hjemmedude
Alt skrevet av hjemmedude
  1. Hei, i et desperat forsøk har jeg kjørt restore til en 3 dager gammel snapshot, men heller ikke her fungerer z-wave nettverket lenger. Ingen ting har endra seg siden i går kveld kl 23, bortsett fra at z-wave ikke vil starte. Noen tips? 2021-01-15 14:26:51.160 Always, OpenZwave Version 1.4.3469 Starting Up 2021-01-15 14:27:01.136 Info, Setting Up Provided Network Key for Secure Communications 2021-01-15 14:27:01.136 Warning, Failed - Network Key Not Set 2021-01-15 14:27:01.136 Info, mgr, Added driver for controller /dev/serial/by-id/usb-0658_0200-if00 2021-01-15 14:27:01.141 Info, Opening controller /dev/serial/by-id/usb-0658_0200-if00 2021-01-15 14:27:01.142 Info, Trying to open serial port /dev/serial/by-id/usb-0658_0200-if00 (attempt 1) 2021-01-15 14:27:01.172 Info, Serial port /dev/serial/by-id/usb-0658_0200-if00 opened (attempt 1) 2021-01-15 14:27:01.174 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9 2021-01-15 14:27:01.174 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc 2021-01-15 14:27:01.174 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9 2021-01-15 14:27:01.174 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb 2021-01-15 14:27:01.174 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa 2021-01-15 14:27:01.174 Detail, 2021-01-15 14:27:01.174 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9 2021-01-15 14:27:02.175 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s) 2021-01-15 14:27:02.175 Detail, contrlr, Removing current message 2021-01-15 14:27:02.175 Detail, contrlr, Notification: Notification - TimeOut 2021-01-15 14:27:02.176 Detail, 2021-01-15 14:27:02.176 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc 2021-01-15 14:27:03.177 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s) 2021-01-15 14:27:03.177 Detail, contrlr, Removing current message 2021-01-15 14:27:03.177 Detail, contrlr, Notification: Notification - TimeOut 2021-01-15 14:27:03.177 Detail, 2021-01-15 14:27:03.177 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9 2021-01-15 14:27:04.178 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s) 2021-01-15 14:27:04.178 Detail, contrlr, Removing current message 2021-01-15 14:27:04.178 Detail, contrlr, Notification: Notification - TimeOut 2021-01-15 14:27:04.184 Detail, 2021-01-15 14:27:04.184 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb 2021-01-15 14:27:05.186 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s) 2021-01-15 14:27:05.186 Detail, contrlr, Removing current message 2021-01-15 14:27:05.187 Detail, contrlr, Notification: Notification - TimeOut 2021-01-15 14:27:05.187 Detail, 2021-01-15 14:27:05.187 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa 2021-01-15 14:27:06.189 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s) 2021-01-15 14:27:06.190 Detail, contrlr, Removing current message 2021-01-15 14:27:06.190 Detail, contrlr, Notification: Notification - TimeOut
  2. Blir z wave tregere med størrelsen på nettverket?
  3. Fyrer hardt i peisen og justerer litt ned på mindre brukte rom, så faller forbruket litt også. Når man en dag bygger nytt hus (akk og ve) så skal alt bli så bra 😉
  4. Det tar noen år før man sparer inn abo man hadde med Sector/verisure, men men. Har Homely og er sålangt fornøyd. Råtten bransje
  5. Finnes det temperatursensorer (wifi/zwave og batteri) til en billig peng der ute? Har Netatmo fra gammelt, det funker jo flott, men dyrt utstyr å ha i for eks garasje.
  6. Nja, når prisen er jevnt høy over lenger tid mister også varmekablene mine varmen sånn jeg erfarer. Ikke noe unormalt det, men å redusere alle termostater med 1-2 grad kan kanskje hjelpe på forbruk, men negativt ut over komfort. Funker bra/greit på nattsenking da.
  7. Når prisen er høy som i disse tider fra kl 09 til 1900, hvordan kan man da «spare» samtidig som man har komfort temperatur? Min logikk er varm opp mer enn nødvendig når en dyr periode nærmer seg, ikke senk temperatur fordi det er dyrt.. teoretisk.
  8. Ingen begrensning? edit: det er kostnad for icloud ja. Bruker nextcloud nå og det er jo gratis i den forstand at hardwaren allerede er kjøpt inn. Funker greit det, og datane er i mitt hjem.
  9. Wireguard fungerer ikke lenger, til å begynne med mener jeg den var ok. Forsøker en snapshot restore fra 18 desember via console i vmware. Den spinner på processing og har gjort det i 15 minutter. Når jeg restarter vmen ser alt greit ut, jeg kan også logge på via console med root. Men burde kanskje logge på med min konto som er administrator? Ups.. Ingen kontakt mot ip:8123 Sinnsykt irriterende edit: tok litt tid med processing, nå er jeg oppe å kjøre igjen. Takk og lov!
  10. Hei, det skjer selvfølgelig når man ikke er hjemme 😉 Wireguard er konfigurert via HA og fungerer fint. Nextcloud kjører også som VM på server og den fungerer fint. Har TeamViewer til server men klarer ikke få opp lovelace derfra. Forsøkt restart av vm og server.. Noen simple grep for videre feilsøking? Alt var ok senest i går.
  11. Ikke umulig - googla litt i går og fant kjapt at dette var et kjent problem for utviklerene.
  12. Kan anbefale Nextcloud - 5100 bilder og video fra iPhone overført via wifi. Synker ikke når iPhone er låst, appen må være aktiv.. det er kjent Apple/iPhone problemstilling.
  13. Har installert en vm av Nextcloud men har ikke kommet forbi https/ssl oppsett, planen er å ha vpn for å unngå eksponering mot internett. Jeg har http kommunikasjon mot apache server men ikke mot https enda. edit: gikk for en ferdigkonfigurert nextcloud vm og nå er det oppe å gå, overfører filer as we speak. Veldig lekkert! Jeg har selvfølgelig alt på C-disken, så jeg må ordne overføring til 8tb disken slik at den ikke fylles opp.. Vi får se hvor enkelt det blir, kanskje en automatisk jobb som overfører filer til d: disk hver natt. Så langt veldig happy med løsning
  14. Tror jeg vil ha en backup hos Jottacloud kontra å kjøpe lagring hos google/apple, såpass rebelsk er jeg. Fant kjapt photosync til iphone (det er kun apple og windows (og Home assistant da)) her i huset, så smbsync2 til android faller dessverre bort - men ser ut som et godt verktøy. Skal lese litt om photosync som støtter en drøss av leverandører og protokoller, er vel ikke freeware men la gå. https://www.photosync-app.com/home.html engangskjøp på 55kr i app for å overføre i full size og 'uendelig' mange bilder. 70kr året for auto-sync. Må tenke litt på dette.. edit: er mulighet for lifetime kjøp, det hjelper sterkt på. Det er photosync premium som har auto-transfer. edit2: nextcloud er kanskje veien å gå? https://nextcloud.com/athome/
  15. Har ikke fått med meg denne tråden - det var lurt Moskus 😊 Tror mange kjenner seg igjen i at mnd/årlig abonnement er en showstopper, men å kjøpe en til flere harddisker til en høyere sum er helt innafor. Jeg er kommet dit at siden Google Photos (som funker superbra, god AI, enkelt oppsett) nå blir kjøpetjeneste går jeg over på lokal lagring. Dersom det lar seg gjøre på en god måte. Regner med det finnes apper og programvare for dette, blir nok litt romjulssøking ☺️ Har hørt flere skryte av synology på nettopp dette, men det krever vel et synology OS i bunn, og gjerne synology hardware? Har tidligere sett på Jottacloud, vet ikke helt hvorfor det sa stopp. OneDrive har jeg via jobb, det funker også bra men har ikke utforsket bilde-funksjonalitet (AI, deling, app synk osv). Jeg må uansett ha OneDrive privat skal jeg bruke det til private ting 😊
  16. Hvordan ordner dere backup av bilder/video fra mobil til (jeg antar) lokal lagring? Har sp langt brukt Google, men nå er det snart fullt der før man må betale for lagring.. Og lokalt er bedre
  17. Vi har Homely til 169kr mnd (nå 199 for nye kunder). Funker greit det også mot doorman. Koster litt siden de kun støtter develco produkter, men sparer i det lange løp... alt for vektertjenesten 😛
  18. Må bare spørre hvordan nettverket ditt ser ut og hvorfor vil du gjøre dette?
  19. Strømpris fra Daniel lagt inn som custom_component fungerer utmerket. Ser nå strømpris litt fremover i tid. Netgear wifi-deteksjon i HA fungerer bra, openwrt må jeg forske litt på. God helg 🙂
  20. Nå forstår jeg hvorfor ikke iphone dukket opp. Har en netgear router som aksesspunkt hvor vi som regel er tilkoblet wifi. Så enheter på dette ap-et blir ikke detektert av HA.. Skal dette være nok for å aktivere mot netgear routeren? : https://www.home-assistant.io/integrations/netgear/ edit: ja det var nok, fikk opp en hel gjeng med device_tracker_mac:addresse nå.
  21. Da er koden til stigvi på plass, mange takk for den! Har ikke gjort noe mer med automasjonsdelen ennå. Må tenke litt på den og se litt på schedy. Hva bruker man til wifi device tracking i HA? Trackeren er satt til gps såvidt jeg skjønner, ikke den mest nøyaktige. Har kjapt sett nmap, ping, rpc via openwrt.. og det er mest for å sjekke om telefon/ipad er hjemme eller ei. edit: etter en god dose googling finner jeg mange som ikke er fornøyd med 1 tjeneste alene, så mulig denne går på hylla..
  22. Takk for oppklaringen - det er jeg faktisk helt med på. Så du bruker snittet de siste 3 dagene for å unngå nettopp dette.
  23. Og i de tilfellene med lik nettleie gjennom hele dagen/uka/mnden så vil vel Tibber gi riktig pris.
  24. Takk for dette stigvi - kommer til å sjekke dette nærmere i morgen. Men først som sist må jeg advare at det nå kommer dumme spørsmål.. på ei snor. Nettleien (x) legger du til Tibber strømpris (y) , men du sier at nettleien kan være høg når strømprisen er lav og at Tibber sin rapportering av price level kan være feil. Men jeg forstår det egentlig ikke.. er ikke nettleien (kr kWh) lik over en lenger periode (måneder av gangen?) Vi må begynne i det små..
