14
Alt skrevet av iceball
Den enheten er vel elgammel. Minst 10 år siden den kom, så ville satset på noe mer moderne produkt.
Svaret er vel nei, for de genererer for mye egenvarme til at temp/fukt-målinger blir riktig. Elko har vel muligens enheter med innebygget bevegelsessensor.
- 3 svar
Beklager, det var upresist og litt feil. Fra mars 2021 Information to users with a third-party integration to Verisure Our system indicates that you are using a third-party integration to connect to Verisure functionality. If this is not the case, you can ignore this email. Otherwise, please continue reading. Third-party integrations are not an officially sanctioned way to connect to Verisure. However, we hope that you are happy with the functionality provided through MyPages and Verisure app and will continue to use it. This email contains instructions for how to use third-party integrations together with 2-step verification. Our goal is to keep our customers safe and secure. This includes maintaining a high security level for your Verisure account and reduce the risk of unauthorized access. In the next couple of weeks, we will therefor introduce 2-step verification for all logins to MyPages and the Verisure app. Once 2-step verification is enabled for your account, you will need a one-time code in addition to your username and password. Preparation for 2-step verification Please complete the following steps to prepare for 2-step verification. Go to Account in MyPages to check that your registered phone number is correct. Make sure that all users with access to your Verisure system have their own Verisure account. If there are users who share accounts, please ask the system owner or administrators to create individual accounts for them. This is done under Users in My Pages. It is very important to have individual accounts with the correct phone number for each user. It ensures that the verification code is sent to the correct user and device at login. If your alarm system is connected to the Verisure Monitoring Center, it also makes sure that the Verisure first responders can reach you in case of an emergency. This is especially important if you use mobile SOS services such as Verisure Guardian. How does 2-step verification affect third-party integrations with Verisure? When 2-step verification is enabled, your connection through the third-party integration might stop working. Please note that if you disable 2-step verification, the risk of unauthorized access to your account is increased. Follow these steps to restore the connection: Log in to MyPages with your username and password. Enter the verification code when you receive it. Go to Account and Subscription > Account > Login credentials > Disable 2-step verification Follow the instructions to disable 2-step verification. In order for us to get valuable input for potential future improvements for users that have a 3rd party integration to Verisure, we have created a short survey as part of the Disable 2-step verification steps. Best regards Verisure
Meget gammel tråd, men du husker ikke tilfeldigvis om og hvordan du fikk til å aktivere indikator lys og bakgrunnsbelysning fra HS? Har satt en knapp til verdi 0 for å kunne styre den, men tydeligvis må det endres assosiasjoner også?
Homebridge tilkoblingen mot Verisure fungerer fint og den er ikke oppdatert siste 6 månedene. Men nå er det lenge siden Lsoft plugin ble oppdatert sist, og den ble vel aldri tilpasset at Verisure faktisk åpnet for tilkoblinger og 2fa for en liten stund siden.
800 chipen er vel først og fremst nyttig for batteridrevne enheter? Jeg gikk for z-water 1 for 2 mnd siden, kunne ikke finne noen positive ting med å vente på 2eren. Virker også som HeatIt har notorisk problemer med de første enhetene når de kommer med et nytt produkt.
Antar det ja. Rart valg i så fall. Trengte den nå, før vinteren kommer, så da ble det gamle z-water da de ikke kunne svare på når den nye kommer uansett.
800 chipen har vel ikke for mye å si på enheter som går fast på strøm, viktigst for de som går på batteri kanskje? Ellers verdt å merke seg: "annen stor endring er også at power unit ikke er inkludert." fra Gjermund i Thermofloor.
Lyst til å dele oppsettet litt nærmere @Ruud? Jeg sliter med at den tror Vstat enheten kjøler hele tiden 🙄
Samme erfaring som jeg har da. Har strømsatt et par stykker. Support hos Q-light har ingen kunnskap om z-wave, så da går de i retur..
Ingen som har prøvd Q-light Zerodim z-wave (vridimmer) mot HomeSeer, eller forsåvidt andre systemer som ikke er Homey, FH eller SmartThings (som alle står som støttet)? Har fortsatt ikke fått den vanlige zerodim til å sende status til HomeSeer. Har også prøvd en 2-polet versjon. Den sender status, men helt feil verdier. Sender f.eks. 4 % når den er av. Og øvrige verdier er nesten alle under 50 %, selv om flere av de skulle vært 70-90 %.
Har ikke så mye rgbw i z-wave, så får gå over til zigbee på de få enhetene og ta det inn direkte via Hue/Deconz.
Nope, W10 dessverre. Men, går greit egentlig. Etter flytting i fjor, så blir det endelig å få opp full z-wave styring av alt lys snart og styring av vannbåren varme, så da skal jeg klare å bruke appen til Bestway en stund. Blir nok av annet å bruke tid på de neste månedene. Plinger på om jeg får opp noe Linux greier en dag og masse ledig tid. ☺️
Takk. Det gikk til slutt etter noen dager med random prøving. @ZoRaC Lyst til å dele fremgangsmåte for HS integrasjon? 😎
Smartifiserte viftekonvektor i åpent stue/kjøkken ved bruk av Fibaro Switch 2 og Heatit Z-temp2. Styrer foreløpig en inngang på styringsenhet til vidtekonvektoren som setter den i bortemodus/av. Testet først med virtuell termostat via SDJ-VSAT i HS3, men den fikk jeg ikke inn i Homebridge. Åpen terrassedør skrur av Mode på z-temp2. Kommer nok til å bytte ut switch 2 med en Heltun - HE-RS01 Bryter 5-veis,som gjør det mulig å styre alle 3 steg på viften.
Har du tips til å få koblet opp wifi? Har prøvd både ios og Android. Ruter/wifi 2,4 GHz fra Get og UniFi UDM..feiler hver gang. Milano vår, men antar pumpa er lik.
Fikk du til noe @Ruud? Jeg får kun til å styre varmhvit. Virker som Homebridge Homeseer4-plugin mangler mulighet for RGB. I Hue plugin fungerer det sømløst..
Litt eldre tråd, men for de som sliter med termostater, så må det legges inn under advanced og ikke i det enkle oppsettet. Dette fungerer fint for meg:
- 19 svar
Nei, kun en av delene, selv om det står det er lagt til suksessfullt. Har også forsøkt å sette på detaljert logging under z-wave nettverk (har erfart at noen enheter sender info som en sjelden gang ikke leses riktig av HS), men det kommer nærmest ingenting, selv når jeg har lagt til alle grupper. Kommer kun status av og på hvis jeg trykker inn bryter. Har forøvrig satt opp en enhet med endpoint 1 og en uten endpoints. Ser det står noe her om at den kun sender hvis jeg holder inne knappen under ID 3. Greit nok for å styre andre lys via assosiasjon, men må kunne fungere mot sentral automatisk.. Skal uansett få testet det, men nå sover barna.
Noen som har fått Q-light Zerodim Z-Wave til å fungere skikkelig i HS3? Når jeg endrer fysisk på dimmeren, så oppdateres ikke device (Z-Wave Switch Multilevel) i HS. Motsatt vei fungerer, får styrt device fra HS. Manuell polling fungerer. Default assosiasjon: Har forsøkt å ta bort endpoint 1 uten at det hjalp. Har også forsøkt å legge til Group 3 uten at det hjalp. Fra manual:
Heatit Z-TRM3 Status for settpunkt varme blir "Unknown" etter en stund
iceball svarte på zephyr sitt emne i Klimakontroll
Nei, ser at internal temperatur og watt og volt ikke oppdateres automatisk, kun ved polling. Forsøkte å endre tilbake til slik jeg hadde før, men med group 1 endpoint 1 også for å få bort unknown feilen, men hjelper ikke det heller. Samme feil. -
Prøvde. Den gir da feil ved polling på setpoint og gulv temperatur. Polling...9 @ Polling: 1. etg Gang 1 etg. Thermostat (Status is: 0)8 @ Polling: 1. etg Gang 1 etg. Heating Setpoint 1 (Status is:(Plugin Reports Error Getting Status))7 @ Polling: 1. etg Gang 1 etg. Mode 1 (Status is: 1)6 @ Polling: 1. etg Gang 1 etg. Operating State 1 (Status is: 1)5 @ Polling: 1. etg Gang 1 etg. Temperature 2 (rom) (Status is:(Plugin Reports Error Getting Status))4 @ Polling: 1. etg Gang 1 etg. Temperature 3 (Status is: 24,3)3 @ Polling: 1. etg Gang 1 etg. Temperature 4 (gulv) (Status is: 0)2 @ Polling: 1. etg Gang 1 etg. kW Hours 1 (Status is: 0)1 @ Polling: 1. etg Gang 1 etg. Watts 1 (Status is: 0)0 @ Polling: 1. etg Gang 1 etg. Volts 1 (Status is: 0)Done Gikk tilbake til slik og da fungerer det. -
Det ser ut som det gjorde susen! Trenger man da egentlig assosiasjon på group 2-5? Det skal vel komme via group 1? -
Jeg prøvde meg forresten på en justering av assosiasjoner slik: Temperatur 3 og 4 går da dobbelt opp etter justeringen, men ikke ved polling, da går temperatur 3 til 0 gr.C.
