other extensions, - but mine had some backlash that resulted in a door that could`t open (motor moved a while before actually rotate the lock).
- 38 svar
1. Ja, oppdaterte appen først. 2. Du setter termostaten i samme modus som ved inkludering. Trykk den av, deretter trykk 5 ganger til Con kommer opp. Så trykker du "remove device" i Homey, så trykker på i midtposisjon på termostaten - da begynner den å snurre og så viser den at den er eskludert. Derretter må du trykke inn de to høyre knappene i ca 20 sek og da viser displayet "res"..( resett) - når den er ferdig kan du inkludere som vanlig. Jeg tok ingen sjanser og holdt Homeyen i nærheten ved eskludering også
Ja, du må oppdatere app, ekskludere, resette og inkludere. Jeg gikk også rundt med Homey og hadde den helt oppi, og prosessen gikk veldig greit med 8 av de. På to av de måtte jeg i tillegg åpne homey/developer og fjerne noden derfra, men så gikk det fint å få ekskludert. Med den nye appen gikk inkludering veldig greit.
Hei alle med lignende problemer med heatit og Homey. Det er nå kommet en fix, heter Beta 2.4.0. Problemet har vært at de har vært inkludert secure, og det har skapet mye issues. Les denne tråden for å forstå både utfordringen, løsningen og ikke minst hvordan få de opp å gå på ny app. Jeg har nå inkludert alle mine 10 og de fungerer nydelig https://community.athom.com/t/heatit-z-wave-app-v2-2-1-v2-4-0-beta/166/189
Har en dings som heter Nest connect, som kobler den til wifi og nest appen (og nest brannvarslerne). Den eneste ulempen er at Hømey ikke støtter Nest lenger
- 38 svar
Mine er inkludert, men får ikke alle til å reagere - > dvs f.ek sende inn temperatur til Homey ( eller svare på endringer). Kom over denne på developer.Homey ( se bilde): Noen som kan gi meg en indikasjon på hva forskjellene på de ulike termostatene betyr (TX sendt F. eks 5364 og TX error (0%)-, mens en annen har tx Sent 6 og tx error 67%) - > mye forskjeller)?
Finner ikke fibaroenhet (#Homey og #z-wave)
Torill Iversen svarte på Torill Iversen sitt emne i Homey
Takk - funket som bare det -
Vet ikke helt prosedyren, men leser av manualen at en resett av sensoren kan fungere. Eller må jeg gjøre noe via Homey? -
Update: Brukte norsk original låsejasse, men måtte ha sylinderforlenger. Måtte lage større sirkelhull i døren, utvide hullene i bakfestet som skulle inn i låsesylinderen, og kutte litt av rammen på innsiden av selve panelet på fremsiden. Men fikk det til tilslutt!
- 38 svar
- 3
Hei, Jeg har hatt to fibaro produkter koblet til Homey'en min (Button og motion sensor). De falt plutselig ut og jeg får ikke koblet de til igjen. Jeg har restartet z-wave, fjernet enhetene, avinnstallert fibaro appen og innstallert den igjen, men når jeg prøver legge de til får jeg bare melding om at homey ikke finner noen z-wave enheter. Stått fysisk nært Homey og andre z-wave enheter ved installasjon. Noen triks/erfaringer?
Takk for tips, sjekker!
- 38 svar
Har den nyeste modellen som ser ut som bildet. Vurderer å kjøpe dørhåndtak m. m (den fra Yale under.) Vi har glassdør med ikke så mye å gå på, i tillegg har den lås oppe og nede, - så lurer på om dette rett og slett ikke kommer til å gå
Veldig lurt å teste på en planke først..? Husker du hvor du fikk du tak i den låsen? Torill
Har du fått det til med amerikansk låsekasse? Torill
Hei, Noen som har erfaring med å installere denne? Kommer med amerikansk låsekasse, så må mekkes til på et vis (eller kjøpe en slik?). Lure tips for å komme videre? Torill
Takker - skal teste! Edit; Virket som bare det
Noen nye tips på denne? Jeg har 8 sensorer men har bare fått koblet til en (til Homey). De andre står enten å spinner lenge, eller veldig kort, før det kommer 'Err'. I Homey appen (under add device) får jeg avogtil melding om at termostaten 'already is added', men termostaten sier error og og appen viser ingen termostat. Har nærheten til ruteren noe å si?
Er det noen som har koblet z-water mot homey? Erfaringer?
HeatIt - z-trm2fx og følere. Kreative forslag?
Torill Iversen svarte på Torill Iversen sitt emne i Klimakontroll
Da har jeg satt elektrikeren og tømrere igang med å finne en løsning slik at sensorene kommer ned i gulvet. Men vi har også vannbåren varme. Har tenkt å kjøpe den heatit z-water styringsenheten. Må man da ha gulvsensor? Eller styres alt via styringsenheten? Og hvordan kobles dette mot termostaten på veggen? Dette er helt nytt for meg, derfor litt banale spørsmål.
