HåPe
Alt skrevet av HåPe
  1. HåPe
    TrådfriSeer
    Köpte ett par Trådfri strömbrytare idag. De dök inte upp i HS så gissar att du måste fixa support för dem i pluginen. Något som är på gång? Någon info jag kan hjälpa till med?
  2. HåPe
    TrådfriSeer
    Från FB-gruppen "Svenska Hemautomatiseringsgruppen" (i ett mail från IKEA): We at IKEA would like to inform you about a change to our TRÅDFRI Gateway. We are very happy to see your interest in our gateway and have seen that you are using the CoAP interface. We consider the CoAP interface as our internal interface not developed for third party usage and therefore we do not offer any technical support for this usage. However that does not mean that we want to hinder your work in any way. There are some security improvements in a soon coming update that we would like to inform you about since it will break your implementation. Technically the improvement is that the TRÅDFRI Gateway will start using DTLS Identities which you will need to handle in your application. Please use the Following string to connect to the TRÅDFRI Gateway and create a new DTLS Identity. coap-client -m post -u "Client_identity" -k "SECURITY_CODE" -e '{"9090":"IDENTITY"}' "coaps://IP_ADDRESS:5684/15011/9063" SECURITY_CODE is what is labelled on the Gateway label, IDENTITY is any string that is representing the connection. You will then get back a PRE_SHARED_KEY that can be use in all traffic after that. coap-client -m get -u "IDENTITY" -k "PRE_SHARED_KEY" "coaps://IP_ADDRESS:5684/15001" We also would like to request that the SECURITY_CODE that is printed on the gateway is never stored permanently in your application.
  3. HåPe
    TrådfriSeer
    Bytte exe-filen med pluginen disabled. Då försvann mina inställningar, ip/passord, från ini-filen.
  4. HåPe
    TrådfriSeer
    Hade en V7.0.1 i Homeseer-mappen. Döpte om den så länge och då funkade det. Får väl se vad som slutar att fungera istället ?
  5. HåPe
    TrådfriSeer
    Yes!
  6. HåPe
    TrådfriSeer
    Efter att jag bytt till en felaktig IP och sen satt tillbaka till den adressen Huben har så blev den online. Då dök tyvärr ett nytt felmeddelande ang json-dll upp. jul-28 14:00:05 TradfriSeer ExecuteCommand(GetBulbs) Error: Det går inte att läsa in filen eller sammansättningen Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed eller ett av dess beroenden. Den påträffade sammansättningens manifestdefinition matchar inte sammansättningsreferensen. (Undantag från HRESULT: 0x80131040) jul-28 14:00:05 TradfriSeer Debug GetBulbListWhenHubIsOnline(): GetBulbs() queued... jul-28 14:00:05 TradfriSeer Debug GetBulbListWhenHubIsOnline(): Hub is online, getting bulbs... jul-28 14:00:05 TradfriSeer Debug GetBulbListWhenHubIsOnline() starting... jul-28 14:00:05 TradfriSeer Debug GettingBulbsAsync() starting... jul-28 14:00:05 TradfriSeer Debug UpdateHub() done! Getting bulbs async... jul-28 14:00:05 TradfriSeer Debug Updating existing hub
  7. HåPe
    TrådfriSeer
    När den loggar "ping result", är det en helt vanlig ping eller försöker den göra något mer (exempelvis logga in)? Får "Ping result for hub xxxxxxxxxxxxxxxx: Offline" (fast med mitt passord) även med firewall avslagen. Kan pinga den från powershell utan problem.
  8. HåPe
    TrådfriSeer
    HSPI_TradfriSeer.exe.config saknades. Den ligger inte med i V0.0.0.6. Tog den från V0.0.0.3 nu och det verkar lösa problemet!
  9. HåPe
    TrådfriSeer
    Ja, och PCn också.
  10. HåPe
    TrådfriSeer
    Så fort jag försöker ändra något i konfigen kommer detta: jul-26 14:23:30 Error Posting back to plugin web page TradfriSeerHubs: Objektreferensen har inte angetts till en instans av ett objekt.-> Server stack trace: Exception rethrown at [0]: vid System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) vid System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) vid HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) vid Scheduler.proxyPage.postBackProc(StateObject& state, String Data) jul-26 14:23:30 TradfriSeer Debug UpdateHub() #1 jul-26 14:23:24 TradfriSeer Debug GetPagePlugin name: TradfriSeerHubs Men värdena i config-filen ändras. Statusen på plugin-sidan är "WARNING: Failed getting InterfaceStatus from TradfriSeer - the interface was not found in the list of active interfaces, the list may need to be refreshed." Disable/enable på pluginen ger följande: jul-26 14:26:31 Plug-In Finished initializing plug-in TradfriSeer jul-26 14:26:31 Error Initializing plug-in(2): TradfriSeer Instance::Det går inte att läsa in filen eller sammansättningen CoAP, Version=1.1.6.0, Culture=neutral, PublicKeyToken=e2c10a743037308b eller ett av dess beroenden. Det går inte att hitta filen.STACK: Server stack trace: Exception rethrown at [0]: vid System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) vid System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) vid HomeSeerAPI.IPlugInAPI.InitIO(String port) vid Scheduler.clsHSPI.CheckInterfaces() jul-26 14:26:31 Warning Attempt by plugin to register a duplicate link of TradfriSeerHubs. Plugin: TradfriSeer Instance: jul-26 14:26:31 TradfriSeer This beta will expire on October 1st, 2017. jul-26 14:26:31 TradfriSeer Starting initializiation. jul-26 14:26:31 Info Plugin TradfriSeer has connected. IP:127.0.0.1:50518
  11. HåPe
    TrådfriSeer
    Packade upp zip-filen till HS3-installationsmappen. Så jag har de 6 dll-filerna i C:\HomeSeer\Bin\TradfriSeer och HSPI_TradfriSeer i C:\HomeSeer Sen har den skapat en ini-fil i config-mappen. Pluginen syns i HS3 och jag kan mata in IP/key. Men inga lampor dyker upp och försöker jag ändra t.ex. nyckeln så kommer ovanstående felmeddelande igen.
  12. HåPe
    TrådfriSeer
    Provade lägga in denna men får följande fel vid start av Homeseer: jul-26 13:19:02 Plug-In Finished initializing plug-in TradfriSeer jul-26 13:19:02 Error Initializing plug-in(2): TradfriSeer Instance::Det går inte att läsa in filen eller sammansättningen CoAP, Version=1.1.6.0, Culture=neutral, PublicKeyToken=e2c10a743037308b eller ett av dess beroenden. Det går inte att hitta filen.STACK: Server stack trace: Exception rethrown at [0]: vid System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) vid System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) vid HomeSeerAPI.IPlugInAPI.InitIO(String port) vid Scheduler.clsHSPI.CheckInterfaces() jul-26 13:19:02 TradfriSeer This beta will expire on October 1st, 2017. jul-26 13:19:02 TradfriSeer Starting initializiation. Vad kan det vara den saknar?
