Tue
Alt skrevet av Tue
  1. Tusinde tak for dette, det er lige det jeg har ledt efter, jeg er helt ny i yalm. Kan du give mig et hint i hvorledes jeg i et script kan bruge dette. Jeg ønsker af når elbil lader bliver sat i så skal den finde gennemsnit pris over de 3-9 billigste timer fra NU til i morgen kl 7. jeg tænker noget sodu code som dette: ford_battery_size: 89 kWh ford_battery_charge_speed: 10 kWh end_charge_level: 100 % if sensor.mustang_gt_easee_status from: disconnected and device_tracker.fordpass_tracker = type: is_home then conditions missing_charge: ford_battery_size/100 * (end_charge_level - sensor.ford_hv_battery_percent) charge to end_charge_level #100%: Hours_needed = ((Ford_battery_size/100 * (end_charge_level - sensor.ford_hv_battery_percent)) / ford_battery_charge_speed) + 1 | round(0) {% set low_interval_length = Hours_needed -%} If best_interval_price * missing_charge bellow XX kr make charge scheme, else test again with new end_charge_level = end_charge_level – 5% until it fits sequence: - service: easee.set_basic_charge_plan data: charger_id: XXXXXXX start_datetime: 2022-03-14T09:49 stop_datetime: 2022-03-14T09:50 repeat: false mode: single
