mk1 black limited
VIP
Alt skrevet av mk1 black limited
  1. Lette litt i manualen (nederlag, jeg vet...:D): Direct image, video and command requests In addition to serving HTML pages, Blue Iris can also act as a "video server." There are a number of methods for retrieving images and video from the Blue Iris web server for use on mobile devices, converting a USB camera into a web camera, or for any other purpose. Here are the paths to these methods: /image/{cam-short-name}?q=50&s=80 A single JPEG image from a specific camera or group, with optional quality (q) and scale (s) parameters. Quality is a percentage from 1-100, and scale may be any number >0. /image/{cam-short-name}?h=100 You may also specify a specific height (h) or width (w) instead of scale. /mjpg/{cam-short-name}/video.mjpg An M-JPEG stream. This stream is compatible with Blue Iris's "MJPEG stream request." /file/clips/{filename}&mode=jpeg&speed=100 An M-JPEG stream of a clip from your New clips folder. You may include additional subdirectory names in the filename. The speed parameter is optional, a percentage of normal playback speed. /thumbs/{filename} A thumbnail image from a specific file in the New clips folder. /alerts/{filename} A JPEG image from the Alerts folder. /admin?profile=x Temporarily change the active profile to x. Use x=-1 to toggle the lock status. /admin?camera=x&trigger Trigger camera x (short name) /admin?signal=x Changes the traffic signal state and returns the current state. x=0 for red, x=1 for green, x=2 for yellow. This requires admin authentication. /audio/{cam-short-name}/temp.wav Pull a raw audio stream (MIME type audio/x-wav). /cam/{cam-short-name}/pos=x Performs a PTZ command on the specified camera, where x= 0=left, 1=right, 2=up, 3=down, 4=home, 5=zoom in, 6=zoom out /cam/{cam-short-name}/pos=100 Causes a snapshot image to be captured from the specified camera. /h264/{cam-short-name}/temp.h264 Pull a raw H.264 stream (MIME type video/H264). This stream will play in a tool like VLC, and may be used in future versions of the ActiveX control. /h264/{cam-short-name}/temp.ts Pull an MPEG-2 transport stream (MIME type video/MP2T). /h264/{cam-short-name}/temp.m or .m3u8 Pull a virtual M3U8 file (MIME type application/vnd.apple.mpegurl). This will play in QuickTime, iPad and the iPhone using the iPhone Live Streaming format. Funker strålende (testet stillbilde og video)! Visste ikke om denne muligheten, så takk for spørsmålet Moskus!
  2. Har ikke forsket mye på det, men ut fra spesifikasjonene tror jeg ikke dette skulle være så vanskelig: Webcam Features Built-in multithreaded web server; supports authentication. Broadcast MPEG, a JPEG image stream to a Java client applet, or, Perform “true” webcasting using leading-edge Windows Media Technologies such as variable and multiple-bitrate encoding (full version). View all cameras at once remotely. PTZ controls accessible remotely in MPEG broadcast window. Stream and seek through large clips remotely without downloading the entire file. Detailed stats window. Use Blue Iris’s powerful digital Zoom and Pan functionality remotely! The default home page allows you to view all of your cameras and captured clips remotely; this page is easily customized. Integrated “mini-browser” to test your home page. Post images to a remote web server; maintain a ring of images; resize for use on cell phones and PDAs.
  3. Tenkte jeg skulle fortelle litt om systemet jeg bruker til kamerasikring, Blue Iris. Jeg har tidligere brukt Milestone (http://www.milestonesys.com) som er et knallbra system, men skal du ha flere kamera enn 8 stk blir det dyrt (inntil 8 er gratis). Dessuten er det foreløpig vanskelig å integrere med Homeseer, som jeg bruker. Blue Iris er også utrolig bra, det finnes plugin til Homeseer, og for opp til 64 kameraer koster det ikke mer enn $60. Jeg er kanskje i overkant opptatt av kamerasikring, men 8 kamera blir fort veldig lite hvis man har normal størrelse eiendom og enebolig. I tillegg har jeg et kamera plassert på min mors gårdsplass og skal ha et (eller flere) på hytta når jeg får Internet der - eksterne kamera på helt andre lokasjoner er helt uproblematisk å integrere. Mer info om Blue Iris finner man her: http://blueirissoftware.com Plugin'en til Homeseer gjør at du kan trigge events basert på bevegelser foran ett eller flere kamera (kan altså erstatte bevegelsessensorer), eller du kan trigge opptak på ett eller flere kamera basert på hendelser i Homeseer, f.eks. en bevegelsessensor har blitt utløst. Det finnes en app til iOS og Android (sorry Moskus) og et webgrensesnitt dersom du åpner for det fra Internet. Man bør ha en rimelig kraftig PC for å kjøre serverdelen hvis man har flere kamera med høy oppløsning. For mine 16 kameraer med litt ymse oppløsning ble en i5 for tregt, måtte opp på en i7. Men det er egentlig ikke så unormalt for et kamerasystem, selv om Milestone var betydelig snillere. Alt i alt er jeg svært fornøyd.
  4. Bare å invitere det, Moskus...:)
  5. Skal i en bursdag i kveld, men skal prøve å rekke det.
  6. Jeg vil ha den andre, Fermate - kan hente
