DiderikFrom
4
Alt skrevet av DiderikFrom
Da har jeg ekskludert 23 og 24, inkludert dem som batterinoder. De virker ikke. De har snodige child devices, men "Test node connectivity on a network" tar dem ikke med. Da betyr det altså noe (i motsetning til hva Aeotec skriver i manualen) hvorvidt de inkluderes med USB-strøm eller på batteri. Obtaining a list of nodes to be contacted... 20 nodes will be contacted, the following nodes will be skipped: 1 10 12 18 19 20 29 30 32 34 35 37 38 46 55 56 Node 3 (Node 3 Study Fibaro Switch Binary Node 3 Root) Successfully contacted. Node 4 (Node 4 Study Fibaro Switch Binary Node 4 Root) Successfully contacted. Node 5 (Node 5 Living Room Switch Multilevel Node 5 Root) Successfully contacted. Node 6 (Node 6 Bedroom Fibaro Switch Binary Node 6 Root) Successfully contacted. Node 7 (Node 7 Bedroom Table lamp) Successfully contacted. Node 8 (Node 8 Laundry Aeon Labs Switch Multilevel Node 8 Root) Successfully contacted. Node 9 (Node 9 Study Fibaro Switch Binary Node 9 Root) Successfully contacted. Node 11 (Node 11 Living Room GreenWave Switch Binary Node 11 Root) Successfully contacted. Node 13 (Node 13 Kitchen Counter Light) Successfully contacted. Node 14 (Node 14 Bathroom Fibaro Switch Binary Node 14 Root) Successfully contacted. Node 15 (Node 15 Bathroom RGBW Node 15 Root Vertical Cove) Successfully contacted. Node 16 (Node 16 Bathroom RGBW Node 16 Root Ceiling Cove) Successfully contacted. Node 21 (Node 21 Bathroom RGBW Mirror Node 21 Root) Successfully contacted. Node 22 (Node 22 Bathroom Fibaro Switch Binary Node 22 Root) Successfully contacted. Node 28 (Node 28 Study Aeon Labs Switch Binary Node 28 Root) Successfully contacted. Node 39 (Node 39 Storage Room Light) Successfully contacted. Node 42 (Node 42 Living Room Fibaro Switch Binary Node 42 Root) Successfully contacted. Node 43 (Node 43 Kitchen Aeon Labs Switch Binary Node 43 Root) Successfully contacted. Node 44 (Node 44 Bedroom Aeon Labs Switch Binary Node 44 Root) Successfully contacted. Node 52 (Node 52 Z-Wave Fibaro Switch Multilevel) Successfully contacted. Finished!
Takk, igjen! Naboer 28: Neighbors: 3, 4, 7, 9, 14, 15, 16, 21, 22, 39 39: Neighbors: 3, 4, 5, 6, 7, 8, 9, 11, 14, 15, 16, 21, 22, 28, 42, 52 42: Neighbors: 3, 5, 6, 8, 9, 11, 13, 14, 15, 16, 21, 22, 39, 43, 52 43: Neighbors: 5, 6, 8, 13, 14, 22, 42 44: Neighbors: 8, 11 23 og 24 er altså ikke naboer til noen av disse. Jeg kjørte nå en full optimize uten andre feil enn 23 og 24. Prøvde nå å ekskludere 24 og så inkludere, men det blir bare feil ved inklusjon, ZW100 inkluderes med ymse inkomplette varianter av child devices. Problemet her er den hersens qubino dimmeren som ligger i kontrolleren, node 51, som jeg ikke blir kvitt. All manipulasjon av z-wave-nettverket fører til feilmeldinger nå, og det begynte etter at jeg satte parameter 100 til 9 på qubino'en, ekskluderte, og så inkluderte. Før det har jeg gjort masse rart frem og tilbake uten feilmeldringer eller problemer. Jeg har kjørt optimize, Z-health og diverse og alt har fungert fint. Jo mer jeg gjør nå, jo mer clogger ting seg.
Aha. Jeg har lurt på hvorfor HS ikke skjønner at de batteridrevne sensorene ikke skal våkne. Dette er dog ikke noe nytt, og har ikke ført til problemer tidligere. Men rescan av node 24 gikk ikke så bra. May-21 23:57:44 Z-Wave Warning The device at node 24 should result in 4 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation. May-21 23:57:44 Z-Wave Error Node 24 did not provide Wake-Up Command Class information - it will not be processed further. May-21 23:56:51 Z-Wave Error UZB1: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (UZB1). May-21 23:55:46 Z-Wave Getting association information for node 24 May-21 23:55:07 Z-Wave Node 24 is a Z-Wave Plus node. Retrieving ZWPlus Info... May-21 23:55:07 Z-Wave Node 24 is Z-Wave version: Lib: 4.05 App: 1.6 May-21 23:55:07 Z-Wave Warning Error getting version information for node 24, Send failed. May-21 23:54:57 Z-Wave Node: 24 Controls Class(es): DEVICE_RESET_LOCALLY May-21 23:54:57 Z-Wave Node: 24 Supports Class(es): ZWAVEPLUS_INFO_V2, VERSION_V2, MANUFACTURER_SPECIFIC, ASSOCIATION_GRP_INFO, ASSOCIATION, POWERLEVEL, NOTIFICATION_V3, WAKE_UP, BATTERY, SENSOR_BINARY, SENSOR_MULTILEVEL_V2, CONFIGURATION, FIRMWARE_UPDATE_MD_V3 May-21 23:54:57 Z-Wave Syncing Z-Wave nodes with device list... May-21 23:54:57 Z-Wave Found 36 Z-Wave nodes May-21 23:54:57 Z-Wave Getting Z-Wave node list for network CFDE9095... Eller 23 May-22 00:10:04 Z-Wave Error UZB1: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (UZB1). May-22 00:08:03 Z-Wave Getting association information for node 23 May-22 00:07:13 Z-Wave Node 23 is a Z-Wave Plus node. Retrieving ZWPlus Info... May-22 00:07:13 Z-Wave Node 23 is Z-Wave version: Lib: 4.05 App: 1.6 May-22 00:07:13 Z-Wave Warning Error getting version information for node 23, Send failed. May-22 00:07:00 Z-Wave Node: 23 Controls Class(es): DEVICE_RESET_LOCALLY May-22 00:07:00 Z-Wave Node: 23 Supports Class(es): ZWAVEPLUS_INFO_V2, VERSION_V2, MANUFACTURER_SPECIFIC, ASSOCIATION_GRP_INFO, ASSOCIATION, POWERLEVEL, NOTIFICATION_V3, WAKE_UP, BATTERY, SENSOR_BINARY, SENSOR_MULTILEVEL_V2, CONFIGURATION, FIRMWARE_UPDATE_MD_V3 May-22 00:07:00 Z-Wave Syncing Z-Wave nodes with device list... May-22 00:07:00 Z-Wave Found 36 Z-Wave nodes May-22 00:07:00 Z-Wave Getting Z-Wave node list for network CFDE9095...
Ja. 23 og 24 er Aeon Labs ZW-100 MultiSensorer (batteridrevne). 28 er en Aeon Plug-In switch Gen5, 39 er en Everspring Screw-in Bulb Module, 42 er en Fibaro Wall Plug (nyeste type), mens 43 og 44 er Aeon Smart Switch - ZW096. Disse burde svare, og jeg har ikke hatt noe trøbbel tidligere. Jeg kjøpte en Fibaro DImmer 2 i dag for ev. å ersatte Qubino'en dersom den var murstein. Forsøkte å inkludere den (midlertidig, strøm koblet til via en apparatøedning og uten last), alt ser fint ut, men fikk et par feilmeldinger, og status på devicene settes bare til "Unknown". Da jeg holdt på i går, klarte jeg å bli kvitt ghost noden fra kontrolleren, men ikke i dag. Den blir bare værende.
Gjerne! Obtaining a list of nodes to be contacted... 22 nodes will be contacted, the following nodes will be skipped: 1 10 12 18 19 20 29 30 32 34 35 37 38 46 Node 3 (Node 3 Study Fibaro Switch Binary Node 3 Root) Successfully contacted. Node 4 (Node 4 Study Fibaro Switch Binary Node 4 Root) Successfully contacted. Node 5 (Node 5 Living Room Switch Multilevel Node 5 Root) Successfully contacted. Node 6 (Node 6 Bedroom Fibaro Switch Binary Node 6 Root) Successfully contacted. Node 7 (Node 7 Bedroom Table lamp) Successfully contacted. Node 8 (Node 8 Laundry Aeon Labs Switch Multilevel Node 8 Root) Successfully contacted. Node 9 (Node 9 Study Fibaro Switch Binary Node 9 Root) Successfully contacted. Node 11 (Node 11 Living Room GreenWave Switch Binary Node 11 Root) Successfully contacted. Node 13 (Node 13 Kitchen Counter Light) Successfully contacted. Node 14 (Node 14 Bathroom Fibaro Switch Binary Node 14 Root) Successfully contacted. Node 15 (Node 15 Bathroom RGBW Node 15 Root Vertical Cove) Successfully contacted. Node 16 (Node 16 Bathroom RGBW Node 16 Root Ceiling Cove) Successfully contacted. Node 21 (Node 21 Bathroom RGBW Mirror Node 21 Root) Successfully contacted. Node 22 (Node 22 Bathroom Fibaro Switch Binary Node 22 Root) Successfully contacted. Node 23 (Node 23 Study Aeon Labs Multisensor Node 23 Root) did not respond. Node 24 (Node 24 Living Room Aeon Labs Multilevel Sensor Node 24 Root) did not respond. Node 28 (Node 28 Study Aeon Labs Switch Binary Node 28 Root) did not respond. Node 39 (Node 39 Storage Room Light) did not respond. Node 42 (Node 42 Living Room Fibaro Switch Binary Node 42 Root) did not respond. Node 43 (Node 43 Kitchen Aeon Labs Switch Binary Node 43 Root) did not respond. Node 44 (Node 44 Bedroom Aeon Labs Switch Binary Node 44 Root) did not respond. Node 52 (Node 52 Z-Wave Fibaro Switch Multilevel) Successfully contacted. Finished! Qubino kommer ikke med i listen. Den er id 51. Men her var det altså mye som ikke svarte. Jeg har hatt et system som har fungert prikkfritt lenge, helt inntil dette.
Det har jeg også gjort. For lenge siden. Jeg har et bash-script som ruller i bakgrunnen, men egentlig blir det knapt brukt fordi "slå-av-alt-lys-nå-er-det-natt-knappen" blir brukt hver kveld. Poster gjerne scriptet dersom noen er interessert, men det bruker å være laber interesse for bash-skript her. De fleste er vel uansett på windows, så da er det uansett ikke aktuelt.
Tusen takk for svar! Guiden din er nyttig! Den har jeg sett og brukt tidligere, men dessverre hjelper den ikke her. Noden legger seg inn som du ser på skjermdumpen under: det er altså ikke noe å trykke på. (I dag tidlig hadde det lagd seg en inkomplett node som jeg fikk fjernet med denne metoden.) Jeg får dog fjernet noden ved å ekskludere på tradisjonelt vis mange, mange ganger. Etter å ha forsøkt igjen og igjen, får jeg beskjed om at det ble funnet en node som skal ekskluderes, og success, eller hva det står. Loggen ved inklusjon er som følger (dette er fra rescan, men det står akkurat det samme): (Jeg har altså ikke trykket abort eller avsluttet.) Og i selve log'en: May-21 11:26:39 Z-Wave Z-Wave Plus Association Root Group Information For Group 9 retrieved successfully from Node 51 Group Name=NotificationKey, Profile Is General:Not Specific And the group hosts 1 Event commands. May-21 11:26:39 Z-Wave Z-Wave Plus Association Root Group Information For Group 8 retrieved successfully from Node 51 Group Name=BasicSetKey1, Profile Is General:System And the group hosts 1 Event commands. May-21 11:26:39 Z-Wave Z-Wave Plus Association Root Group Information For Group 7 retrieved successfully from Node 51 Group Name=NotificationKey1, Profile Is General:Not Specific And the group hosts 1 Event commands. May-21 11:26:37 Z-Wave Z-Wave Plus Association Root Group Information For Group 2 retrieved successfully from Node 51 Group Name=BasicSetKey1, Profile Is General:Not Specific And the group hosts 1 Event commands. May-21 11:26:36 Z-Wave Z-Wave Plus Association Root Group Information For Group 11 retrieved successfully from Node 51 Group Name=TempReport, Profile Is General:Not Specific And the group hosts 1 Event commands. May-21 11:26:36 Z-Wave Z-Wave Plus Association Root Group Information For Group 10 retrieved successfully from Node 51 Group Name=NotificationKey1, Profile Is General:Not Specific And the group hosts 1 Event commands. May-21 11:26:35 Z-Wave Getting Z-Wave Plus Association Group Information (11 groups) from Node 51... May-21 11:26:35 Z-Wave All associations for node 51 have been retrieved successfully, it supports associations on these groups: 1, 10, 11, 2, 3, 4, 5, 6, 7, 8, 9. May-21 11:26:35 Z-Wave Node 51 Association Group 9 can have 16 associations, and currently has 0 May-21 11:26:35 Z-Wave Node 51 Association Group 8 can have 16 associations, and currently has 0 May-21 11:26:35 Z-Wave Node 51 Association Group 7 can have 16 associations, and currently has 0 May-21 11:26:35 Z-Wave Node 51 Association Group 6 can have 16 associations, and currently has 0 May-21 11:26:35 Z-Wave Node 51 Association Group 5 can have 16 associations, and currently has 0 May-21 11:26:35 Z-Wave Node 51 Association Group 4 can have 16 associations, and currently has 0 May-21 11:26:35 Z-Wave Node 51 Association Group 3 can have 16 associations, and currently has 0 May-21 11:26:35 Z-Wave Node 51 Association Group 2 can have 16 associations, and currently has 0 May-21 11:26:35 Z-Wave Node 51 Association Group 11 can have 16 associations, and currently has 0 May-21 11:26:35 Z-Wave Node 51 Association Group 10 can have 16 associations, and currently has 0 May-21 11:26:35 Z-Wave Node 51 Association Group 1 can have 1 associations, and currently has 0 May-21 11:26:34 Z-Wave Getting association information for node 51 May-21 11:26:34 Z-Wave Node 51 is a Z-Wave Plus node. Retrieving ZWPlus Info... May-21 11:26:34 Z-Wave Node 51 is Z-Wave version: Lib: 4.05 App: 1.1 May-21 11:26:34 Z-Wave Node: 51 Controls Class(es): BASIC, SWITCH_MULTILEVEL May-21 11:26:34 Z-Wave Node: 51 Supports Class(es): ZWAVEPLUS_INFO_V2, VERSION_V2, MANUFACTURER_SPECIFIC, DEVICE_RESET_LOCALLY, POWERLEVEL, BASIC, SWITCH_ALL, SWITCH_BINARY, SWITCH_MULTILEVEL, SENSOR_BINARY, NOTIFICATION_V3, METER, MULTI_CHANNEL_V3, ASSOCIATION, MULTI_INSTANCE_ASSOCIATION, ASSOCIATION_GRP_INFO, CONFIGURATION Igjen, tusen takk! Bare gi lyd dersom jeg skal komme med mer info.
Under parameter 100 "NOTE1: After parameter change, first exclude module (without setting parameters to default value) then wait at least 30s and then re include the module!" Lenger ned står det at den vil huske parametrene hvis den ekskluderes med X trykk på I1 og ikke huske Y trykke på I1. 1-6 er "notification sensors" og 9 er binær sensor. Jeg forsøkte først å assoiere alle gruppene til HS, men fikk ingen instant status på I2 (kun dersom jeg holdt I2 inne og pollet samtidig). Derfor forsøkte jeg dette. Nå har jeg egentlig gitt opp I2, og vil bare ha dimmeren til å funke igjen... Etter mye frem og tilbake får jeg fjernet ghost devicen fra kontrolleren. Ved å vente lenge (på det meste over natten) dukker det opp én root device som kommuniserer dårlig med kontrolleren (og som ikke kan brukes til å styre noe). Den kan jeg fjerne enten ved "Remove bad node" eller tradisjonelt fra Qubino-modulen, og da forsvinner den også fra UZB1, ser det ut til. (Mens HS3-devicen er der, fylles loggen med alskens feilmeldinger også fra andre noder.) Når jeg så da forsøker å inkludere igjen (secure eller noe-secure) gjentar balletten seg. Jeg har også flyttet serverer till rett under modulen siden Qubino skriver noe om maks én meter... Med så mange eksklusjoner/resets, kan jeg egentlig ikke forstå at parameter 100 fortsatt er satt til annet enn 0/default, men hvert forsøk på inklusjon av modulen får systemet til å knele.
Jeg trenger hjelp! Jeg har brukt en Qubino Z-wave plus dimmer med HS3 uten problemer i et par uker. Denne: https://www.tronika.no/en/lighting-control/864-dimmer-zmnhdd1.html Så fant jeg ut at jeg ville bruke I2 til noe, derfor satte jeg parameter 100 til 9, som det står i manualen. Man skal så ekskludere, og inkludere modulen igjen, og I2 skal kunne brukes. Nå får jeg ikke inkludert modulen på skikkelig vis igjen. Ved inklusjon stopper inklusjonsprosessen opp, og jeg får en ghost device i kontrolleren (som er en UZB1). Jeg har gjort dette på siste versjon av z-wave plugin (3.0.1.77), men har nå også testet å nedgradere til BETA 3.0.1.74, men det hjelper ikke. Akkurat samme som her: http://board.homeseer.com/showthread.php?t=176341 Det rare er at det funket fint å inkludere modulen for noen uker siden da den var ny. Forslag? Kan jeg 1) gjenoprette en sikkerhetskopi av min UZB1? 2) Sette opp domoticz/Z-Way, inkludere der og så "import info from controller" til HS3? 3) Annet? 4) Kaste hele greia?
Ah. Takk for tips! Det virker greiere (og billigere) enn fra USA.
Nå som jeg fikk lyst på en.... Men bestilte du denne fra store.homeseer? Hva ble det i frakt? Og hvordan sendte de?
Velger du en RPi3 tror jeg du må kjøre linux. Jeg vet ikke helt hva du mener med å lage bilder, men funksjonaliteten i HSTouch Designer må du jo betale for. Det blir en vurdering du må gjøre om du trenger den. Jeg satt akkurat og så på CPU-statistikken på min RPi2 og konkluderte med at det ikke var noe poeng å oppgradere til RPi3. (Men jeg ville fortsatt gått for en treer dersom jeg skulle begynt på nytt i dag.) Dersom du ikke er vant med linux, men kjenner windows inn og ut, er kanskje det et argument for å velge en annen maskin, ev gå for noe ferdigkonfigurert.
Jeg presiserer litt her. Det fins egen software med egen lisens ti Raspberry Pi, men du kan fint kjøre HS3 "full versjon" på en Raspberry Pi, og det er å anbefale. Software'n laget for Pi'en er begrenset, og du kan ikke migrere til en annen platform senere. (Egen versjon for Pi 1 og egen versjon for Pi 2.) Jeg kjører full versjon HS3 på en raspberry Pi 2, men dersom du skal kjøpe en Pi i dag er det ingen grunn til ikke å kjøpe en Pi 3. Jeg har en del plugins og devicer og har ingen problemer med ytelse. Velger du full versjon kan du senere bytte tl en kraftigere maskin som enten kjører linux eller (skrek og gru) Windows. Personlig skjønner jeg ikke poenget med HS3 Pro. Forskjellen er HSTouch Designer og en del plugins jeg uansett ikke bruker. HSTouch bruker jeg knapt, og det lille jeg bruker det, klarer jeg meg fint med oppsettet slik det er. Hva du velger/trenger er selvsagt smak og behag, men jeg tenkte som så at jeg alltids kunne oppgradere dersom behovet kom. (Et veldig mye billigere alternativ til Pro, er forresten Imperihome plug-in til HS3.)
Edit April 2019: Dessverre har dette skriptet sluttet å virke grunnet endringer i Weather Undergrounds tjenester. Forhåpentligvis kommer det en ny versjon her, men tidsaspektet er uvisst. Edit: Dersom du hopper til denne posten, finner du en lua-implementasjon for HomeSeer med dette skriptet: https://www.hjemmeautomasjon.no/forums/topic/122-real-time-solar-data-without-any-hardware-sensor/?do=findComment&comment=7954 Dette er jo det jeg har drømt om: https://www.domoticz.com/wiki/Real-time_solar_data_without_any_hardware_sensor_:_azimuth,_Altitude,_Lux_sensor... Supert initiativ med lux og diverse andre værdata beregnet real-time og ut fra tid, vær, skylag. Jeg synes lux-sensorer for mange formål blir vel lokale. Dessverre er jeg ikke så stødig i LUA, forøsøkte å gjøre dette om til noe jeg kan bruke i HS3, dvs, bare et skript som gir meg tallene slik at jeg bruke curl for å oppdatere en virtual device i Homeseer, men no luck.
Ok, takk! Men dersom jeg kjøper tre av denne kan jeg kanskje finne noen andre senere å komplettere med. Forresten: stakkars plantene dine: på plantcaretools står det at man bør vanne ved 60% fuktighet, i hvert fall ved 50%...
Hæ? Kan du utdype? Er ikke dette rfxcom? Jeg som lurte på å kjøpe meg en rfxcom (igjen, selv om jeg har avviklet protokollen) bare for dette. Hvorfor ikke mer enn tre? Skal det være noen vits må man jo ha flerel
Jeg har slettet alle mine Alexa-IFTTT-greier. Jeg har ikke giddet å bruke skill'en fordi jeg ikke synes det er presist nok, men kanskje jeg skal prøve igjen?
Men jeg hadde et veldig fint system oppe å gå med HCL v3 (ikke v4, vel å merke) der jeg trikset til kommunikasjon med en raspberry pi. HCL med v3 var faktisk veldig stabil og kjempefin å bruke. Mangelen på LUA tok jeg igjen med virtual devices som kjørte curl calls til en raspberry pi med domoticz. Det fungerte veldig bra og stabilt. Jeg var dog passe sur på Fibaro fordi jeg hadde kjøpt min HCL med lovnad om diverse funksjoner som ikke fantes i v3 (plugins, deriblant Sonos, det løste jeg jo selv på raspberry'en men men). I nesten to år lovte Fibaro at det "kommer snart". HCL med v4 ser etter alt å dømme ut til å være særdeles ustabilt (dersom man skal dømme etter forumet). Dersom jeg skulle satt opp et enkelt, billig system kunne jeg fint vurdert en brukt HCL (og ikke oppgradert, ev. nedgradert til v3). For nybegynnere har Fibaro en super app som funker fint når man ikke er hjemme. Jeg ville dog satt opp en virtual device som rebooter en gang annen hver uke. (Man finner oppskriften i forumet, cut&paste.) Og Homeseer: i Fibaro kan man sette sol/skyet/regn som condition i events (eller scenes som Fibaro kaller det).
Jeg mente å skrive: "Jeg vet forresten ikke om dette kun er et problem for HCL som oppdateres fra v3 til v4, eller om det også gjelder de nye versjonene av HCL." Brukerne av HC2 er nok mer fornøyde enn HCL. Problemet fra Fibaro sin side er at HCL ble solgt med lovnad om mange funksjoner som en krevde en helt ny firmware (v4), og jeg tror rett og slett ikke HCL er dimensjonert for å gjøre det Fibaro har lovet. Når det er sagt, har jeg sans for Fibaros tilnærming til z-wave/hjemmeautomasjon. Både HCL og HC2 begynner å bli gamle, og ingen av dem er vel z-wave plus (?). Regner med de kommer med noe nytt snart. Og de nye mikromodulene fra Fibaro er veldig mye bedre enn mikromodulene som ble laget samtidig med HCL og HC2.
På papiret virker HCL utmerket. Deres software er mye enklere og renere enn Homeseer (og attpåtil lagd for Europa). Dette er dog problemet: http://forum.fibaro.com/index.php?/topic/20937-update-hcl-4080/page-8 Jeg vet forresten ikke om dette kun er et problem for HCL som oppdateres fra v3 til v4, eller om det også gjelder Homeseer kjører ihvertfall stabilt uten å kræsje.
API er definitivt best. Da går man direkte via Alexa. Skill'en er under utvikling, men jeg bruker virtual devices for å trigge eventer under API'en. Med skill synes jeg Alexa høres mye feil, så jeg har ikke brukt skill'en på lenge. Bruker API'en daglig, og er storfornøyd. Jo, formelt sett er man begrenset til å totalt bestille to Dot'er per bruker, men det er jo enkelt å knytte Echo'en til en ny konto så sikkert greit å omgå, men jeg ville registrert den på «dama» sånn til å begynne med. Så får du bestilt to nye Dot'er dersom du trenger det.
