MortenB
Alt skrevet av MortenB
  1. MortenB
    ID-Lock V2
    Jeg brukte denne for å kjøre OTA oppgradering av Z-TRM2, så da kan man vel i teorien gjøre det samme her så lenge man får firmwarefilen? Z-Wave PC Controller: https://www.silabs.com/products/development-tools/software/z-wave
  2. Noe ala denne? https://snips.ai/
  3. Jeg hadde også dette problemet på 0.92.2. Måtte rulle tilbake til 0.92.1.
  4. Bilder! Hadde gitt opp dette produktet for lenge siden ?
  5. MortenB
    Pollenvarsel
    https://pollenkontroll.no/api/pollen-count?country=no&location=126 Prøver å bruke RESTful sensor i Home Assistant til å fange dette, men sliter litt
  6. Jeg har assosiert S2 på en Dimmer 2 med Aeotec garasjeportåpner. Det fungerer fint, i Home Assistant. Gjøres i Z-Wave kontrollpanelet.
  7. Er det lov å håpe ? First we like to thank all of you great backers that have helped us with suggestions how to get pass the problems we have had. The new solution we have developed puts the z-wave module in sleep mode using Z-Wave FLiRS 1000ms technology and we are turning off all register functions and a lot of features in the mcu controlling the motor. This brings a 1 second interval in the communication with the gateway. This means that between the point when a user want to change position of a MOVEZ and when the device will execute that command there will be some delay. In theory because we have 1 second interval the delay time would be 0.1 to 1 second but in reality there will be a lot of things influencing this. In our tests with different z-wave hubs we have seen that things like how fast the transmission between the app and gateway is and how good radio connection the MOVEZ will have does affect this delay quite a bit. But we think the delay will be acceptable and thanks to it we have managed to drive down the power consumption to a level where we think it will be acceptable and we can send out beta test devices. During the next week we will reach out to all beta testers asking for the correct address where they want us to send the devices. We are then planning for beta testers to test during 4 weeks before we together with the beta testers can make a decision regarding if the software is stable enough to go forward or if changes are needed. We are still working with catching up with emails but we have prioritised development the last weeks making emails pile up. We feel that we are making progress and will be able to go forward with this new power saving solution. Like we have mentioned before our goal is to send everyone useful devices not only send devices. We like to thank all you backers for the patience, understanding and support. Together we will bring MOVEZ to the market.
  8. Samme løsning som jeg har valgt. Mill-appen gjør det såpass enkelt at jeg synes det blir mer styr enn nødvendig å lage noe tilsvarende i HA.
  9. Kan være verdt et forsøk, ja..
  10. Ja, kjøpte via Powerbuy her på forumet og fikk i første batch.. Z-Wavemodulen var også første leveranse uten offisiell emballasje..
  11. Veldig rart.. Har hatt min ID Lock i bruk siden mars 2018, og fortsatt 35% strøm igjen ifølge Home Assistant. Z-Wavemodul siden juli..
  12. Ser det er mange som har fått refundert beløpet for MoveZ nå. Kanskje det er håp? https://www.indiegogo.com/projects/movez-motorize-blinds-and-shades#/comments Sikkert litt mer omfattende siden det er et powerbuy, men..
  13. Akkurat det samme skjedde med meg. Også Aidonmåler. Håper det kun er at porten ikke er åpnet..
  14. Du må ha det for at parring i secure mode skal fungere, se denne dokumentasjonen: https://www.home-assistant.io/docs/z-wave/installation/
  15. Har du laget en network key for z-wave og parret låsen i Secure mode?
  16. Ja, skjønner at det er noe optimistisk. Litt kjipt at man kan ende opp med å få en løsning fra IKEA lenge før dette faktisk blir et endelig produkt. Helt sprøtt at det skal være så vanskelig å legge til Z-Wave støtte på et produkt som allerede selges med bluetooth..
  17. IKEA er rett rundt hjørnet med rullgardiner med Zigbee. https://9to5mac.com/2018/11/10/ikea-smart-blinds-price/?fbclid=IwAR0PP5WFu5_ILmirdcubBhkZ56foXykkpRfHiIgdZNdxNH_2yQ_mYQcQO-w Er det verdt et forsøk på en refund fra Teptron? Vet det er et long shot, men ser noen skriver at de har fått refundert. Dog kanskje verre med en powerbuy.. Siste oppdatering av et random kretskort: https://www.indiegogo.com/projects/movez-motorize-blinds-and-shades#/updates/all
  18. MortenB
    ID-Lock V2
    Jeg bestilte min fra Intin 9. januar, ble levert 19. februar.
  19. Gen 2 her
  20. Jeg får iallefall overstyrt mine ved å endre på varmeovnen. Status oppdaterer seg i Home Assistant.
  21. MortenB
    ID-Lock V2
    Nå ble jeg litt misunnelig Det er ikke så rett frem på Home Assistant for øyeblikket. Får håpe det bedrer seg etterhvert.
  22. MortenB
    ID-Lock V2
    Tar ca 3-4 minutter. Avslutt app og prøv på nytt.
  23. MortenB
    ID-Lock V2
    Slik fungerer det i Home Assistant også. Manual Unlock/Lock/Keypad Unlock.
  24. MortenB
    ID-Lock V2
    Jeg har også vært del av betatesting av appen for iOS. Rapportering av batterinivå fungerer i Home Assistant med ny firmware.
  25. Har 2 stk AC AP Pro. Den ene står i samme rom som de 2 Mill ovnene. Har 1 SSID med både 2.4GHz og 5GHz aktiv.
