bio
3
Alt skrevet av bio
Litt annen feilmelding: Med kode: sub Main(ByVal Parms As Object) Dim ParmArray() as String ParmArray() = Parms.tostring.split(",") Dim tDevice As Integer = ParmArray(0) Dim tCalendar As String = ParmArray(1) Dim tDays As Integer = cint(ParmArray(2)) Dim allEvents() As Object Dim myemail as string="[email protected]" Dim msg as string = "" msg="<table>" msg=msg & "</table>" if msg="" then msg="No Events Scheduled" hs.SetDeviceString(tDevice, msg.Trim, true) End Sub Og: sub Main(ByVal Parms As Object) Dim ParmArray() as String ParmArray() = Parms.tostring.split(",") Dim tDevice As Integer = ParmArray(0) Dim tCalendar As String = ParmArray(1) Dim tDays As Integer = cint(ParmArray(2)) Dim allEvents As Object() Dim myemail as string="[email protected]" Dim msg as string = "" msg="<table>" msg=msg & "</table>" if msg="" then msg="No Events Scheduled" hs.SetDeviceString(tDevice, msg.Trim, true) End Sub Og: Ved også å fjerne Dim allEvents As linjen, med denne koden: sub Main(ByVal Parms As Object) Dim ParmArray() as String ParmArray() = Parms.tostring.split(",") Dim tDevice As Integer = ParmArray(0) Dim tCalendar As String = ParmArray(1) Dim tDays As Integer = cint(ParmArray(2)) Dim myemail as string="[email protected]" Dim msg as string = "" msg="<table>" msg=msg & "</table>" if msg="" then msg="No Events Scheduled" hs.SetDeviceString(tDevice, msg.Trim, true) End Sub
B Beklager, en av de andre Denne feilmeldingen: Med kode: sub Main(Parms As Object) Dim ParmArray() as String ParmArray() = Parms.tostring.split(",") Dim tDevice As Integer = ParmArray(0) Dim tCalendar As String = ParmArray(1) Dim tDays As Integer = cint(ParmArray(2)) Dim allEvents() As Object Dim myemail as string="[email protected]" Dim msg as string = "" allEvents = hs.PluginFunction("BLGData", "", "GetCalendarEventsForXDays", new Object(){myemail,tCalendar,tdays}) msg="<table>" msg=msg & "</table>" if msg="" then msg="No Events Scheduled" hs.SetDeviceString(tDevice, msg.Trim, true) End Sub
Ops Får samme feilmelding uavhengig ?
Feilmelding: Med kode: sub Main(ByVal Parms As Object) Dim ParmArray() as String ParmArray() = Parms.tostring.split(",") Dim tDevice As Integer = ParmArray(0) Dim tCalendar As String = ParmArray(1) Dim tDays As Integer = cint(ParmArray(2)) Dim allEvents() As Object() Dim myemail as string="[email protected]" Dim msg as string = "" allEvents = hs.PluginFunction("BLGData", "", "GetCalendarEventsForXDays", new Object(){myemail,tCalendar,tdays}) msg="<table>" msg=msg & "</table>" if msg="" then msg="No Events Scheduled" hs.SetDeviceString(tDevice, msg.Trim, true) End Sub
Får denne feilen: Ved å endre til kode: sub Main(ByVal Parms As Object) Dim ParmArray() as String ParmArray() = Parms.tostring.split(",") Dim tDevice As Integer = ParmArray(0) Dim tCalendar As String = ParmArray(1) Dim tDays As Integer = cint(ParmArray(2)) Dim allEvents As Object() Dim myemail as string="[email protected]" Dim msg as string = "" allEvents = hs.PluginFunction("BLGData", "", "GetCalendarEventsForXDays", new Object(){myemail,tCalendar,tdays}) msg="<table>" For Each ev As Object In allEvents msg = msg & "<tr><td> " & ev.StartTime & " - " & ev.Name & "." & "</td></tr>" Next msg=msg & "</table>" if msg="" then msg="No Events Scheduled" hs.SetDeviceString(tDevice, msg.Trim, true) End Sub eller kode uten linjene @Moskus nevnte: sub Main(ByVal Parms As Object) Dim ParmArray() as String ParmArray() = Parms.tostring.split(",") Dim tDevice As Integer = ParmArray(0) Dim tCalendar As String = ParmArray(1) Dim tDays As Integer = cint(ParmArray(2)) Dim allEvents As Object() Dim myemail as string="[email protected]" Dim msg as string = "" allEvents = hs.PluginFunction("BLGData", "", "GetCalendarEventsForXDays", new Object(){myemail,tCalendar,tdays}) msg="<table>" msg=msg & "</table>" if msg="" then msg="No Events Scheduled" hs.SetDeviceString(tDevice, msg.Trim, true) End Sub
Nei, får eksakt samme feilmelding(er). Takk for at du hjelper til!
sub Main(ByVal Parms As Object) Dim ParmArray() as String ParmArray = Parms.tostring.split(",") Dim tDevice = ParmArray(0) Dim tCalendar = ParmArray(1) Dim tDays = cint(ParmArray(2)) Dim allEvents As Object() Dim myemail as string="[email protected]" Dim msg as string = "" allEvents = hs.PluginFunction("BLGData", "", "GetCalendarEventsForXDays", new Object(){myemail,tCalendar,tdays}) msg="<table>" For Each ev As Object In allEvents msg = msg & "<tr><td> " & ev.StartTime & " - " & ev.Name & "." & "</td></tr>" Next msg=msg & "</table>" if msg="" then msg="No Events Scheduled" hs.SetDeviceString(tDevice, msg.Trim, true) End Sub
Hei. Til info så har jeg null peiling på scripting eller koding, jeg er en copy/paster Prøver å få til et script som skal liste kalender eventer til en virtuell device gjennom Blade sin BLGData plugin, slik at jeg kan liste dette i HStouch. Har postet dette på HS forumet også, men ikke fått svar. Får følgende feil: Googler på harde livet, og endrer småting uten at jeg får det til å virke. Takk på forhånd.
Hentet akkurat min Tibber Easee lader på posten. Snerten lekker sak, mye mindre enn jeg trodde. Gikk for den, da den bla støtter 3-fas, kan paralell kobles til flere ladere, jeg er Tibber kunde og bruker HomeSeer. Syntes også prisen er gunstig i forhold til tilsvarende ladere. Holder på med strøm og isolering av garasjen, så vil ta noe tid før jeg får testet denne og delt erfaringer ved bruk.
Til info så har jeg dialog med Thermofloor rundt dette. Status pr nå (etter lang stillhet fra de) er at det i utgangspunktet kun skal rapportere på gruppe 2 hvis ekstern sensor er fysisk koblet til termostaten, at dette er rart, og at de skal se på det. ...
Mener Routines fungerer om du styrer telefonen og assistent språk til kun engelsk.
Det er begrensinger i Google på norsk så vidt jeg vet. Tror vi må vente på at Routines i Google Home fungerer på norsk. Chattet med Google support for en måned siden, og de sier de jobber på spreng for å få alle funksjoner, inkl Routines klart for de ny supporterte språkene. Venter i spenning..
Mener du at de ikke rapporterer i det hele tatt? Eller at verdien i parameterne ikke overholdes? Jeg har hatt/har siste problemet. Kan jeg spørre deg, hvilke store problemer fikk du med Z-wave nettverket pga termostatene? Jeg har en tråd her på forumet ang ustabilitet i Z-wave nettverket, til tider treg respons og random devices som blir Unknown, og jeg har mistenkt termostatene som årsaken til tider, har 8 stk i huset. Det som har gjort at jeg har sett litt bort ifra termostatene er at jeg har bygd opp nettverket på nytt flere ganger, ny RPI, ny UZB1, ny harddisk i Esxi 6.5 server, ny install av Esxi 6.5, ny install av VM, prøvd HS3 på annen pc ++++. Og alt dette UTEN å inkludere termostatene, men problemet er der fortsatt. Det jeg ikke har gjort er å koble termostatene helt vekk, de har fortsatt vært i drift, 8 stk, bare uten å være inkludert i noe Z-wave nettverk. Jeg vil tro disse sender noen form for signaler på frekvensen og kan forstyrre uansett? Noen som kan bekrefte? Har nå bygd endel eventer for å trigge ting på nytt hvis noe går til Unknown, både Fibaro Dimmer 2 devicer og Heatit Z-TRM2fx. Samtidig som jeg prøver å finne ut hva som forstyrrer og ødelegger hos meg. Ikke så morro å ha 20-30+ fix events for at devicer skal oppdateres riktig. Hadde jeg hatt overflod av penger hadde jeg bytta ut alle FIbaro DImmer 2 til Elko RF og alle Heatit Z-TRM2fx til Elko RF termostat (så sant disse termostatene blir fungerende i Deconz/Jowihue). Har masse annet på Zigbee, og ingen problemer med de.
Har også opplevd dette. Det jeg gjorde var å bruke funksjonen Remove Bad Node på Zwave taben på noden. Hvis Remove Bad Node feiler, prøv å trykk Test Connecticity, så Remove Bad Node igjen. Det fungerte for meg.
+1 for Doorbird. Hatt mitt Doorbird D101 montert og integrert i HomeSeer siden sommeren i fjor. Aldri feilet med triggers i HS. Bevegelsessensoren, med tilhørende device i HS fungerer også overraskende bra. Bruker den til å dimme opp taklys over inngangsdør når noen nærmer seg døra:)
Ja, det er vanlig ip kameraer. Sa forresten feil om OS som Blue Iris kjører på, det er Win 10 Pro, ikke Ubuntu. Går litt surr i alle vmene på hosten:) https://amcrest.com/ip-cameras.html
Bruker Blue Iris. Kjøres på Ubuntu som en virtuell maskin på Esxi 6.7. Fungerer knall. Betalte vel 480,- for lisens, fri antall kameraer. http://blueirissoftware.com Veldig populær plugin finnes til HS også, https://shop.homeseer.com/products/blue-iris-plug-in-for-hs3 Forresten veldig fornøyd med Amcrest sine 4k kameraer. Kosta ikke veldig mye, knallskarp qual.
Jeg har forresten oppdaget ytterligere en "feil" med termostatene. Fint hvis noen andre kan bekrefte at dette skjer hos dem ,@Frankis78 ? Jeg har kun gulvfølere koblet til mine termostater, og i forbindelse med feilsøking av nettverket mitt hadde jeg i stad på Detailed logging på Z-wave Plugin. Ser da at child devicen for den eksterne rom sensoren for alle termostatene rapporterer inn hyppig. Jeg gikk inn på alle devicene og sørget for at device value oppdateres selv om ikke value changes. Det rapporteres på en sensor som ikke er tilkoblet ? Parameter 2 har 0 på alle sammen, noe som er Floor sensor mode.
Hei. Fikk et standard svar fra daglig leder i Thermofloor i dag. " Dette skal vi se litt nærmere på. Vi kan ikke gi deg noen tidsfrist nå. Vi har ikke fått tilbakemelding fra andre GW brukere om dette (annet enn Homeseer). "
Ja det kan man lure på. Med beta plugin .252 og oppgradert UZB1 til firmware 5.36 ser de ut til å fungere for meg, med unntak av rapporteringen. Var litt issues med inkludering og rescanning. Men det opplever jeg med flere noder, deriblant Fibaro Dimmer 2 også. De har også feilaktig vist at de er off, når de egentlig er on. Men enn så lenge så fungerer også dette nå. Jeg har tenkt det har vært mitt ustabile z-wave nettverk som er skylden og beskjedene ikke når frem. Hvilke problemer har du? Bortsett fra oppstartsproblemer som inkludering.
Will do! Har oppdatert saken med at termostatene kun tar hensyn til parameterne når de er avskrudd. Ikke rart parameterne aldri fungerte i går når jeg testet, alle termostatene kjørte for fullt etter å ha vært avskrudd hele dagen pga testing av andre ting.
