Espenk
Alt skrevet av Espenk
  1. Oppdaterte til 0.107.6 nå og får feilmeldingen igjen. Følgende i system loggen, er det noen andre logger som burde sjekkes?: 20-03-24 17:13:04 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json 20-03-24 17:19:44 INFO (MainThread) [supervisor.host.info] Update local host information 20-03-24 17:19:44 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1 20-03-24 17:19:44 INFO (MainThread) [supervisor.host.services] Update service information 20-03-24 17:19:44 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1 20-03-24 17:19:44 INFO (MainThread) [supervisor.host.network] Update local network DNS information 20-03-24 17:19:44 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager 20-03-24 17:19:45 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information 20-03-24 18:13:04 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository 20-03-24 18:13:04 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository 20-03-24 18:13:06 INFO (MainThread) [supervisor.store] Load add-ons from store: 65 all - 0 new - 0 remove 20-03-24 18:54:38 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.107.6 20-03-24 18:54:38 INFO (SyncWorker_18) [supervisor.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.107.1 to homeassistant/raspberrypi3-homeassistant:0.107.6 20-03-24 18:54:38 INFO (SyncWorker_18) [supervisor.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.107.6. 20-03-24 19:13:04 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json 20-03-24 19:26:24 INFO (MainThread) [supervisor.host.info] Update local host information 20-03-24 19:26:24 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1 20-03-24 19:27:13 INFO (MainThread) [supervisor.host.services] Update service information 20-03-24 19:27:13 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1 20-03-24 19:27:13 INFO (MainThread) [supervisor.host.network] Update local network DNS information 20-03-24 19:27:13 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager 20-03-24 19:27:13 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information 20-03-24 19:31:13 INFO (SyncWorker_18) [supervisor.docker.interface] Stop homeassistant application 20-03-24 19:31:37 INFO (SyncWorker_18) [supervisor.docker.interface] Clean homeassistant application 20-03-24 19:31:37 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse 20-03-24 19:31:50 INFO (SyncWorker_3) [supervisor.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.107.6 20-03-24 19:32:46 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance 20-03-24 19:32:46 INFO (MainThread) [supervisor.homeassistant] Successful run Home Assistant 0.107.6 20-03-24 19:32:47 INFO (SyncWorker_3) [supervisor.docker.interface] Cleanup images: ['homeassistant/raspberrypi3-homeassistant:0.107.1']
  2. Kjører akkurat nå 0.107.1 Finner ikke noen feilmelding i loggen, men nå virker det igjen og loggen går bare tilbake til i dag morges.
  3. Dette har skjedd med flere versjoner og kan fungere noen ganger etter restart og andre ganger ikke. Virker ikke som det er relatert til HA versjon. Jeg gikk igjennom config filen nå og kommenterte bort Snich som jeg ikke har fått til å fungere og nå fungerer Tibber puls integrasjonen igjen. Det er også bare Tibber puls data som har opplevd dette, strømpris og prisnivå har fungert fint hele tiden.
  4. Hei. Jeg får noen gang opp meldingen "Entiteten er ikke-numerisk" for verdier fra Tibber Puls, andre ganger virker det helt fint. Klarer ikke helt å forstå hvorfor dette skjer, noen som vet?
  5. Brukte ikke motstand. Alle sensorer må kobles på før inkludering på z-wave nettverket ellers må enheten eksluderes og inkluderes igjen. Feilen jeg hadde var dårlig kontakt, koblet opp med wago hurtigklemme og kablene var i tynneste laget. Har nå loddet på litt tykkere ledninger. Sto vel et sted at maks lengde på ledning er 3m, så holdt meg innenfor dette.
  6. Fant feilen, rett og slett dårlig kontakt. Tynne ledninger...
  7. Takker. Trikset var å sørge for at alle sensorer er koblet til før smart implant legges til i systemet. Nå ser jeg interntemperatur og alle 6 sensorene. Men har fått en ny merkelig feil. Sensorene viser helt forskjellige verdier på tross av at de ligger ved sidenav hverandre på gulvet. Intern sensor = 29,9 Sensor 1 = 86,3 Sensor 2 = 90,5 Sensor 3 = 23,5 (Trolig riktig) Sensor 4 = 63,7 Sensor 5 = 69,3 Sensor 6 = 68,5
  8. Noen som har erfaring med å bruke Fibaro Smart Implant sammen med DS18B20 temperatur sensorer i Home Assistant? Jeg får lagt til Smart Implant til Home Assistant, men finner ikke de tilkoblede temperaturprobene.
