Vegard trenger hjelp
    Home Assistant
Vegard trenger hjelp sine prestasjoner
Lysmester
Lysmester (5/16)
  • Samarbeidspartner
  1. Selvlært er vellært, osv. Slår på lysene om morgenen, intensitet og fargetemperatur reguleres gjennom dagen. En variasjon skjer hvis det er høyt lysnivå. alias: autolights variables: light_factor: 80 color_factor: 2200 default_colortemp: 420 default_brightness: 127 default_transition: 30 description: >- enables automatic control of brightness and color tempe regulated by outside readings trigger: - platform: state entity_id: sensor.sensative_strips_comfort_luminance - platform: time at: input_datetime.morgen - platform: homeassistant event: start condition: - condition: time after: input_datetime.morgen before: input_datetime.natt weekday: - mon - tue - wed - thu - fri action: - choose: - conditions: - type: is_value condition: device device_id: 97be2f15adad95bd8f5d2e6648a04915 entity_id: sensor.sensative_strips_comfort_luminance domain: sensor above: 2000 below: 50000 sequence: - service: scene.turn_on data: entity_id: scene.dim_high transition: 120 - conditions: - type: is_value condition: device device_id: 97be2f15adad95bd8f5d2e6648a04915 entity_id: sensor.sensative_strips_comfort_luminance domain: sensor below: 2000 above: 40 sequence: - service: light.turn_on data: entity_id: light.stue brightness: >- {{(light_factor * log(states.sensor.sensative_strips_comfort_luminance.state, 10)) | int }} color_temp: >- {{(color_factor / log(states.sensor.sensative_strips_comfort_luminance.state, 2)) | int}} - service: light.turn_on data: entity_id: light.soverom brightness: >- {{(light_factor * log(states.sensor.sensative_strips_comfort_luminance.state, 10)) | int}} color_temp: >- {{(color_factor / log(states.sensor.sensative_strips_comfort_luminance.state, 2)) | int}} - service: input_number.set_value data_template: entity_id: input_number.setcolortemp value: >- {{(color_factor /log(states.sensor.sensative_strips_comfort_luminance.state, 2)) | int}} - service: input_number.set_value data_template: entity_id: input_number.setbrightness value: >- {{(light_factor *log(states.sensor.sensative_strips_comfort_luminance.state, 10))| int}} - conditions: - type: is_value condition: device device_id: 97be2f15adad95bd8f5d2e6648a04915 entity_id: sensor.sensative_strips_comfort_luminance domain: sensor below: 40 sequence: - service: light.turn_on data: entity_id: 'light.stue, light.soverom' brightness: '{{default_brightness | int}}' color_temp: '{{default_colortemp | int}}' transition: '{{default_transition | int}}' - service: input_number.set_value data: entity_id: input_number.setcolortemp value: '{{default_colortemp| int}}' - service: input_number.set_value data: entity_id: input_number.setbrightness value: '{{default_brightness | int}}' mode: restart
  2. Men nok om det, kan dere hjelpe meg å skrive en god automasjon på dette her?
  3. Jeg kjøpte akkurat denne Sensative Strip saken, uvitende om hvor utrolig strømsparende den var. Så en strek i regningen der. Hadde samme bekymringene som deg, men vi får se hvordan det blir i praksis. Den gir meg i det minste utetemperatur. Husker ikke helt hvor jeg lærte dette med lys, men mennesker er veldig gode på å omstille seg fra mye til lite lys, tenk nattsyn og hvor dårlige gamle mobiltelefoner var på mørke. Om dagen om vinteren er det 3000 lux hos meg, mens i et solrikt land på sommeren er det 20 - 30 000 lux. Mye skarpere, men jeg ble overrasket over hvor store forskjeller det var når jeg så målingene i et histogram hjemme hos meg selv. Kurven går skarpt opp og ned igjen når den er plottet linært.
  4. @Moskus den oppdaterer seg veldig sjeldent, men den sender som sagt en oppdatering ved dobling eller halvering av styrken. Siden mennesker oppfatter lys logaritmisk tenker jeg det kan være håp. Kom uansett på at jeg hadde noen Mi Flora greier som jeg endelig har fått inn i HA, så nå har jeg to lyssensorer til. De går på BLE, vet ikke helt hvor ofte de oppdaterer, kanskje hvert 10. minutt eller så. @stigvi tallene jeg nevnte er kun for eksempel, vil basere dem på erfaringstall senere. @NilsOF artig! så du justerer lyset, så lagres et setpunkt av lysnivået, som da opprettholdes av en 'PID'? Kanskje jeg bør gjøre det samme og glemme det med å måle lyset ute, og heller kun måle lyset innover i rommet.
  5. De virker som fine biblioteker for å få jevn dimming av lyset, men det ser ikke ut til at noen av de regulerer utifra lyssensor, kun plassering.
  6. Hei, Jeg er relativt uerfaren på å lage automasjoner i Home Assistant, men har en klar visjon for hvordan jeg ønsker at lys skal dimmes i leiligheten min. Håper at noen her på forumet kan hjelpe meg å utvikle denne automasjonen, og at også andre drar nytte av den. Lysforholdene varierer utrolig mye basert på tid på året, døgnet og været ute. Jeg ønsker å alltid holde lysene på optimalt nivå, basert på en lysintensitetsmåler. Lyset skal dimmes inn fra kl 07.30 Ved mye naturlig lys skal kunstig lys slå seg av Lysnivået skal være høyt mellom 9 og 18.30 Lysnivået skal være dimmet mellom 18.30 og 00.00 Lysmåleren min gir meg kun en ny avlesning annehver time eller ved fordobling og halvering av lysintensiteten. Jeg ønsker derfor at lysnivået skal reevalueres on-event. Vet enda ikke hvordan jeg skal forholde meg til det med å slå av og på lyset, vil nødig vente et døgn før det kommer tilbake i rytmen sin igjen, men det må bli steg 2. Eksempler er under. Belysning (blå linje) øker gradvis om morgenen, slår seg av når sollyset (oransje) blir sterkt nok og kun naturlig lys trengs, og kompenserer gravis for bortfall av lys ved skumring. Det totale lysnivået reguleres en del ned på kvelden, og dimmes gradvis til null ved natt-punktet. Belysning (blå linje) økes gradvis om morgenen, og holder seg høyt utover dagen, da sollyset (oransje) aldri blir strekt nok til å trigge deaktivering. Det dimmes ned til samme nivå som ovenforstående eksempel på kveldstid, og ned til 0 ved natt. Jeg har begynt med denne psudokoden: on (time: morning) { #Om morgenen sjekker vi om lyset alt er på, hvis ikke så dimmer den mot settpunkt basert på hvor lyst det er ute if (brightness == 0% && val <3000lux) { if (val < 10lux) { brightness = 30%} else if (val < 100lux) {brightness = 60%} #Hvis det er litt lysere, høyere settpunkt else if (val < 1000lux {brightness = 85%} else {brightness = 100%} on (time: night) { #Slå av lyset når det blir natt. Kan bygges ut senere til bevegelsessensor i stuen og andre ting, og vil da utsette med 30min hvis fortsatt aktivitet if (brightness != 0%) {brightness = 0%} on (state change: lux.val) if (night > time > morning+60min) #Hvis på dagtid, bør være oppe og gå nå if (val < 10lux) { brightness = 50%} #Hvis det er mørkt, settpunkt lavt) else if (val < 100lux) {brightness = 65%} #Hvis det er litt lysere, høyere settpunkt else if (val < 1000lux {brightness = 90%} else if (val < 3000lux) {brightness = 50%} else (brightness == 0%) #Hvis det er jækla lyst, slå av } else if (time > night && brightness != 0%){brightness = 0%} #Hvis natt-tid har passert og lysene enda ikke er slått av (hva gjør jeg hvis lysene er manuelt slått på midt på natten? da vil de jo periodisk slå seg av. Lage en ekstra automasjon på tid som tar siste avlesning av lys heller, for morgen og kveld? Så langt har jeg prøvd å lage en entitet av alle lysene jeg vil regulere. Så antar jeg at jeg må lage denne koden i automation.yaml filen. Hadde satt stor pris på om noen hadde tid til å komme med innspill på ideene mine og kanskje hjelpe meg å skrive automasjonskoden i Home Assistant markup.
  7. Da kjøper jeg gjerne en sånn når jeg kommer så langt. Har du noe erfaring med Neatmo sin termostat? Der var det en pakke med egen gateway.. noen argumenter for eller imot?
  8. Men fungerer alt dette fremdeles med Google Assistant, og fortrinnsvis Apple Home? Bruker ofte stemmestyring via Sonos, og av og til via mobilen. Det funker faktisk ganske greit per i dag.
  9. Samstemt liker jeg! På IKEA har jeg hatt problemer med at den ene pæren min har mistet kontakten. På en annen er to pærer koblet til en kontroll, og hvis jeg skrur av den ene (med feks Google Assistant) og så trykker på bryteren, toggler begge to. Dvs den ene går på og den andre går av. Sonos volumkontrollen er også myye seigere enn den burde vært. Er så klart enig i at man burde hatt en gateway for å styre alt på komponentnivå. Men det blir jo veldig vanskelig for utviklerne å holde alt oppdatert, med full kompatiblitet og enkelt grensesnitt.. Og hvis det er åpen kildekode er det så mange som bidrar med kode at ting sjelden blir konsistent og like bra. Den dagen den perfekte gatewayen (som støtter alt, er dritenkel å sette opp og har uendelig med oppsettsmuligheter) kommer, så kjøper jeg jo så klart den. Men har inntrykk av at det enda ikke eksisterer. Man må velge mellom glatt og sorgfritt, eller funksjonsrikt og fleksibelt. Ser jo på Home Assistant, et par av de "støttede" produktene innebærer jo helt sinnsykt mye arbeid, av type 'dump minnet på telefonen din på PCen, bruk et diagnoseverktøy, ransak config-filer og finn en token-key'. Er du fornøyd med Openhab?
  10. 0. Neida, men blander Google Assistant og Google Home. 1. Har lest om Conbee, den virker jo fleksibel men upolert, akkurat some HA. Hvis Hue-boksen fikser alle lysene, og IKEA-boksen fikser Sonos fjernkontrollene, og både HA og Google Assistant kan styre alt sammen burde jeg vel være good? 4. Rimelig sikker! Bruker det kun til å styre fargetemperaturen på lysene per idag. 6. Device detection på wifi virker jo nyttig! Men jeg vil egentlig ikke preprogrammere den mot en viss MAC-adresse eller noe slikt, mer som kan gå galt. Det optimale hadde jo vært om den visste om en mobiltelefon var koblet til nettverket.
  11. Hei, alle sammen. Ny bruker, men ivrig leser. Jeg er, sikkert som alle andre her, over middels glad i perfekte automatiske systemer. Jeg har utdanning som utvikler, men det betyr ikke at jeg ikke syntes det finnes overveldende mye informasjon, og at mange ting virker ekstremt kompliserte og tungvinte. Sliter også med at det finnes så altfor mange broer og sentraler. Har lært litt, men med å stå på forumets skuldre skal det nok bli mye bedre! Dette blir jo en veldig lang tråd, den hjelper meg å samle tankene, men innspill om enkeltpunkter mottas med stor takk. Hva jeg ønsker å få til: Lys som reguleres basert på hendelser som at jeg kommer hjem, dagslys og slår på TVen Temperaturstyring og 'borte-modus' Enkel styring av musikk Et robust og fleksibelt system Stemmestyring via Google Assistant Kanskje motorisert solskjerming Det er en 65m^2 leilighet, helt ny, med varmekabler på bad og varmeveksler for fjernvarme til generell oppvarming. Ble akkurat kunde hos Tibber, men har ikke kjøpt noe utstyr fra dem enda. Har akkurat begynt å flytte inn, så jeg har enda ikke solskjerming. Ønsker plisségardiner, og det er ikke noe must å motorisere dem, men det hadde jo vært kult, da. Til nå har jeg: En haug med IKEA Trådfri utstyr Sonos One, Connect og Symfonisk Hue lamper og bro Hue bevegelsessensor Home Assistant Samsung Q90 smart-tv Mill smart terassevarmer Koogeek P1EU stikk Apple TV, iPhone og Apple Home Har enda ikke kommet i gang med Hue. Så langt er status som følger: Koblet Sonos til IKEA-appen, bruker IKEA-volumkontroller i stuen og på soverommet Koblet Sonos med Spotify og Home Assistant Finner nå musikk ganske greit, men har problemer med gruppering av høyttalere. Feks "spill av kun her" eller "slutt å spille musikk i stuen" funker ikke for meg. Home Assistant styrer IKEA-lysene greit via stemme. Integrasjonen mellom Samsung Q90 og Home Assistant er ganske dårlig. Holder ikke Samsung-produkter spesielt høyt i denne sammenhengen.. Ønsker bedre integrasjon mellom system og TV, i det minste at det kan regulere lys. Kanskje i fremtiden også gardiner. Styrer fargetemperatur på lys med Flux-plugin i Home Assistant, det syntes som det virker bra. Tenkte å få alt av IKEA-lys over på Hue-broen, regner med det er anbefalt? Skulle gjerne fått en termostat på badet, ser at det følger med en temp. sensor i pakken, ellers må man bruke en som er der fra før. Er det vanlig å ha en temp. sensor i gulvet? Betjeningspanelet er på utsiden av rommet, så det er ikke mulig å strekke noe ledning inn dit. Ser også at Tibber selger termostater til radiatorer, passer disse 'alle' radiatorer? Noen som har erfaring med å bytte dem? Må også ha en Zwave mottaker for disse tingene, har ikke lyst til å bruke mange tusen på flere sentraler, anbefalinger for Zwave mottaker for Home Assistant? Har ikke noe stort automasjonsbehov for den terassevarmeren, annet enn å lage en fjernkontroll, om det ikke er inkludert i pakken. Greit å kunne la den slå seg av etter noen kriterier også, i tilfelle jeg glemmer det. Jeg har lyst til å slå av og på lyset når jeg kommer og går, og effektivisere oppvarming. Må helst ta høyde for at selv om jeg går på jobb, kan det være det er noen andre igjen i huset. Det er jo også greit at hvis det kommer noen andre inn enn meg, så slår lysene seg på og alt dette. Derfor kjøpte jeg en Hue bevegelsessensor som jeg tenkte å plassere i entreen, selv om jeg er klar over at Home Assistant og andre systemer har en drøss med geofencing-tiltak. Tenkte helt initielt følgende logikk: En form for fast nattsenking. Vanligvis drar jeg på jobb før kl 9, hvis jeg forlater huset da, er jeg sannsynligvis borte til minst kl. 15. Men hvis noen er igjen i huset bør den ikke ta noen drastiske tiltak. Kanskje med enda en bevegelsessensor? Av og til er jeg jo lengre borte, jobbreiser eller ferie. Village en manuell override på det, men ønsker jo helst at systemet skal finne ut av det selv. For eksempel at hvis jeg ikke er hjemme innen nattsenkingen er ferdig påfølgende morgen, skal den bare la være å varme opp noe videre, fram til jeg er i området, eller noen går inn døren. Det jeg trenger hjelp til, er den gode erfaringen fra dere for å konkretisere hvordan jeg bør sette det opp for best mulig resultat!
