mk1 black limited
VIP
Alt skrevet av mk1 black limited
  1. I seem to be getting flow temperature, @Tor Magnus: {"media":"cold water","meter":"multical21","name":"WaterMeter","id":"12345678","total_m3":46.618000,"target_m3":41.335000,"flow_temperature":5,"external_temperature":13,"current_status":"","time_dry":"","time_reversed":"","time_leaking":"","time_bursting":"","timestamp":"2019-01-24T08:09:22Z"}
  2. Very strange, my new 3B+ has the same problem:
  3. Got this: (cmdline) using usb device: /dev/ttyUSB1 (cmdline) number of meters: 0 (serial) opened /dev/ttyUSB1 (serial /dev/ttyUSB1) received "00" (amb8465) are you there? (serial /dev/ttyUSB1) sent "FF0B00F4" (serial) closed /dev/ttyUSB1 (serial) closed /dev/ttyUSB1 (serial) opened /dev/ttyUSB1 (im871a) are you there? (serial /dev/ttyUSB1) sent "A5010100" (serial) closed /dev/ttyUSB1 (serial) closed /dev/ttyUSB1 No wmbus device found! Anyway, as this is a very old Pi I've gone out and invested in a new 3B+ which I will try as soon as I get back home. Great excuse to get a new Pi.
  4. I've tried both auto (have added udev rules) as well as /dev/ttyUSB0 (and USB1). rw set to 777 right now, still same error. @Tor Magnus. have you got yours to work?
  5. @wmbusmeters - got the im871a USB stick today, and installed your program on my Pi, but I get "No wmbus device found!". It seems to be recognized, I see the im871-device in /dev. Any suggestions?
  6. Det nyhetsbrevet meldte jeg meg på for leeeenge siden, det har ikke kommet en eneste epost med info enda...:) Men vi krysser fingrene!
  7. Tro om det gjelder alle Hafslundkunder?
  8. Jada, nå var det ikke BT-delen som var det mest interessante her da vøttø
  9. https://www.digi.no/artikler/batterifri-bluetooth-merkelapp-henter-energi-fra-radiobolger/455686
  10. Pinne i posten på vei til meg også, vannmåler ble installert i våres.
  11. Jeg skjønner ikke helt dette produktet. Her har de en knapp ved døra som sender signal på 433Mhz til en z-wavedings på innsiden? Som så snakker med z-wvaekontrolleren som så snakker med sentralen? Så i prinsippet kunne man satt opp en Nexa-knapp ved døra i stedet og tatt inn signalet direkte på sentralen man måtte ha i stedet? Om dette faktisk kommer på markedet er jeg ikke sikker på om de kommer til å selge så mange av dem.
  12. Ikke noe problem
  13. Vi kunne bestille sammen for å spare litt i frakt?
  14. Ja, den du har sett på var jo en del rimeligere også.
  15. Farnell har to forskjellige, og jeg er usikker på hvilken man skal ha: https://no.farnell.com/wurth-elektronik/amb8465/wifi-usb-stick-adaptor-868mhz/dp/1749515?mckv=s_dc|pcrid|265491119230|kword|+amber +wireless +amb8465|match|b|plid||slid||product||pgrid|50191607703|ptaid|kwd-322281592009|&CMP=KNC-GNO-GEN-SKU-MDC og https://no.farnell.com/wurth-elektronik/amb8465/wifi-usb-stick-adaptor-868mhz/dp/1749515?mckv=s_dc|pcrid|265491119230|kword|+amber +wireless +amb8465|match|b|plid||slid||product||pgrid|50191607703|ptaid|kwd-322281592009|&CMP=KNC-GNO-GEN-SKU-MDC
  16. Takk for påminnelsen Leter etter passende USB-dongle, de to som oppgis på Github koster jo litt... Billigste jeg fant var på Farnell (Amber) til drøyt 700,-. Andre alternativer som bør sees på?
  17. Det er masse GPS-trackere (krever SIM-kort) å få tak i på Aliexpress, gearbest etc. Kjøpte inn en for å teste, og det fungerer helt fint.
  18. Har testet mange forskjellige røykvarslere, både 433Mhz og div Fibaro, men har endt opp med Nest-varslere. Disse fungerer fantastisk stabilt og jeg har ikke fått falske varsler slik som jeg opplevde med andre (som er realtivt kjedelig midt på natten f.eks.).
  19. Samme her, samme feil med siste versjon av plugin dessverre.
  20. Tenkte mest på om dll-en han bruker er nyere enn den kan/skal/bør være
  21. Har forøvrig flere NewtonSoft.dll (ingen ligger der de ikke skal ligge), og ingen er så ny som den du bruker. Kan det være noe? (dette har jeg ikke greie på altså...:D)
