FredrikKan
Alt skrevet av FredrikKan
Startat om Trådfri Hub helt från början via appen och lagt upp några device på nytt och nu ser det ut att fungera - åtminstone kraschar plugin inte längre; jun-21 22:21:17 TradfriSeer Debug Gettin bulbs done! jun-21 22:21:17 TradfriSeer Plugin devices found count: 1 jun-21 22:21:16 TradfriSeer Debug CheckAndCreateBulbDevices() starting... jun-21 22:21:16 TradfriSeer Debug GetBulbListWhenHubIsOnline() done! jun-21 22:21:16 TradfriSeer Debug GetBulbListWhenHubIsOnline(): Total bulbs found: 0 jun-21 22:21:15 Plug-In Finished initializing plug-in TradfriSeer jun-21 22:21:15 TradfriSeer Debug RestartTimer, diff: 224286 jun-21 22:21:15 TradfriSeer Debug GetBulbListWhenHubIsOnline(): Hub is online, getting bulbs... jun-21 22:21:15 TradfriSeer Debug RestartTimer, nextWhole: 22:25:00 jun-21 22:21:15 TradfriSeer Debug GetBulbListWhenHubIsOnline() starting... jun-21 22:21:15 TradfriSeer Debug RestartTimer, timeNow: 22:21:15.7144415 jun-21 22:21:15 TradfriSeer Debug GettingBulbsAsync() starting... jun-21 22:21:15 TradfriSeer Debug Checking bulbs async... jun-21 22:21:15 TradfriSeer Debug Device found for hub with key: mW4dnknDY5zVgOm8 jun-21 22:21:15 TradfriSeer Plugin devices found count: 1 jun-21 22:21:13 TradfriSeer CheckAndCreateHubDevices() trigging... jun-21 22:21:13 TradfriSeer Debug OnlineCheck() starting... (hub: mW4dnknDY5zVgOm8) jun-21 22:21:13 TradfriSeer Debug LoadHubList() done! jun-21 22:21:13 TradfriSeer Debug LoadHubList() starting... jun-21 22:21:13 TradfriSeer Debug Checking hubs... jun-21 22:21:13 TradfriSeer Debug InitializeTrådfri() done! jun-21 22:21:13 TradfriSeer Polling has started... jun-21 22:21:13 TradfriSeer Debug Starting ProcessQueue() Thread.Timer... jun-21 22:21:13 TradfriSeer Debug InitializeTrådfri() starting... jun-21 22:21:13 TradfriSeer This beta will expire on October 1st, 2017. jun-21 22:21:13 TradfriSeer Starting initializiation. jun-21 22:21:13 Info Plugin TradfriSeer has connected. IP:127.0.0.1:62838 Ska fortsätta lägga till device och försöka styra dem.
Jag har dubbelkollat både IP och key - de är korrekta! Editerade in debug logging; jun-21 21:27:41 Info Plugin TradfriSeer with instance: has disconnected jun-21 21:27:40 TradfriSeer Debug RestartTimer, diff: 139170 jun-21 21:27:40 TradfriSeer Debug GetBulbListWhenHubIsOnline(): Hub is online, getting bulbs... jun-21 21:27:40 TradfriSeer Debug RestartTimer, nextWhole: 21:30:00 jun-21 21:27:40 TradfriSeer Debug GetBulbListWhenHubIsOnline() starting... jun-21 21:27:40 TradfriSeer Debug RestartTimer, timeNow: 21:27:40.8296361 jun-21 21:27:40 TradfriSeer Debug GettingBulbsAsync() starting... jun-21 21:27:40 TradfriSeer Debug Checking bulbs async... jun-21 21:27:40 TradfriSeer Debug Device found for hub with key: mW4dnknDY5zVgOm8 jun-21 21:27:40 TradfriSeer Plugin devices found count: 1 jun-21 21:27:40 Z-Wave Device: 2 Allrummet Motion Sensor Set to On/Open/Motion jun-21 21:27:39 TradfriSeer CheckAndCreateHubDevices() trigging... jun-21 21:27:39 TradfriSeer Debug OnlineCheck() starting... (hub: mW4dnknDY5zVgOm8) jun-21 21:27:39 TradfriSeer Debug LoadHubList() done! jun-21 21:27:38 TradfriSeer Debug LoadHubList() starting... jun-21 21:27:38 TradfriSeer Debug Checking hubs... jun-21 21:27:38 TradfriSeer Debug InitializeTrådfri() done! jun-21 21:27:38 TradfriSeer Polling has started... jun-21 21:27:38 TradfriSeer Debug Starting ProcessQueue() Thread.Timer... jun-21 21:27:38 TradfriSeer Debug InitializeTrådfri() starting... jun-21 21:27:38 TradfriSeer This beta will expire on October 1st, 2017. jun-21 21:27:38 TradfriSeer Starting initializiation. jun-21 21:27:38 Info Plugin TradfriSeer has connected. IP:127.0.0.1:62055 jun-21 21:27:38 Warning I/O interface TradfriSeer is down, executable is not running, restarting ... jun-21 21:27:30 Z-Wave Device: 2 Allrummet Motion Sensor Set to Off/Closed/No Motion jun-21 21:27:10 Info Plugin TradfriSeer with instance: has disconnected jun-21 21:27:08 Plug-In Finished initializing plug-in TradfriSeer jun-21 21:27:08 TradfriSeer Debug RestartTimer, diff: 171634 jun-21 21:27:08 TradfriSeer Debug GetBulbListWhenHubIsOnline(): Hub is online, getting bulbs... jun-21 21:27:08 TradfriSeer Debug RestartTimer, nextWhole: 21:30:00 jun-21 21:27:08 TradfriSeer Debug GetBulbListWhenHubIsOnline() starting... jun-21 21:27:08 TradfriSeer Debug RestartTimer, timeNow: 21:27:08.3659795 jun-21 21:27:08 TradfriSeer Debug GettingBulbsAsync() starting... jun-21 21:27:08 TradfriSeer Debug Checking bulbs async... jun-21 21:27:08 TradfriSeer Debug Device found for hub with key: mW4dnknDY5zVgOm8 jun-21 21:27:08 TradfriSeer Plugin devices found count: 1 jun-21 21:27:06 TradfriSeer CheckAndCreateHubDevices() trigging... jun-21 21:27:06 TradfriSeer Debug OnlineCheck() starting... (hub: mW4dnknDY5zVgOm8) jun-21 21:27:06 TradfriSeer Debug LoadHubList() done! jun-21 21:27:06 TradfriSeer Debug LoadHubList() starting... jun-21 21:27:06 TradfriSeer Debug Checking hubs... jun-21 21:27:06 TradfriSeer Debug InitializeTrådfri() done! jun-21 21:27:06 TradfriSeer Polling has started... jun-21 21:27:06 TradfriSeer Debug Starting ProcessQueue() Thread.Timer... jun-21 21:27:06 TradfriSeer Debug InitializeTrådfri() starting... jun-21 21:27:06 TradfriSeer This beta will expire on October 1st, 2017. jun-21 21:27:06 TradfriSeer Starting initializiation. jun-21 21:27:06 Info Plugin TradfriSeer has connected. IP:127.0.0.1:62018 Har en idé om att göra reset på Trådfri hub och starta om den från början. Återkommer när jag vet mer...
Kopierade manuellt in en fil som fattades "HSPI_TradfriSeer.exe" och därefter startar TrådfriSeer men fungerar inte korrekt. Så här ser loggen ut; jun-20 22:12:54 Info Plugin TradfriSeer with instance: has disconnected jun-20 22:12:53 TradfriSeer Plugin devices found count: 1 jun-20 22:12:52 TradfriSeer CheckAndCreateHubDevices() trigging... jun-20 22:12:52 TradfriSeer Polling has started... jun-20 22:12:52 TradfriSeer This beta will expire on October 1st, 2017. jun-20 22:12:52 TradfriSeer Starting initializiation. jun-20 22:12:52 Info Plugin TradfriSeer has connected. IP:127.0.0.1:57171 jun-20 22:12:51 Warning I/O interface TradfriSeer is down, executable is not running, restarting ... jun-20 22:12:22 Info Plugin TradfriSeer with instance: has disconnected jun-20 22:12:21 TradfriSeer Plugin devices found count: 1 jun-20 22:12:20 TradfriSeer CheckAndCreateHubDevices() trigging... jun-20 22:12:19 TradfriSeer Polling has started... jun-20 22:12:19 TradfriSeer This beta will expire on October 1st, 2017. jun-20 22:12:19 TradfriSeer Starting initializiation. jun-20 22:12:19 Info Plugin TradfriSeer has connected. IP:127.0.0.1:57169 jun-20 22:12:19 Warning I/O interface TradfriSeer is down, executable is not running, restarting ... jun-20 22:12:06 Warning File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\TradfriSeerHubs jun-20 22:11:51 Info Plugin TradfriSeer with instance: has disconnected jun-20 22:11:49 Plug-In Finished initializing plug-in TradfriSeer jun-20 22:11:49 TradfriSeer Hub device created! jun-20 22:11:49 TradfriSeer Plugin devices found count: 0 jun-20 22:11:47 TradfriSeer CheckAndCreateHubDevices() trigging... jun-20 22:11:47 TradfriSeer Polling has started... jun-20 22:11:47 TradfriSeer This beta will expire on October 1st, 2017. jun-20 22:11:47 TradfriSeer Starting initializiation. jun-20 22:11:47 Info Plugin TradfriSeer has connected. IP:127.0.0.1:57137 Skulle vilja starta om helt från början. Hur gör jag för att ta bort alla spår av denna installation? /Fredrik
Har nu stoppat Homeseer, packat upp filerna igen i HS3-katalogen, återstartat HS3. Inga felmeddelanden vid uppstart i loggen, men heller inte ett spår av TrådfriSeer bland mina plugin. Vad ska jag göra?
1. Jag avinstallerade och gjorde om installationen 2. Starade om Homeseer (eftersom plugin inte syntes bland de installerade) 3. Fick ett fel i uppstarten av Homeseer: 2017-06-19 22:42:35 ~!~Error~!~(1) Unable to initialize interface TradfriSeer :Either no license or trial has expiredStartup Complete, 2 errors detected, check the log for more information. Tips å tricks? Lägger mig nu men ser om du har några förslag i morgon kväll. God natt! Fredrik
Windows (Windows Home Server 2011) Log; jun-19 22:00:14 Warning I/O interface TradfriSeer is down, executable is not running, restarting ... jun-19 21:59:45 Info Plugin TradfriSeer with instance: has disconnected jun-19 21:59:44 TradfriSeer Plugin devices found count: 1 jun-19 21:59:42 TradfriSeer CheckAndCreateHubDevices() trigging... jun-19 21:59:42 TradfriSeer Polling has started... jun-19 21:59:42 TradfriSeer This beta will expire on October 1st, 2017. jun-19 21:59:42 TradfriSeer Starting initializiation. jun-19 21:59:42 Info Plugin TradfriSeer has connected. IP:127.0.0.1:64237 jun-19 21:59:41 Warning I/O interface TradfriSeer is down, executable is not running, restarting ... jun-19 21:59:12 Info Plugin TradfriSeer with instance: has disconnected jun-19 21:59:11 Plug-In Finished initializing plug-in TradfriSeer jun-19 21:59:11 TradfriSeer Plugin devices found count: 1 jun-19 21:59:10 TradfriSeer CheckAndCreateHubDevices() trigging... jun-19 21:59:09 TradfriSeer Polling has started... jun-19 21:59:09 TradfriSeer This beta will expire on October 1st, 2017. jun-19 21:59:09 TradfriSeer Starting initializiation. jun-19 21:59:09 Info Plugin TradfriSeer has connected. IP:127.0.0.1:64232 Ja - jag packade upp filerna direkt i rot-biblioteket för Homeseer och svarade ja på frågan om att slå ihop innehållet i bin-katalogen.
Hej Moskus! Installerade just och konfigurerade ip-adress samt "key". När jag sparade konfigurationen så stoppade plugin omedelbart. Jag provade att starta den igen men den stoppade åter omedelbart. Nu visas bifogat felmeddelande. Ska se om jag kan komma åt konfigureringen utan att installera om... Hälsningar Fredrik
